Skygate/CARF Viperjet
#676
My Feedback: (54)
Faces into the relative wind. I run a 180 on this overflow.
This is my F-4. I run a 220 on this overflow. No issues or fuel starvation due to head pressure. I think it is only 6mm. I worried about having too small of overflow the first flight. Now I don't worry about it.
#677
Thanks, RCDan on how you prevented the syphoning effect, I appreciate your input from the real world of aviation on this.
#678
There are different ways that pilots tackle that issue. Several of us who are flying in Jet Aerobatics competition, use a method that we learned when we flew Scale Aerobatics and brought it over into the Jet world. It has worked perfectly for me during the many vertical up and down lines that we fly, during our various sequences. It may be to your advantage to at least look into it. There is absolutely no fuel loss at all during the entire flight.
Hopefully, it will work for you. The photo below will show the method.
Safe flying.
Wayne
Safe flying.
Wayne
Skunkwrks (05-12-2021)
#679
Thanks, Wayne for weighing in on how you have dealt with this issue of syphoning from the vent line. Learned from flying Scale Aerobatics.
Russ
Russ
sewbusy (05-12-2021)
The following 2 users liked this post by Dave Wilshere:
BlueBus320 (05-20-2021),
DenisFerrari (05-20-2021)
DenisFerrari (05-22-2021)
#685
At sea level, a lot harder at 3300ft to do........
#687
Hello to all Viper Pilots,
maidened my Viper (McLaren scheme) two days ago, after getting into jets on Xcalibur and Avanti XS before. Mine is powered with a KT160G4, Savöx SA-1256TG all around, except SV-1230 for flaps, Powerbox Mercury, stock tank and thrust tube. All settings are in line with the recommendations given in this thread, thanks to everyone contributing with experience and advice.
T/O and flight was flawless, no issues and only a few trim clicks required. However, on short final I switched to full flaps (70 - 80°) and in the same moment she got pretty unstable. This took my totally by surprise. I applied power and made a go around. The second approach was not much better and I hardly brought her back to the ground. It was an ugly landing (way too fast) and finally she jumped and came down on the nose first. Luckily, only the nose gear pin sheared off, no damage to the airframe thanks to the robust design! My impression was that speed is ok, but it looked like I was pretty close to stall.
I should have checked stall speeds first, but I have to admit that I missed that so I appreciate any feedback on your thrust settings with full flaps before I take her back in the air.
Thank you & regards from Hannover
Sven
Sven
DenisFerrari (08-06-2023)
#688
Sven, from what you are describing, you might have too much flap. That plane comes to a crawl and still does not do funny stuff. I would say either CG or Flap needs to be checked. Dave can pinpoint the issue better.
Behzad
Behzad
#689
Hi Behzad,
thx for quick reply. I will certainly double check CG and eventually go a little fwd to the save side.
I am also thinking of changing flaps control from 3-way switch to knob so that I can extend them in small steps and see where the limit is.
Rgds, Sven
Rgds, Sven
#692
My Feedback: (134)
Hi Sven, My guess is also that you have too much flap dialed in, at least for the way I fly mine. Have been flying mine for lots of years. Power is a 45lb Rhino and I fly mostly from a 400 ft hard surface strip. Can't remember my CG but its conservative. My flap control is via my left slider. Full flaps are set at 45 degrees with takeoff set at 22.5 degrees. At anything above takeoff flap setting I have crow mixed in at about 4mm up aileron and also have 2mm of up elevator. Flaps and mixes come on slowly. My landing procedure is to drop gear when plane gets even with me then go full flaps on the downwind wind and cut my throttle to 3 clicks off of idle. This leaves the plane at a slight nose high attitude which can be slowed way down without fear of snapping. Lots of ways to setup a Viper but this works for me.
Good luck. You will love your Viper
#694
I don’t see how too much flap is the issue…IF it was too slow than it lacked power.
First question would be what is the weight?
Second, where is it balanced?
My method and position is in this thread in the last few pages.
My guys fly with plenty of flap. I’m sure there are photos in this thread showing angles.
Dave
Dave
#696
I don’t see too much flap…maybe not enough power.
First question what flying weight?
Second Question what balance position?
My balance method is in this thread a few pages back.
This is not one of my guys, but the amount of flap we run….
DenisFerrari (07-09-2021)
#697
I have a little experience too. I think I have flown 12-15 Carf Vipers…you?
#698
Thx for all your feedback, much appreciated!
I did not put her on a scale yet, so I do not know the weight. But there is no unnecessary stuff in there, no smoke, no lead, small batteries. The only extra is the stock cockpit and a pilot. I balanced her acc. to Dave's recommendation, but as mentioned earlier will definitely double check before next flight.
I also first assumed that I had too much flap, as I was surely above the stall speeds reported here in this forum. There were no issues at all when I was on flaps 1. Also, I definitely had more than 3 clicks above idle when she started to dance. On the other hand, I have seen the pictures of several other Vipers with similar flap throw. This why I was asking for your thrust settings.
For the next test in safe altitude, I consider to put the flaps on a slider / knob so that I can adjust in case of any instability. I may also add crow mix, however this should not be needed on the 500 feet / 160m gras field where I usually fly. Elevator up / nose down was programmed.
It is truly a nice airplane and I am sure I will put many flights on her once I figured out the flap issue.
Again thank you & best regards,
Sven
Sven
#699
Hi Dave,
my flap throw looks pretty much as shown on the picture.I know it is difficult without knowing the weight, temperature, altitude but what would be your estimate for thrust setting in this configuration?
Referring to previous posts from Clavin and Skunkwrks, I forgot to mention that I was flying in 600+ m altitude. This will surely have an impact on max engine performance, but may it also have such a massive impact at landing config? During T/O and flight, I found performance was pretty ok.
Thx, Sven
Thx, Sven
#700
Sven
OK, yes, altitude will influence the wing performance a huge amount. We fly only 50m above sea level. CROW is going to reduce the wings lift, so I don’t see that helping you here.
Are you sure all your radio conditions are the same, you don’t have something changing at full flap? The way you seem to be describing the handling sounds more than stalling, normally even a tail heavy airframe is stable until pitched in someway by a control deflection
Balance was checked with everything in position, except wings removed and landing fuel in the main tank ( not full of fuel)
Dave
Dave
