Official Tamiya TT-01 Thread
#6878
Tamiya #5455040 for the one that goes on the shaft (it has to be ground down like 1mm or it will cause binding just hold it next to the stock tt01e and you will see where)
Tamiya #3454029 the big ring gear that goes on the diff
#6879
VA
compared to the e10 how well will the tt-01 handle brushless im looking at getting one and using a spare mmp esc and a tacon 4420kv on 2s
#6880
ORIGINAL: momogt
I had an EB10(buggy form of the e10) that I totaled the diffs in under 3 mins, and cracked a chassis almost in half with the same BL setup on pavement... There were no aftermarket parts to fix that issue, and HPI told me pretty much the e10, and eb10 were never meant to be modified.
#6881
My Feedback: (8)
NY
i put a castle sv2 esc and 4600kv in my stock tt-01 and it holds up fine. the only drivetrain upgrade i have is aluminum center shaft and ball bearings. i use a 2 cell lipo with it. the only problem i would say i have is that the rear diff deff unloads on one side when turning hard (doughnut style). but i bet that with a thicker grease or a spool it would be great.
#6882
thats a sweet merc body but you gotta run it ..its no fun if you dont i run mine with the exception of the wheels i change back to the stock bbs style im trying to get it to match or beat the speeds my truck does which i think is around 55-60mph i think i might be there just havent really opened it up yet...need to glue the tires lol was no need to glue with stock motor but now i need to
#6883
Hi I am new to electric on-road and is thinking about purchasing this:
http://www3.towerhobbies.com/cgi-bin...t-01&search=Go
and i am also planning to go straight to brushless. My question is, what are some good esc/motor brushless combo out there?
Thanks!!
Thanks!!
#6885
<div style="margin-top: 0px; margin-right: 0px; margin-bottom: 0px; margin-left: 0px; padding-top: 0px; padding-right: 0px; padding-bottom: 0px; padding-left: 0px; background-image: initial; background-attachment: initial; background-origin: initial; background-clip: initial; background-color: rgb(255, 255, 255); ">Hi all I'm a noob to rc drifting just purchased a tt01d a few days ago, I'm looking to upgrade to brushless Motor, could you guys help with what would be good kit to go with, also does anyone know about the yeah racing alloy kit conversion if it's good woth buying? One more thing I want to change the radio to 2.4 ghz, I have purchased a Fs-gt3b with reciver, would this be a good option and will the reciver work as it is a 5v dc Power source, is that fine to run off the 7.2 car batt cheers all.</div>
#6886
I'm getting ready to build my TT-01 kit and have a question about the paper motor gasket. I will be using the 3racing aluminum motor mount and a 9T ezrun motor. Does anybody use the paper gasket with this or any other application?
#6887
WA
TT-01R Type E chassis kit...
http://www3.towerhobbies.com/cgi-bin...?&I=LXYHY2&P=7
TT-01ER chassis kit
http://www3.towerhobbies.com/cgi-bin...?&I=LXANHJ&P=7
Can anyone tell me what difference there is between these, or which one would be better to get? I'm thinking the one with Tamiya part # 58450 as that would have been a later released kit... ?
If I don't end up getting a CR before they're all gone I'm getting a Datsun TT-01ED kit and one of these with another body ... do any of the HPI bodies have LED light buckets? Or should I look at mainly Tamiya bodies for that... For the ED kit I will likely get an alum. prop. shaft and joints, as well as a motor mount and possibly other bits, any essentials I'm forgetting... I'm thinking of leaving the steering for later..I'd like to know more about the car's specific setup first...
Also, would a JR ST126 MG servo do the trick, or could anyone recommend a good servo in the less than $50 range? Might get a Traxxas 125 oz. in. waterproof one, will go good with other blue bit's i'll add along the way...
Thanks again for making this RCU great folks.
