Official DF-03 Ra Thread
#676
RE: Official DF-03 Ra Thread
Yes, they pop out no matter how i set the foam pieces. Doesnt matter if i try to over stuff it, and if its too loose they literally fall out.i probably screwed with it for an hour before i gave up. The angle is too much, the way they sit in one edge of the dogbone is ALREADY sticking out, it just takes a little pressure and it jams up and starts stripping gears. I nearly smoked my clutch by "just trying it". I think this thing never had the right bones to begin with, it was already seriously touchy when i got it. This things starting to piss me off TBH, one reason i never buy Tamiya. Figured this was above past experience, and reading peoples posts i assumed it would be a different story but so far its been more of the same. Kinda glad i never bought the VDF now.
Anyway, i still need to know how long the dog bone is so i can get a CVD. i think cramming in an oversized CVD will fix this problem, since its held fast on one end, so no spacers required on the other end. That will allow it to sit in slightly deeper, and move freely as the shocks actuate. ALSO it will improve the shock action as a hole, since the crappy way it was built if you over stuff it (which is easy) it will start interfering with the shocks normal operation.
#677
well i got the bones to look like they might not fall out... its pretty close though and if it binds my clutch can kiss its ass good bye. I had to screw with the suspension settings, and for the front i had to carve the hell out of the a-arms so the c hubs could sit at a larger angle. Before they would just limit the downward travel because they would knock up against the arms, i cut them up so that they dont touch anymore... took some work and my fingers are numb from shaving aluminum with my x-acto...
Also, i replaced all the arms with the plastic ones again. soon as i figure out where my battery cover went, i'll go test it.
#678
Can't wait to see how your increased ride height works out. Keep us posted.
I just received my Five Stars main shaft from Japan. It really doesn't look like much, but if it does the trick, I'll be happy. I haven't tried to install it yet, but I bought some plastic repair stuff from Magnum to try and fix the diff case so I'll be able to tighten it up a bit. I'll post if it works out or not. I was able to play with the car a bit last week, and it ran much better, but every once in a while I'd still hear a gear slip when I made a hard turn. This is still on a stock silver can, so I still kind of hesitate putting any real power in the car until I can get the gears running smoothly. With stock power, it's ok, but a little slow to be really fun.
#679
Ok, I installed the Five Stars Main shaft, and tried the plastic repair stuff on the threads in the gear box. The plastic repair stuff didn't really work, and the gear cover is still not as tight as I'd like. It's really nice how easy it is to get to the gearbox on this car. I'm used to having to tear a whole car apart in order to get to the diffs and main gears. I ran the car, but I think I'm going to have to re route my radio wires, because it's really glitchy. I don't think it's the radio or receiver, because I'd used them on another car before without problems. The car ran smoothly though. I am hearing another sound though. It kinda sounds like one of my ball bearings is missing a ball or two. I'll have to investigate further.
#682
I recently put a new Castle Creations Sidewinder SV2 5700kv system in my DF03. I also got a 2s lipo for it.
I ran it today on the street for a bit. I then decided to finally find a "rally like" spot to drive. I went to the park and ran it in the parking lot. It had some gravel, sand, dirt, etc. It was a blast!!
I use the Dark Impact body under my Subaru body, but I still noticed alot of dust got in. When I got home, i used my air compressor and it looked new again.
Also, would you guys recommend the slipper clutch on my car? What will that do for me?
Here are some pictures.
#687
ORIGINAL: SerpentCT4S
#689
My Feedback: (42)
MN
Hey all,
I got a question for those running castle motor's. I have the new sv2 sidewinder and 6900kv motor. I know the motor is a hot one and so I limited it on my transmitter to 65%. But my esc is running hot...not the motor. I am running a 23pinion and stock spur on 2cell lipo. I was planning on re-gearing but the damn motor is such a tight fit I don't think a smaller pinion will fit. Any idea's?
#690
Banned
MA
I suppose it wouldn't hurt to zip-tie a computer cooling fan on top of the SV2, and wire it to the BATT port on the receiver. I'm not surprised that a hot motor like that is heating up that esc since it doesn't have a fan.
#691
i got mine yesterday, put it together and took it out a bunch already. it's PERFECT for what i wanted <div>
</div><div>Soooo, happy! </div>
#692
<div>haven't painted the Evo X body yet, this is unfortunately my basher body.</div><div></div><div>then when i was cleaning up i noticed these F+3/R+6 chrome te37's soooo....</div><div>
<div></div><div></div></div><div></div><div>haven't glue the tires, doesn't seem to be an issue with the gearing i'm running.</div>
#693
Hi all!<div>
</div><div>I've been reading through this thread with great excitement - I have a DF03 ra on order, the 2008 WRC subaru.</div><div>
</div><div>Now I'm planning on getting a brushless setup in it, possibly an EZ run 9T, not sure yet. I'm wondering what the best hop up part would be? So that I don't destroy everything within 10 seconds of thrashing!</div><div>
</div><div>I've seen the carbon damper stays, TRF damper sets, aluminium this and aluminium that… What parts should I prioritise on getting? </div><div>
</div><div>I would appreciate any help, thanks! </div>
#694
Has anyone replaced the front diff yet? I just installed a new set of bevel gears front and rear and also cleaned out the front differential balls before reinstalling.
However the balls don't make contact with the plate. I ordered the DF-03 parts which should be the same for the DF-03Ra. I'm losing so much front end power that I can't even control it when I put on slicks to race around our local track.
What should I do?
Specs:
Sidewinder w/Castle 4600kv motor on 2S with proper gearing
Slipper Clutch/Heat Sink Bars
DF-03 dust sheild
I may also need to replace the tranny gears in the back since the top piece that holds all the gears/bearings in place came loose at one point. I just retapped them with longer screws and a little CA. (Seems like I need to rebuild the entire kit with the amount of bashing I've done lol)</p>
#696
IL
ORIGINAL: TimMc333
Hi all!<div>
Hi all!<div>
#697
ORIGINAL: The Mad Modder
For running brushless, you'll definitely want the slipper clutch kit.
Alright, the slipper clutch is definitely on my parts list. I've read that the steering is quite sloppy on this chassis, what upgrades would fix this?
<br type="_moz" />
#698
IL
ORIGINAL: TimMc333
<br type=''_moz'' />
#699
Well, the stock servo saver is a bit wobbly, an upgrade one would help.
<br type="_moz" />
#700
IL
ORIGINAL: TimMc333
Sorry, I'm very new to this: is there a specific item number or size of servo saver I would need for the DF03ra? Or just a generic aluminium one??
