Official Jammin X1CRT Thread
#601
MA
When the tire is 6"-7" tall how much traction do you think you get when you only have 1/2" of the tire gripping the dirt? The more rubber you get down on the dirt the more traction you get! I just ENJOY running the truck. I haven't had to replace anything but the tires because the centers wore out from running it on blacktop. With that said I'll just shut up, remove myself from this thread, and I'll go back to my cold weather hobby....Slot Cars!...If you check my site you might get an indication that your advice wasn't really needed.
http://www.75th-meu.com/MGSsTrucks.htm
#602
PA
ORIGINAL: Bill Plude
#603
ON, CANADA
Im thinking of getting the X1 CRT and was just wondering what is the first hop ups or upgrades I should get first. I have a Futaba 3PM that Im going to put into and then look for some servos.
Jesse
Jesse
#604
whats a good fr-cent-rear diff fluid i can switch too?
i think im running totally wrong
i just need a normal setup nothing particular
#605
PA
ORIGINAL: nbk
#606
crazy savage.
i am thinking about getting a gas burner 1/5 scale.
what do you know about the fire starter?
is it worth getting one?
thx Dirby.
thx Dirby.
#607
PA
ORIGINAL: Dirby
crazy savage.
thx Dirby.
crazy savage.
thx Dirby.
http://www.ofna.com/dm1-pro.html
#610
i noticed there is alot of slack in my front and rear wheels. Ive tightened all the nuts and bolts and still have the slack. The only thing i've noticed is that the pin that goes throught the knuckle arm has slack in it. Is there a way to fix this or are all jammins this way?
#611
just got a crt the other day. i like the force .28 but i think the picco .28 is calling me. i already went to the jp-3 but i want MORE. any advice/recomendations are welcome. please give your two cents.
#612
If you want to replace the force with a Picco then go with the new JAmmin picco engine. Trust me I had both the force and the new jammin 28 and they are miles apart
#613
good lookin out. my boss gotta revo that needs spanking, and although my force .28 is more than enough, humiliating him is all the more better. you gotta feel me.
#615
I have the RTR version of the X1CRT, im having a little trouble setting up the throttle linkage; the servo opens the carbs way past full open position, any suggestions ?
#616
hi, im interested to try the new jammin .28 engines.. any views on this engine? how bout parts availability? any links?? many thanks.
#619
Big mistake, with my Jammin I outrun both vspecs and ninjas last sunday at the race. I couldnt beleive it myself but the thing proved to be one hell of an engine escpecially in the straights were I was catching up and overtaking those said engines as if they were nothing.
ALL HAIL JAMMIN
ALL HAIL JAMMIN
#621
AZ
Yeah , your idle screw is set to low, just turn it in a turn or even half a turn. To answer your other post: I think all your problems are in your radios end-trim adjustments. If your throttle is opening way to much, then just trim it out with the end trim adj. Your brakes could be set out with this adj. also. I think spending time with your radio would help clear up all your troubles.
Now on to my thing, Bought a Jammin CRT pro today and its my first truggy, NOT my first r/c by any means. Any suggestions for a virgin truggyier? I have a 645mg steering servo off my buggy, wondering if this can handle a truggy setup?? Oh, and WOOT WOOT cant wait to run this beast.
#623
Hey guys,
I am a newbie to this site and to rc truggies. I have had my X1 CRT RTR for about 2 months now. It is my 1st nitro rc vehicle. It is a blast to drive but I want to get the handling better on it. I get the dreaded balloning front tires down the str8's and would like to fix it. From reading the posts I see changing the diff oil and shock oil will help some and I plan to do both this week but I want to replace the tires also.
I have never glued tires before... How difficult is it to glue the tires propery? any tips?
What are the best pre-mounted tires you can get that will help get rid of the balloning?
Any help for the newbie would be MUCH appreciated!
X1 CRT RTR Force .32 engine JP1 pipe.
Thanks guys
Thanks guys
#624
Does anyone else use the O.S. .21 V-spec in their CRT? If so how well does it race in this truck? I am still building mine so I have not been able to run it yet.
#625
ORIGINAL: Force4x4