TT-01ER chassis kit
#6888
<span class="Apple-style-span" style="font-family: verdana, arial, helvetica, sans-serif; font-size: 10px; ">These are the things that are on the TT01ER, which are not on the regular TT01E, but it's been discontinued by Tamiya.</span><div style="margin-top: 0px; margin-right: 0px; margin-bottom: 0px; margin-left: 0px; padding-top: 0px; padding-right: 0px; padding-bottom: 0px; padding-left: 0px; background-image: initial; background-attachment: initial; background-origin: initial; background-clip: initial; background-color: rgb(255, 255, 255); font-family: Arial; font-size: 12px; "><div><span class="Apple-style-span" style="font-family: verdana, arial, helvetica, sans-serif; font-size: 13px; "><span class="font-med" style="font-style: normal; font-variant: normal; font-weight: normal; line-height: normal; font-family: verdana, arial, helvetica, sans-serif; font-size: 0.8em; "><div><span class="Apple-style-span" style="font-family: verdana, arial, helvetica, sans-serif; font-size: 13px; "><div class="font-med-red-bold" style="font-style: normal; font-variant: normal; font-weight: bold; line-height: normal; font-family: verdana, arial, helvetica, sans-serif; font-size: 0.8em; color: rgb(255, 0, 51); ">The TT-01R Type-E features the following exclusive parts:</div><span class="font-med" style="font-style: normal; font-variant: normal; font-weight: normal; line-height: normal; font-family: verdana, arial, helvetica, sans-serif; font-size: 0.8em; "><ul>[*]Item 50746 CVA Super Mini Shock Unit Set[*]Item 50823 Glow Engine R/C TG10 Wheel Axle (2pcs.)[*]Item 50883 39mm Drive Shaft Set[*]Item 51023 Medium-Narrow Racing Radial Tires[*]Item 53673 Toe-In Rear Upright (TT-01, TGS)[*]Item 53471 Medium-Narrow 5-Spoke Wheels (Offset 0)[*]Item 53642 5mm Aluminum Ball Connector (Blue)[*]Item 53665 TT-01 Spur Gear Set (55T/58T)[*]Item 53983 Lightly-Tuned Motor (28T)[*]Item 54025 TT-01 Type-E Ball Bearing Set
</p>
</p>[*][/list]</span></span></div></span></span></div></div>
</p>
#6889
I just picked up a TT-01 today, used. Seems to be in good shape. The original Raybec Honda body is trashed. Seems quite brittle. Anyways, I wanted to get the HPI 200 mm Cuda body for it. Now I am not sure if I am looking at this right but if I get a set of 6 mm offset wheels to put on the TT-01 would that effectively make it a 202 mm chassis? I want to make sure the wheels can fill the body. There aren't any classic bodies out there in 190 mm. I want to make sure the proportions are good. Any thoughts on cool bodies that can fit this car?<div>Thanks</div><div>-Zack</div>
#6890
If you are talking classic like the VTA bodies.. the bodies are for a 190mm car.. with the wide rims from HPI that make the car 200mm at the rear and 190mm at the front..
#6892
Hi.<div></div><div>I have big problem with my TT-01 and ezrun 5.5T, since I fit this motor I can hear strange noise coming from motor, when is in free run or when I push car by hand or roll free.</div><div>This short movie will explain everything</div><div>http://www.youtube.com/watch?v=hAe5AWv-ph4&feature=youtube_gdata_player</div><div>All gears are perfectly fit I havn't got this noise with stock motor!?</div><div>Thanks for help</div><div>Regards</div><div>Pawel</div>
#6893
OH
not to sound like i'm hatin', but are you SURE that's the motor?.... sounds an awful lot like a gearing problem to me.....<div>
</div><div>with it being a brushless, you may have to resort to looking up warranty or getting a new one. srry.</div><div>
</div><div>however, i could be wrong.....(as little as that happens).....</div>
#6894
ME
Yeah, I'd agree with the above post. Sounds more like gear/diffs issue. If your certain its the motor, than its probably a bad bearing.
Does the motor work? Does it get hot?
#6895
Sorted! Thanks for help<div>
</div><span style="font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 11px; line-height: 17px; -webkit-tap-highlight-color: rgba(26, 26, 26, 0.296875); -webkit-composition-fill-color: rgba(175, 192, 227, 0.230469); -webkit-composition-frame-color: rgba(77, 128, 180, 0.230469); -webkit-text-size-adjust: auto; ">That noise is the strong motor magnets, in Ezrun 5.5T 6000kv motor.
</span>
</span>
#6897
My Feedback: (8)
NY
with the nice weather out i took out my tt-01 that i put a cc sV2 and cc 4600Kv last year. first battery in it and i hit a small bump in the parking lot which threw me into the air and a few flips later i broke the rear shock tower, first order to tower of the season is sooner then i had expected lol
#6898
Who said that the Tamiya shells were brittle??? They might be a little thin is some spots or I am just a real bad driver, HA! Running a 2s lipo, Reedy motor, bearings, drift tires, adjustable upper arms. For the money, these are a hoot!<div>
</div><div>
</div><div>
</div><div>
</div><div>
</div><div>
</div>
</div><div>
</div><div>
</div><div>
</div><div>
</div><div>
</div>
#6900
OH
yeah, too be honest i'm not entirely sure how you did that.....<div>
</div><div>sledgehammer? loL</div><div>
</div><div>just cause they're SOOO cheap, i use HPI bodies.</div><div>However, i cant say for sure about the bodies, but the tamiya cars are REDICULOUSLY durable....</div><div>
</div><div>I cant tell you the amount of times i have hit a curb went into the grass with my TA05 at 45+ mph and (after spinning madly through the air) and landing upside down without a scratch.... </div>
