Official DF-03 Ra Thread
#576
RE: Official DF-03 Ra Thread
ORIGINAL: Eman77
I know, I know - not sure if I was aware of his special. If I was, I was probably too buried in debt to consider it. He says it was a good deal. Maybe I should have. [&:]
Really want that Lancia all of a sudden.
ORIGINAL: Casper06
You should have caught LB's special during December...
Still never too late to get one from Tower!
#577
ORIGINAL: bymannan
Hi All, I am looking to get this kit. I have a few questions about it, hope you can help.
1. Can I run LiPo with the stock motor and ESC? I plan to use a ZIPPY Flightmax 5000mAh 2S1P 20C hardcase pack. There isn't much use for an old NiMH battery, I plan to go Brushless at some point.
2. How much run time can I expect from the stock setup with the above LiPo?
I am a heli guy, on helis you fly for like 4.5 minutes... So I hope this will be a lot more.
3. Can this car kinda rally drift with stock electronics? Can it do that with any electronics configuration?
Thanks for now
Thanks for now
As to a run time I would guess in the 15-20 minute range depending on how hard you are running it. I ran 3s2200 batteries on my stock motor and was easily running for 10-12 minutes or until really hot. Then again, I wasn't full throttle most of the time either.
#578
Thanks! Will a 139 x 46 x 26mm buttery fit?
ORIGINAL: CWHFSR
Running that battery won't be a problem as long as it fits. It is a pretty small space for batteries and a hard case will make it very tight. I would check with the size of your battery and then the size of the location on the car (I don't know that size off hand).
ORIGINAL: bymannan
Thanks for now
Thanks for now
#579
AB, CANADA
Well I just finished my LED light project for my Lancia Delta. It was a great looking body before but I like it more now. I made my own taillight boxes using polycarbonate and aluminum tape, drilled out the headlights, and added a RPM four light cannister bar to the front (it looks very close to scale). let me know what you think.
#580
IL
ORIGINAL: bridge69
I've still gotta get some paint for my Lancer, I'll post some pics when It's painted.
#581
My Feedback: (10)
QC, CANADA
Looking sharp indeed!
The level at which people are finishing this car is phenomenal (people other than myself that is)
It really brings out the artist in (most of) us.
#582
ORIGINAL: bymannan
#583
AB, CANADA
Thanks for the comments on my Lancia. Half the fun of this hobby is building the cars! I picked up a Mistubishi Evo X from Tower with their Christmas special. I plan on making another Rally / Drift car with the body. I plan on using the extra chassis for spare parts. I have a 3 Racing LED kit for this set up with turn signals and brake lights! I've got some carbon decal for the hood and rear wing.I will post photo's when I have it done.
CWHFSR, thank Aflipz for this battery information from page 7:
The battery tray is (approximately)
145MM long (it's a bit longer but there's some of that space used for the hinge pin that holds the door in, you'll understand when you see it. basically a bit shorter than 145mm would be preferable, wouldn't really risk buying one longer than 140-143 myself)
50MM wide (but again I'd leave a few MM maybe 5, to clear wires, any bulge the wires sticking out the side of the pack and so forth)
roughly 27MM deep. Doubt that part would be problematic with any 2 cell pack.
#585
I agree with both of you. Ipersonally run a 4000mah 2S lipo in my DF-03Ra with the Sidewinder 4600kv combo. Even in Texas heat the motor is a nice 140-145 ESCis tops at 135 with a dust shield on andy the body. Zippy hardcase packs will not fit since the battery tray is meant for a standard 6 cell nimh...however you can dremel the sides to jam it in there. On my lipo it was a soft pack so I just dremeled out parts of the upper chassis so the wires don't get bunched up.
Depending on your gearing, your run time on a 5000mah 2S should be in the ball park for 25 minutes maybe half an hour depending on the course or if you're just blasting around the street. However with the stock silver can about 27T...you will lose a lot of the power your lipo can provide. Iwould say at least make a jump to the Sport Tuned black can version...it's only $25.
With stock electronics is was hard to maintain a good drift...the most you'd get is maybe a little over half a circle. However with a brushless setup on 2S...go nuts!
This car is extremely versatile being of buggy heritage to take jumps (yes I have taken it to several short course tracks (slipper installed of course lol), easy lock on the ball diffs for drifting, and very easy to waterproof if you go mudding like Ido.
Enjoy the car!
Enjoy the car!
ORIGINAL: CWHFSR
ORIGINAL: bymannan
Thanks for now
Thanks for now
#586
IL
ORIGINAL: Ttam Says Blarg
I didnt know about it so...? That Lancia is an awesome body! I have seen some stellar paint jobs on that body!
ORIGINAL: Eman77
ORIGINAL: Casper06
...then get me one!
