#6201
RE: Welcome to Club SAITO !
Jim, I ran the .82 yesterday and found only a 100 rpm difference, then I remembered that I bought a 1.00 muffler for my .82. To be fair I will re-run the .82 using its own muffler first. The .91/1.00 muffler is considerably larger than the .65/.82 muffler but still has a 12mm inlet. Saito must have some logical reason for not using the .91/1.00 muffler on the .65, .72 and .82. I think the .62a is 10mm, I'll check.
#6203
well I think I found the problem Im thinking it is my gas tank I took the 80 out of the plane and put it on the bench with a brand new tank and seems to run without missing Im not sure but im only getting about 2/3 throttle b4 I get scared its gunna rip off the bench and kill everything in sight I did jump it to full once just for a second it seems like it wants to rev way to hight with a 13x6 prop but cant tell till its in the air. The feeler gage file helped me a lot the LS when screwed all the way in takes 3 turns to get it where you can put 2 feelers between the needles but thanks again Rideblue
#6205
I need some help getting the sleeve out of a OS Max fs 120 surpass. Has anyone had one of these apart? Do you have to heat the case to get it out? I am trying to fix this one for one of the guys in our club. I know we have a lot of talent here so someone must know how. It seems to be and interferance fit. I dont have any experence with the OS line. Thanks in advance. Harold
#6207
Thanks. I was wondering about that hole in the back. Is there a good way to time the cam? I marked the cam and case with a sharpie when I removed the cam but the chances of not loosing them when I clean the parts up is slim. The eng. was in a crash and the crank pin was scoring the back plate and caused a lot of aluminum and brass to go all thru the eng. It is so bad I can just turn it over. The owner thinks the crank may be bent but I wont know until I get it out and check it. Any advice on the cam timing would be great. Thanks
#6208
With the crank at top dead center and the piston all the way to the top, there is a little dot or line on the cam that should be aligned with the lifters. You can be more accurate with it towards the top but it will work towards the bottom also. Just so it is on the same alignment as the pushrods/lifters.
#6210
Hello, First post-I have been away from the hobby for a few years but getting back in. LOVE to fly. I really like th Saito engines, I have had very good luck with them. I have 2-80's and a 65. all on cubs. First question, would anybody know where I could get a rocker arm for the 65 ??? please e-mail. Thank-You
#6211
http://www.horizonhobby.com/Products...ProdID=SAI5041
Rocker arms for the 65 are the same for the 50, 56, 65, 72, 80, 82, 91, 100, & 125
#6212
My Saito 72 developed an air leak by the intake pipe and cylinder head. I replaced the oring and metal washer, and after 1/2 tank of flying the intake manifold is loose once again. What exactly is the repair method to stop this leak?
#6213
My Feedback: (14)
ORIGINAL: LordSirOb
Some say that repeated failures in this area are the fault of an old design/defective backplate. Replacing the backplate with the latest version remedies the problem for the most part.
Ed Cregger
#6214
ORIGINAL: w8ye
Flyer,
Sounds as though you have ruined the new rear bearing?
When installing a bearing into the crankcase, you must drive against the outer race only.
No hammers. Use a arbor press only
The balls of the bearing have made imprints on one of the races
Flyer,
These bearings are much more tight than the stock ones but the performance was about 100rpm better than before.
A very good thing about this engine is that it uses standard metric sizes on the bearings so they are dirt cheap[sm=wink_smile.gif]
#6217
I know much has been discussed regarding velocity stacks. They improve fuel economy and reduce spit back to keep the plane cleaner. Could they actually cause a decrease in rpm though?
Phillip
Phillip
#6221
The one for the Saito 50 will bolt right on. It's id is about the same as the throttle bore. But the throttle has the spray bar which makes its effective area smaller
http://www.horizonhobby.com/Products...odID=SAI50GK93
#6222
ORIGINAL: WWII
what prop would be best for a stio 125 on a funtana 90 for best hover pull out
the engine is brokin it
thanks
rob
thanks
rob
