#6827
RE: Welcome to Club SAITO !
W8ye,
Thanks for the information. I was wondering whether it would cause an intake restriction on the 1.00 due to the smaller diameter. I think I will give it a try.
Jim
Jim
#6828
Yeah, I am not going to polish the valves or the valve seats. If I send this off to Horizon it's going to be a pain to get them to repair or replace it under warranty as it is. If I go lapping the valves or valve seats I've got no hope.
I was thinking about just taking it to the field today and flying it to see what happens but I can't keep the engine running long enough for me to feel comfortable with it in the air. I'm going to be working on it this morning, but I'm not anticipating anything different. I just checked it and sure enough, there is very little compression. I'm going to pull the valve covers off today and snap the valves a few times and pull it up into the head with some pressure then see what happens. I'm not going to do anything that requires disassembly at this point.
I really need to fix my test stand.
ORIGINAL: Hobbsy
Here is Robert's engine turning an APC 14x6 at 9,200 plus with his muffler and IronBay regulator, then his engine turning 9,400 plus with a TurboHeader and no regulator. There were no valves hissing when it was here. William Robison cautioned people over and over about polishing the valve seats on the AAC Saitos, you can easily remove the chrome that serves as the seat. I cleaned Roberts with a Q-tip and they came clean easily.
#6829
It wouldn't start because it had no compression at all. I couldn't even find the compression stroke turning the prop around by hand. When it cools down it regains a bit. Then, sometimes, it doesn't get any worse after running for a few minutes. There is still plenty of hissing from the intake and exhaust manifolds regardless of whether it is warm, cold or otherwise.
Yeah I've done that, and Dave already cleaned 'em up real good. It ran fine for him. I am at a complete loss as to what is going on. The air here must be toxic to this paricular Saito or something.
ORIGINAL: w8ye
RVM,
I must have missed the part where you said it wouldn't run at all?
Your valves could just be gummed up around the stems and seats. Remove the rocker cover and squirt some fuel through the valve springs and then turn the prop several revolutions to move the valves up and down?
RVM,
#6830
Well, I ran the engine for a good 20 minutes this afternoon. It seems to have improved slightly. It doesn't leak all the compression within 2 seconds. Rather, it is taking around 5 seconds now. I'm going to go to the field and see if I can keep it running. If a couple more tanks through it (barring it dies in midair and the plane crashes or something) doesn't improve anything it's off to be looked at.
Thanks for all the advice and help so far!
#6831
My Feedback: (8)
Just to clarify something...
When I am talking about using the cleanser and oil mixture, you are not necessarily "lapping" the valves...you don't have to do it for more than a few seconds to knock off the pounded in flake of carbon or whatever...and, chrome is not THAT delicate...it's very hard and will take a few seconds of "cleaning" but not a lengthy "lapping" with a coarse cutting compound.
Another thing...you need to be careful which type of eraser you use, because the gray "pen" erasers can be a LOT more abrasive (coarse) than a Comet / Bon Ami cleanser and oil mix. And the eraser does nothing to clean the seating area on the valve face.
You just need to be "touched" [sm=bananahead.gif]...er..I mean you just need a delicate "touch" that's all...[sm=thumbup.gif]
You are just twirling the valve stem between your thumb and fore finger...
Edit: Just had a thought (ouch!) do you suppose it could be slightly warped valve(s)? They might be only slightly deformed or defective when cold, but that gets more pronounced when they get hot?
RVM...if you get tired of it and want to dump it, let me know, aye?
#6832
Two flights, one deadstick. I tried a few different fuels at the field with no difference. It sags and surges a lot, particularly on uplines. That would tell me it is too lean except for the fact it's got a pressure regulated fuel system so the fuel flow doesn't change. I richened it up anyway and it still sagged and surged. The fuel system will hold pressure for days, so I know it doesn't have any leaks.
The only thing I can think of that might not be working right is the regulator. It's still leaking a bit of air between it and the carb, but I didn't have these problems before and it was leaking then. It had the same problems on the test stand without a regulator anyway. Also, it doesn't explain the valve problem. At least Iron Bay is replacing the unit for me.
I've got a blowtorch that would not mind going on a date with some aluminum...
#6834
Yeah I did that a long time ago. I fly on a dirty field so anytime I ever have any kind of engine problem the first thing I do is clean the carb and needle valve. Believe it or not this is rarely ever a real problem.
ORIGINAL: freeonthree
Have you removed the HSN and blown fuel thru the inlet nipple on the carb yet ? Probably a silly question, that was probably done as soon as the problem started...
#6835
Unfortunately the November notes were the last addition Bill made. Not too long after this his home burned down and then he passed away.
I have thought about trying to continue to keep the Club Saito roster going, and keep the Notes updated, but unfortunately I don't have the knowledge or experience to fill his shoes.
ORIGINAL: N1EDM
If there are more recent notes than November '06, please let me know (and please send a copy or a link) and I'll post them and send out the new link.
Bob
Bob
#6836
My Feedback: (14)
ORIGINAL: RVM
Just a guess, but I would shorten the fuel tank intake line a bit. It could be that the fuel tank clunk is intermittently contacting the rear of the tank and shutting off fuel flow in little time segments, if that makes any sense.
Ed Cregger
#6840
The clunk, at its farthest, is about 3mm from the back of the tank. I checked that. The fuel system has been working fine for months. I just replaced all the fuel line and it held pressure overnight with no leakage.
That said, it's a good idea, and worth double check. Maybe I didn't measure it right the last time I did it. Thanks!
ORIGINAL: Ed Cregger
Ed Cregger
Ed Cregger
#6842
Has anyone had a problem with the exhaust manifold breaking on Saito 91's it's the angle one not the fully threaded straight one. I have 1 Saito 65, 5 72's, 2 100's and 2 125's plus the 91 and it the only one which breaks the manifold I have now broken two both in normal flight.
#6844
ORIGINAL: w8ye
Vibration is most likely the cause of your problem on this one engine.
Did you balance your prop?
Phillip
#6845
MB, CANADA
I have glued an aircraft ply wooden washer to the back of a wood prop that was too thin I make them with a 1" hole saw. I have also made spacing washers for behind props made from 1/32 aircraft ply with 340 wet and dry sand paper glued to both sides of the washer. I've used these on wood and composite props.
#6846
MB, CANADA
You can affect the hi side with the low speed adjustment. Trying for a low idle, if you lean the low speed too much it will prevent richening the hi speed enough and it could heat up.
#6847
Some Saito's will idle very smoothly (no lope) while others like the 72, idle like they have a big cam. I believe it's mostly in the carb they used on a particular engine. My friend had a 65 that would idle at 1800-1900 rpm all day long, then the carb got munched in a crash. He bought a new carb, and now it won't idle below 2100 dependably. We really miss that old carb. lol He use to land and shut the reciever off and let that sucker sit there and idle as we all watched in amazement waiting for it to load up and die, but it would just keep idleing away until he shut it off. I'd love to buy a whole bag of those particular carbs. My 65 (picked up for $60.00), idles good, but not even close to Greg's old marvel... That 65's idle was rather famous in these parts, but now it's just a memory for us all.
#6849
My Feedback: (19)
NY
Jim,
The weather broke nicely and it was 65 today.
So, I ran the SAITO 82A with a stock muffler and the Turboheader.
Omega 15% is the fuel.
Idle Hi Speed
Stock 2200 rpm 7800 rpm
Turbo 2100 rpm 8000 rpm
Turbo with
new bafle 2100 8125 rpm.
The sound is even better. A truly awesome combination.
Thank you very much.
I'll keep you posted.
krop
Idle Hi Speed
Turbo with
krop
