Official Tamiya TT-01 Thread
#6576
Looks good! What shell you got on it?<div>
</div><div>Do you find yourself wanting the steering to go further drifting or is it ok?</div>
#6577
ORIGINAL: cydog510
yes
ORIGINAL: brushless4life
would a 3980kv brushless motor work with a 60amp ezrun v2 esc, or would there be problems
P.S. V.sorry for double post <br type="_moz" />
#6578
Thanks!
I got the Nismo Z-Tune GTRR34 shell but it's ab it damaged from the front
wish i could have another one Finished from the factory!best paints ever
and yeah about the steering i wish it'd go a bit futher.. no idea how to do that
i still need to install a better motor
probably gonna get that EZRun 5.5T 6000kv combo with the 60AESC
#6581
not sure if theres metaral gears but do get the optional speed tuned gears by tamiya (55t/58t spur gears, coloured black).
you wouldn't need metal gears as long as you drivetrain is bind free and smooth.
I have lots of hopups but these proved to be the most effective
http://www.rcmart.com/catalog/rc-tam...b-p-27070.html
http://www.rcmart.com/catalog/rc-dam...th=595_744_708
http://www.rcmart.com/catalog/rc-tt0...th=595_744_708 < u need 2 of these
http://www.rcmart.com/catalog/rc-tt0...h=595_744_1223
#6587
im upgrading my tt01 to a 3980kv brushless motor, 60amp ezrun v2 esc, alloy dampers, alloy mainshaft, matal ball bearings, metal motor mount, 2.4ghz reciver and transmitter, 6kg steering sevo and a 3cell 4200mah lipo. Would i need anything else
#6588
ORIGINAL: woody_294
Yeah with the 5.5t on 2s lipo you're looking at just under 40mph with standard gearing, lol.
What motor should I be installing to get it faster than 40 mph?
#6589
going beyond a 6000KV motor on a TT is silly, for one the drive train will not be able to handle it, the heat alone caused by friction would eventually melt components, for two, you'll have trouble keepin the wheels on the ground, ballooning of tyres compounded with lack of traction= no stability. if you wanna go straight line drag, a 5.5 ezrun will get you well past 60kph geared at 25/55 but going past that i would, from experience, suggest against it. the 5.5 is plenty swift for this entry level chassis.
#6591
hey brushless4life you need to get a larger hole pinion as the av pinions wont fit on that so put it in a car that takes 48pitch (your hsp)
#6592
Some more pictures of my RC:
Also any idea how i can replair scratched drifting tires? just so they could drift smoothly on carpet..
#6594
The R34 has to be one of my favourite cars of all time, from way back in the days of Gran Turismo 2. I'd say to clean them up I'd just run it on some wet and dry paper that you've taped down to a plank. Holding the car I mean, you may have to get someone to do the transmitter or you could get the wheels spinning using the trim on your tx
For drift btw, you may well find it's near impossible to control once you put that motor in it <br type="_moz" />
#6596
NO! Stop it with the Skyline already! I'm getting a Silvia <div>
</div><div>But then R34s are soooooooo cool... damn you sir for making me want a Skyline LOL</div>
#6597
good luck brushless for life, but it sounds a bit risky using a drill to get it to the right size, have u seen if swapping rotors with your old ezrun 13t ribbed can motor will work? You will need to use different bearing to do that
#6598
i bought a 5mm hole pinion 20t so i wont ruin my other pinions. its steel but it says it can run with plastic spur gears so it wont ruin my gears. And i didnt get the damper set so ill give your shock oil back by friday
#6599
Good idea, drilling the old pinion could have screwed it unless you have a good drill press and vice I ordered a GPM tie-rod set to see if that helps front suspension travel and general rubbishness!</div>
#6600
You guys i need help
How can i increase the steering angle?? do i need a new servo? new settings?
when i steer left, the wheels don't go left enough ..same to right
