Old 02-17-2007, 04:36 PM
  #6351
NM2K
My Feedback: (14)
ORIGINAL: w8ye
The 72/82 do not exactly have the same beam width as the 56/62. The bigger engines are 1/8" (3mm) wider in between the beams but the bolt pattern for the mounting bolts is the same.
I stand humbly corrected by the Master. <G>
Ed Cregger
Old 02-17-2007, 05:07 PM
  #6352
skyleader slx
Hi Guys I bought my first Saito 82 and flew it in my U-can-do last week. I use Magnum 20% heli fuel. When I went to fly today when turning the engine over there was no compression my first thought was that the glow plug had for some reason come loose. On inspection the plug was still tight so I removed the rocker covers to find that the exhaust valve was jammed in open position, it was really stuck and would not readily free. Has anyone out there experienced a similar problem as I have only read good reports on these engines. I am an OS engine user and never experienced any such problems. I hope this is a one of.
Any replies welcomed.
John
Old 02-17-2007, 06:09 PM
  #6353
w8ye
w8ye's Avatar
Try squirting a little new fuel around the valve stem
It might also have the edge of the rocker arm adjusting screw jumped up on the end of the pushrod. Check for this?
Old 02-17-2007, 06:12 PM
  #6354
gjeffers
gjeffers's Avatar
what is the oil content on the magnum 20% heli?
Old 02-17-2007, 11:58 PM
  #6355
blw
blw's Avatar
khodges- I suggested the .72 because he wants to 'hang on the prop'. You would need good power to do that, which would be basically be hovering, right?
Old 02-18-2007, 07:52 AM
  #6356
maineflyer
My Feedback: (44)
maineflyer's Avatar
I just picked up a new Saito 1.50, any thoughts on the best 3d prop for it? I am thinking 17x6... Any other thougths would be appreciated.
Jeff
Old 02-18-2007, 10:17 AM
  #6357
w8ye
w8ye's Avatar
I'm not a 3D flyer. But as a gage of comparison, A 16-8 works nice on mine for general flying.
Old 02-18-2007, 08:45 PM
  #6358
az3d
My Feedback: (59)
I was using a 18x6W APC on my 70" edge 540 with a saito 150. It was awsome except it was causing the engine to overheat. I am looking for the right prop as well. I don't know if a 17x6 is enough. I am wondering if they make a 17x6W? My motor is at BJ's right now getting rebuilt. I will let you know what they think. They were talking to me about a 18X6.
Old 02-18-2007, 09:18 PM
  #6359
Pit-Viper 1
My Feedback: (12)
Pit-Viper 1's Avatar
My freind has H9 P-51 w/ Saito 1.25 and he uses an APC 16X8 and it is extremely fast and has almost no limit vertical. Just a touch over 8lbs. Not sure if this is a good comparison though. The 1.25 is a beast!!
Shane
Old 02-18-2007, 09:31 PM
  #6360
gjeffers
gjeffers's Avatar
the 18x6w is a little too much for the 150, its more a prop for the 180. i run a 17x8 on my 180 and would think a 17x6 would be better for the 150 whether its enough prop or not. that overheating may be what lead to the demise of your 150 from being overproped.
what plane and weight?
Old 02-18-2007, 11:09 PM
  #6361
PTS
My Feedback: (153)
Hello!
I am building a Pacific Aero Model GEE BEE "Y" 120. I am wanting to install the 170 3-cylinder radial in this plane. I hear things such as dropped cylinders, which fuel to use, which glow plugs to use, etc . . . I have never owned a radial, and I want to be sure I wount regret this purchase for this plane. What is the 170 compared to the single cyllinder SAITO as far as power? Please any comments!
Perry
Old 02-18-2007, 11:11 PM
  #6362
w8ye
w8ye's Avatar
Somewhere between a 120 and a 150
A lot of people run 15-8's on them. After it is broken in, it may pull a 16-8 without over heating?
Old 02-19-2007, 09:23 AM
  #6363
jasonlacey
What has happened to big Bill R? I saw in the last few posts that members were helping out. What can I do?
Old 02-19-2007, 09:51 AM
  #6364
RC Specialties
Jason,
There is a thread "Our friend Bill Robison is Okay" started by Hobbsy. Check it out for more info.
Jim
  #6365
Birman
Jason, look here for info on Bill.
http://www.rcuniverse.com/forum/m_5417994/tm.htm
Old 02-19-2007, 10:13 AM
  #6366
RC Specialties
Thanks, Birman!
Old 02-19-2007, 12:46 PM
  #6367
localbuyer
Dose anyone know where to get the CAM/Engine gasket for a Saito 82?
[link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=SAI82A32]Engine Gasket Set[/link]
I need the gasket to install the CAM housing. It's backorder for another month from Horizon.
I really don't understand why Saito would have this essential part be backordered for such a long time, it's not good customer service.
Old 02-19-2007, 02:17 PM
  #6368
Kmot
My Feedback: (24)
Kmot's Avatar
Have you ever tried making your own gaskets? It's pretty easy, actually. Get some paper that is the approximate thickness you need. Put some adhesive glue on it and glue it to the cam housing. Now carefully cut away the excess with an x-acto blade.
Old 02-19-2007, 03:07 PM
  #6369
UltimateFlyer120
UltimateFlyer120's Avatar
Can someone give me an easy way to touch up Golden Knight scratches? I did a search and must not have searched for the right thing.
Old 02-19-2007, 03:23 PM
  #6370
localbuyer
What's the correct thickness for the gasket? Can any type of paper be used as gasket?
Old 02-19-2007, 03:47 PM
  #6371
w8ye
w8ye's Avatar
The nominal thickness is .007". The maximum is .012"
Old 02-19-2007, 03:50 PM
  #6372
w8ye
w8ye's Avatar
Old 02-19-2007, 03:53 PM
  #6373
w8ye
w8ye's Avatar
High temperature paint is pretty good on the Golden Knights for touch up.
Be sure and remove all traces of oil first
Old 02-19-2007, 05:07 PM
  #6374
twm12664
Hey guys,
I am sick of waiting for a magnum 91 on back order from tower. Bottom line, if you had to choose between a saito or an os which engine would you chose? I am looking to power my sig four star 60 and would like to be able to move to a more aggressive plane with that same engine once I am proficient with the four star. Suggestions?
Cheers,
Tim
Old 02-19-2007, 05:22 PM
  #6375
RC Specialties
Tim,
There are many engines that will do the job. Personally I love the Saito engines. A FA-100 would do the job well. It is hard to beat a well tuned Saito. It's like auto's, some like Fords and some like Chevy's. It's a matter of taste and pocketbook. Sorry, it's not much help.
Jim