#587
Thank you. Boy, this is a much much more expensive hobby than Helis. The last heli I built is a HK450GT with a very good ESC and motor and the whole thing was 160$ with 2 LiPos. Here going brushless with a nice upgrades such as the clutch and the inner cover will set me way over the 300$ mark easy..... Makes me think I should go with the Slash 2WD RTR which is less. But it does not speak to me as this EVO X car.
Are you sure Zippy hardcase packs will not fit? The numbers bridge69 wrote (thank you) are 145 x 50 x 27mm, and the hardcase Zippy is 139 x 46 x 26mm. If i'll find a way for the wires to come out, I should be fine no?
Thanks again...
Thanks again...
ORIGINAL: alexchen86
I agree with both of you. I personally run a 4000mah 2S lipo in my DF-03Ra with the Sidewinder 4600kv combo. Even in Texas heat the motor is a nice 140-145 ESC is tops at 135 with a dust shield on andy the body. Zippy hardcase packs will not fit since the battery tray is meant for a standard 6 cell nimh...however you can dremel the sides to jam it in there. On my lipo it was a soft pack so I just dremeled out parts of the upper chassis so the wires don't get bunched up.
Depending on your gearing, your run time on a 5000mah 2S should be in the ball park for 25 minutes maybe half an hour depending on the course or if you're just blasting around the street. However with the stock silver can about 27T...you will lose a lot of the power your lipo can provide. I would say at least make a jump to the Sport Tuned black can version...it's only $25.
This car is extremely versatile being of buggy heritage to take jumps (yes I have taken it to several short course tracks (slipper installed of course lol), easy lock on the ball diffs for drifting, and very easy to waterproof if you go mudding like I do.
Enjoy the car!
Enjoy the car!
ORIGINAL: CWHFSR
ORIGINAL: bymannan
Thanks for now
Thanks for now
#590
ORIGINAL: theibault
Pretty good for an all around tire. Pushes a bit on pavement. Life span is based on how you drive and what motor you have.
What inserts do you use?
#591
My Feedback: (10)
QC, CANADA
ORIGINAL: 378
I'm fitting them on my NTC3, so figure about the same power as a ~4200kV BL on 2S lipos.
ORIGINAL: theibault
I would add that durability also depends on surface used.
#592
Ahh, so it's like the tires on my CEN. That's good to know, though I remember tires that don't need inserts tend to be pretty bouncy.
As for the surface I'm going to run on, it will vary considerably. Mud, snow, dirt, dust, gravel, rough and smooth asphalt, even some concrete. Pretty much anything one could run a shaft-drive touring car on.
#593
My Feedback: (10)
QC, CANADA
ORIGINAL: 378
That's exactly what these tires are designed for. They don't bounce too bad IIRC. I do use a variety of tires for different surfaces, from racing slicks to rally tires and everything in between. Never tried it on foams though I am sure it would perform quite nicely. I only wish we could adjust rear toe. (and get sealed gear diffs)
#594
ORIGINAL: aflipzThat's exactly what these tires are designed for.
These tires ought to do the trick.
I can adjust my toe-in though. I'm leaving it at the stock 2º just to preserve the tires, with 4WD I don't need excessive rear toe. It tends to follow the front wheels when I floor it.
#595
My Feedback: (10)
QC, CANADA
ORIGINAL: 378
I would want to remove a bit, how do you adjust your REAR toe in with a fixed lower control arm pivot point and hub carrier? I can adjust front toe and camber, but only camber in the back.
If you need a slipper; get a slipper! These weak ball diffs won't last under high power if you rely on them slipping to save the gears.
In fact, IMO these (ball diffs) are the major killjoy on these cars; they are weak, don't keep adjustment and are overly sensitive to dirt contamination. I want to dial in my diffs with various density silicon oils and never have to mess with them again.
I quite simply don't drive the car anymore partly due to this; it's just too tedious to keep fumbling with diff adjustments and cleaning/lubing all the time.
#596
ORIGINAL: aflipz
ORIGINAL: 378
#597
My Feedback: (10)
QC, CANADA
I don't know...
It could be I'm a little jaded with RC cars at least at the moment; my complaint doesn't seem to be so popular... It's just that in my opinion/experience is that ball diffs are obsolete. I'm sure when I get it back out there I will love my DF03RA again though so take my rant with a grain of salt...
They all have their pro's and cons. I don't know that I would ever buy anything 2wd though. especially not something designed to go off road. personal taste.
#598
ORIGINAL: aflipz
ORIGINAL: 378
#599
what size bodies fit on the chassis?
would these work? : http://www.tamiyausa.com/product/ite...oduct-id=51188
http://www.tamiyausa.com/product/ite...oduct-id=51223
#600
My Feedback: (10)
QC, CANADA
ORIGINAL: bubbz
Yes.
That's too rich for my blood though.
