#701
NC
RE: Welcome to Club SAITO !
That engine looks great! I like how you put the throttle servo right there at the engine. What benefits do you have.
It should be on the main page, there's alot of information here
~Michael~
~Michael~
#702
Just another quick question to you saito guys, at what price will the new Saito 125 come in at compared to the 120 for example? Will be be more expensive or cheaper andd by how much do you think?
#704
Where can I get some gasket material suited to make replacement v/c gaskets for my .91? It seems like such a wimpy little order to get from Horizon. ( oh, I ripped one that was heavly coked to the engine ) Gonna give it the crock pot cleaning.
thanks, BL
thanks, BL
#705
CT
I have a Saito 91 GK to put in my Venture kit as soon as I finish my telemaster.On my last 91 I could not keep a spinner on it.It would get started and than trow it off,how do you deep this from happening?I used a heavy hub and never had a problem only with the spinner.
#706
BL:
I don't know if the particular brand is available where you are, but "Vellumoid" 1/32" gasket paper works fine. If you can't get the Vellumoid you want a gasket material that is impregnated, it looks like very thin linoleum. Plain paper gaskets don't work well there.
Dave:
You didn't specify what spinner you're using. I've had no problems with the metal spinners using a central retainer screw, Tru-Turn, SpinRight, and so forth. At the same time I've not had good results with plastic spinners on a four stroke.
Can you give a little more information?
Bill.
Dave:
Bill.
#707
CT
I do not remember the names,I did try different ones including the ones that came with the kits,I did'nt try the meals ones I will try a true turn on the next one.I do like the Saito one fine engines with great sound and performance,I had it on a 4*60 and than on a venture which is why I have another venture with a few more goodies to put in it.
#709
CT
Almost forgot I even had an old timer put a jam nut on too no luck.I'm just trying to think ahead,the GK might not even have a problem who knows
#710
NC
What prop for a Saito 100 on a Funtana 40. This thread goes by so fast, my post is way back a page.
Thanks for the help. Like I said I have a APC 15x6 right now.
Any suggestions
~Michael~
Any suggestions
~Michael~
#712
OH
Bill,
Is there any of the automotive type RTV sealants suitable for gasket replacement?
Thanks!
JLK
Oh, I had great luck finding what I needed from Paul.
Thanks again!
Thanks!
JLK
Thanks again!
#713
Bill
RE: Vellumoid for gasket material. After researching the product, I only find it available from Industrial Material suppliers , nothing relating to say, Lowes, Home Depot or any automotive parts suppliers. Can you think of a possible substitute ?
thanks again , BLdrums
Charlottesville, VA
Charlottesville, VA
#714
Rob--RCU:
You are now on the list as number 110.
JLK:
Any of the automotive RTVs will work on the Saito engines, except on the exhaust piping. Gets too hot. There is a high temperature version that might work there.
There are two places where the Saito has to have a gasket, whether you put RTV on it or not. One is the cam box; the thickness of the gasket sets the lash in the timing gears. The other is the rocker boxes. To clarify, I don't know that they will fall off without the resiliency of the gaskets, but I think the heat/cool cycles would make the screws work loose. If you try it and it works with no problem, please let us all know.
Thanks.
Bill.
JLK:
Thanks.
Bill.
#715
Will the gasket in the cam box hold up ok when cleaning the engine in a crock pot using antfreeze at low temperature?
( this new thread is really keeping
you busy isn't it ! )
we appreciate you, thanks
BLdrums
BLdrums
#716
BLD:
When I was living in Virginia Beach, there were three places in Norfolk where I could get the Vellumoid products. Since that's a 300 mile round trip for you I guess you wouldn't want to make it just for a $2 pair of gaskets.
Fel-Pro also has sheet material available, that shouldn't be too hard to find, even though you might have to ask it be ordered.
If you can only find the plain "Paper" gasket material in a 1/32" thickness, take a piece large enough to cut your gaskets and smear some RTV on it, and rub it in as well as you can. Do this on both sides, let it dry, then cut the gaskets from it. I've done this in the past as a "Quick and dirty" replacement for the rubberized paper, it does work but it's messy and smelly in the preparation. Just be sure it IS gasket paper, and not ordinary paper.
Bill.
Bill.
#717
I remember buying Perfect gastket material at the hobby shop. I wonder if they still sell it, or if there might be a package hanging around somewhere in some corner of you LHS. Would that type of material be sufficient, do you think, Bill?
Just a thought,
Bob
Just a thought,
Bob
#718
BLD:
I've never seen a gasket that would hold up if it is open to the antifreeze, but if the cam box were left in place with the screws tight it should be OK. On the other hand I wouldn't consider doing the A/F Pot thing to a Saito without pulling the cam out. I'm just not comfortable with the thought of getting all the A/F out after soaking it. Besides, why would you be going that far if you aren't replacing the bearings? And that means re timing the cam anyway.
When you strip the engine the cam box gasket usually comes off without damage.
Bill.
Will the gasket in the cam box hold up OK when cleaning the engine in a crock pot using antifreeze at low temperature?
Bill.
#719
Bob:
Those old "Perfect" brand bags had almost anything you could think of in one or another.
As near as I remember the "Perfect" gasket sheets were impregnated, but memory also says they were thicker than needed for the Saito rocker boxes. But thicker shouldn't hurt, it's just that the thinner material is easier to cut cleanly.
Bill.
Bill.
#720
Michael, have you tried an APC 15 or 16x4W prop on your 100? If you are flying the slower 3D moves rather than pattern style I think you would like the pull of these props.
Ernie
Ernie
#723
KY
The reason I put the servo there is because it was easy. It was a lot easier to run the servo wire than to try and use some kind of linkage or cable.
#724
WA
ORIGINAL: William Robison
Rob--RCU:
Rob--RCU:
#725
Please add me to the list I have
40a in bristol scaout
56 in a box
82a in sensation
100 in shestring
100ti in super sterman
Lars Lindström
56 in a box
82a in sensation
100 in shestring
Lars Lindström
