Nylint 1/6th scale Rock Crawler
#51
NC
RE: Nylint 1/6th scale Rock Crawler
ORIGINAL: MARGRETTE
I just ripped my whole vehicle apart for my build-up...I will snap some pics of the wheels tonight.
#52
minor stuff for now...cutting and narrowing the body, new skid plates, new steel roll cage, not really buying much for now...guess its not a total build up...sorry for getting too many hopes up. am planning on strengthening the axles and upgrading the belts though using cleffdawg's idea (prev. page)
other than that, mostly cosmetic stuff, lights, paint, etc...just trying to make a mini version of my real crawler...I will throw some more pics up when the little one is finished, for judgment on how I did. For now, here is one of the 1:6 fresh out of the box, and a couple of my real crawler "Sherman"
If you do this you'll have to cut off the suspension stops from the chassis. As far as the guy who lost his front wheel drive i had this happen with both axles. There is a small plastic peice on the axle that is supposed to turn with the axle. In other words it's supposed to be attached. I beleive they did this with a small pin through the axle but it is weak. I drilled another hole in the axle, through the plastic peice and JB welded the @%$ out of it. it holds great now. Another problem is the belts they use. I replaced mine with some O'rings and they work spectacular.
#53
How does the Nylint 1/6th rock crawler compare, performance-wise, to the New Bright 4WD Jeep rock crawler? Is the Nylint worth the extra $100?
#54
WI
ORIGINAL: MARGRETTE
#55
My Feedback: (325)
does anyone use a different tx with the stock truck? I want to know the channel? freq?band?
All I know is it is 27 mhz and has 4 different bands (channels)?
#56
IN
You could probably put hobby grade electronic in the 1/6 scale one. I have an old radioshack dodge raminator and I tore it completely down today. It now has 4 rustler shocks, a 27 turn midnight pro motor, futaba magnum jr. radio system, novak fwd/rev reactor speed control, and the rear diff is locked! This thing is about 3 times as fast now. I might be breaking 20+ mph on a full batt! I hit my bike ramp at pull speed on our asphalt driveway and when I eventually came back to earth it slammed down and I pressed the throttle back as hard as I could and managed a sweet slap wheelie! I had to press the brake and bring the front end back down befor I hit the barn! This is one tough truck! Sorry about rambling just tried to give an idea! I also put hobby electrics on my beothers 1/6 scale Ford Harley Davidson truck!Very fast now! Just some ideas![8D]
#59
PA
What would you rate this truck on a fun-factor of 1-10. It looks like a pretty cool truck and a good buy fro the money.
All the owners of this truck, please post some pics/videos when you can, I would love to see this thing in some more action. [8D]
#60
CO
I just bought the 1/6 Nylint and plugged in the battery and took the thing apart. You can put a hobby grade radio in it but you need a three channel radio or at least two channels and a swith to switch from high to low gear. I took the gearboxes apart and was pleasantly surprised by the metal axles and the ballbearings. How many R/C kits can you buy that have ball bearings on the axles? The wheel do have a hex but they look like 6-7 mm hexes. The gearboxes are NOT sealed so I wouldn't run them in mud or water.
Other than a paint job, I'm probably not going to mod the Jeep.
Much.......
Any gripes? Please......it is not a Clod so there has to be some compromise for the price. But for what it is it's great!
BTW there is a video of the Jeep at www.funrise.com
Much.......
#61
ORIGINAL: Pede guy 9114
#62
sorry it took so long to get em up, but here are some pics of how the wheels mount up. Newbie, so not sure how they are sized, but looked like just over 3/8", maybe 10mm (?) hex, with a keyed hub held in by a plain-jane flat head philips machine screw.
ORIGINAL: hpiguy
Thanks, those pics would be appreciated.
#63
CO
Got a question, Some of the suspension components are held on with what looks like rivets. What are they? Are they press in rivets or one way screws or what?
How do you get them out?
#64
ORIGINAL: RC-Archer
#66
OH
OK, now this 1/18 one isn't that great.
there is no proportional control for the steering OR throttle (don't know why I expected different), and one good fall knocked my front right wheel off.
it's got potential, though...i'm gonna tear 'er apart tomorrow since I'm off school.
#67
I have had my 1/6th scale for a few months now. So far, nothing has broke. Like it has been said before though, the steering needs to be stronger and the clearance under the axles is less than par. The Jeep is capable of much more than the clearance allows for.
#68
Im new to the rc hobby and purchased the 1/6 crawler last night from walmart. Ive seen some great paint jobs here, what kind of paint do you recommend. Thanks...Jeff
#70
Thanks....i will get some krylon...im luvn this rock crawler and the dvd that came with the jeep is great....this rock crawlers must be popular i went back to walmart to purchase one for my brother for christmas and the were sold out and I had just purchased mine the night before...but i did get it right when it was coming off the truck....
Now for a good color scheme...
Thanks again...Jeff/Mansfield, TX.
#71
Banned
My Feedback: (7)
nylints are junk alright, if your gonna pay 180 bucks for a non hobby level rc crawler then your jut a *****, afraid to build a real crawler, i can see 40 or 50 bucks for the smaller one just to fool with and have a little fun but ive owned the bigger one and they are horrible performers, i described this on a earlier thread, they are crap alright, to spend 180 bucks on a walmart car is stupid and you are stupid for doing it and not taking it back,
and then you saying that you could put hobby level electrics in one of those, WHY THE HELL WOULD YOU DO THAT, why would you put more money into that piece of junk, they will never perform as well as something hobby level, they are junk and you are supporting junk by paying 180 dollars, dont support those pieces of crap, you can build a nice competition capable crawler with only 280 bucks, if you want to know how i will gladly do a big long list of everything you need and everywhere to get it, josh
#72
MI
it seems like most people are more than happy with them. And as far as building a competition crawler, these trucks are more for the scale look.
#74
ORIGINAL: jkrustchinsky
#75
My Feedback: (14)
NY
well I geuss I'm stupid, I bought the 1/18th for my son and the 1/6th for myself! X mas was a blast. I bought this thing to see if I would enjoy crawling an rc vehicle. I used to wheel and rock crawl in my Toyota tacoma until my little ones were born. The 1/18th is great for my son to learn on the TX is just the right size for his little hands. He is only 2 and drives quit well for his age( Still doesn't know about reverse) he always loves rc stuff especially my nitro ones, and planes. well I sure wish I could see a list of things to build a crawler for 280.00 I think I will build one more capable than the nylint once it breaks.
Bill
Bill
