Official Tamiya TT-01 Thread
#6026
the "racing slicks" that come with the kit are garbage, get some HPI x-patterns. ball bearingings are a must, the stock sillver can is 27t so i would get a 23t RZ or TZ super sport motor, real good torque and RPM, the kit in question has the 'long" wheel base (or standard TT-01 wheel base), basically for the BMW Z3 kit it has the rear A arms flipped to make the wheel base smaller. ebay or tower or RCmart are your friends when it comes to hop-ups, i would suggest propeller shaft and upgrade the steering assembly ball bearings, new tyres. that's really all is needed for this kit, anything more is strictly for looks, it is a seriously base kit, i love it though, and there is definately a limit to noticeable upgrades. i know this from experience, i hopped- up my TT-01 with almost everything and didn't really find a difference. i would also buy some aluminum steering knuckles and TGS parts bag with the shock mounts. good luck and have fun!
#6027
hi everyone. just need to ask one question, have any of you guys installed a ball diff at the front / rear? does it have any improvement in term of the performance compare to the stock one?
#6029
yes, i have done it, they are the axles from the ferrari kit. you have to use wide hexes, or epoxy 2 toghether, works well.
ball diff on the rear seams to help with power transfer, but this chassis i would say, save your money.
#6031
TN
Some one tell me if I'm wrong, but I believe this is the kit that comes with one set of short axles and one set of long axles.
http://www3.towerhobbies.com/cgi-bin...5&I=LXETJ1&P=K
I just hate you have to order 2 parts trees to get the wide hexes.
#6032
Hey guys,
A couple of months ago i bought an XB TT01-D. I love it, and drift it probably 4 times a week. However one thing that's always bothered me is that it seems to get weaker until my Nimh batteries run out. I realize this can be fixed by switching to Lipo batteries, (which seem to be getting pretty cheap). My question is this: will my stock ESC be able to handle Lipo? Its the TEU 104 or whatever. I know you need some sort of voltage cutout, but my esc alredy shuts down if it detects low voltage from my Nimh, will that work for lipo or will i need one of these: http://www3.towerhobbies.com/cgi-bin...LXPGM8&P=7
Thanks!
Felix
Thanks!
Felix
#6033
The TEU104 can handle 2S lipo, but you will need a cutoff. I use a Novak smart Stop, it works great. Wired mine to a deans-to-deans cable, that way I can easily transfer them to my other cars.
#6034
OH
hey all,
i was hoping to get some input from you all about gearing on my TT-01R. i recently got a LRP GT3 Turbo 14x2 motor and i dont really know where to start with gearing. i will be running it with a 2 cell lipo and mostly just drive around in a parking lot and am looking for something that won't overheat the motor. i dont really have a lot of gears to test with so thats why i'm asking here, but i can order whatever is recommended. i have the 55, 58, and 61 tooth spur gears that came with the kit and a 22 tooth pinion that i got for the stock gt tuned motor. let me know what you think.
thanks,
adam
thanks,
adam
#6036
Im kind of lost. I dont know why. My motor is HOT after a 20 min run. So hot that I cant touch it for more than about 4 secs. Im using stock gearing with a 27 turn motor by fantom.
#6037
Ok well after a little bit of searching I realized that I was using a 19 turn pinion from my durga and had left the stock on the silver can. Would a 23 turn pinion make my temps hotter or cooler?
#6038
i don't know what the experts would say ... but i think it's normal for your motor to get hot after a 20 min run
i think you should buy a heat sink... maybe it would help a little
#6040
#6041
hey guys! I got a TT01E Drift Spec for a while and upgraded some parts with (Yeah Racing Conversion kit, 3racing front one way and aluminium solid shaft for the rear) .
I use this car for drifting and solely for that purpose.
However, recently, after the upgrades, I have felt that the power has seemed to drop and I am wondering if there is anything else I can do to modify my TT01E, looking for input in 2 areas in particular:
1 - Gears: What are my options? What is the best ratio for drifting(highest torque, what numbers?)? If anyone has heard of countersteer drifting what do I have to do to get my car to do that?
2 - Brushless Setup: Again, what are my options? ESC and motor as well as lipos (i have been using NiMh)
3 - Any other hop ups that are useful or important for drifters?
Thanks in advance guys! (=<br type="_moz" />
#6042
hi i have a tamiya tt01e and i have
alloy motor heatsink
alloy prop shaft
ballbearings
alloy swing shafts, alloy dog bones
alloy spood diff
alloy front knuckle arms
and a 9T EZRUNSensorless Brushless Motor, though it 's to over powered and i am only using a nimh 7.2V instead of its max capicity of 11.1V Lipo. My Spur gears keep gring every time i go full power. Any Help, i screw them in the right place so is ther like an alloy spur gear or some something else ican do to stop the wear? others with thye same motor dont have this probs on there tt01's and tt01'e so wat do u guys think i am doing wrong.
thanks
alloy prop shaft
ballbearings
alloy spood diff
thanks
#6043
well if your car is wide tread it doe i dont know wat that means but see the hop up manual with your tt01 or tt01 e manual
#6044
hi guys iuse a 9t EzRUN brushlessand my spur gear makes a grindinding noise when i go full speed. wat can i do to stop it from happening, my spur gears only last a week or 2 before being unuseasble. I screw the screws in the right place on the motor mount. Any Hop ups needed other than
alloy prop shaft
ballbearings
alloy spood diff
And is there such a thing as metel spurs and would they help? thanks
alloy prop shaft
ballbearings
alloy spood diff
#6045
hi bok my gear comb is 25/55 and my spur is crunchingif i go full pedel. I am using same motor as yours except its the 9T version and a tt01e platform.Any help, thanks
#6046
Haddi Taha,
I think the problem is that your pinion gear is worn out, causing it to strip your spur gear. I recently had the same problem. The stock Tamiya pinion is too soft and wears out too quickly, especially with brushless power. I'm using the stock 19/61 gearing, so I upgraded to Tamiya's 49232 (Hard Coated 0.6 Aluminum Pinion Gear 19T/TL-01). You can also use ones from Robinson Racing, they should last longer than the standard Tamiya "AV" pinions.
Stripped spur gear
Worn out pinion
Hopup pinion on the left, stock pinion on the right
Here's the pinion gear I upgraded to (pic from rcmarket.com.hk)
Stripped spur gear
Worn out pinion
#6048
Hi all.. am new to this and thought i should become a member to find out things people do to there rc car..
anyway back to the reason why i am here.. i have a TT-01 tamiya...and i just wna try putin a 12T brushless motor in it.. but the thing is .. i wanted to use a hoobywing ezrun 12T one.. so i bought the motor and the problem is.. that the motor obvisly doesnt have the flat piece for the pinion to lock on ..like the tamiya onces have a flat surface on the motor where the pinion goes..so any other idea how i can make this EZRUN 12t motor run ?
#6050
i have looked at it carefully and it doesnt have the flat area.. even if you look up the motor online.. it doesnt show it . a standard o any tamiya motor has it.. thanks for the reply tho..il have a loook at it again
