I need help
#51
Hydro Junkie,After reading your thread about redesigning this kit I'm tempted to get another kit and start over.The only thing stopping me from doing it is that I don't have the tools to cut new parts and I don't have patterns for the new parts.Also,I don't have the tools to make new machined engine mounts as well as the other metal parts.In your thread you mentioned several times the Newton Pak color sheet,where can I find this?Let me know what you think about me getting another kit and what to do about the re-designed parts.
#52
Sorry it took me this long to get back to you, been mulling this one over.
What I would recommend, knowing you have limitations would be the following:
If you decide you want to start again, you can order the plywood and spruce sticks at Aircraft Spruce:
https://www.aircraftspruce.com/
Just remember, this is your choice. I'm not going to tell you that you have to start over because of this or that. Your boat should run the way it is but won't be up to being used as a race boat.
As far as the Newton color sheet, it was part of a three sheet set that was drawn by someone I tend to think of as a mentor, Roger Newton. Unfortunately, Roger passed on several years ago due to cardiac issues. His son has been selling plan sets and single sheets there of for 1/8 scale boats ever since. Here is the link to that plan set on their website:
Newton Marine - The Best Source for Scale Hydroplane Plans
Contact information is on the home page, just click the left most tab at the top of the page linked above
- If you want to start over, feel free BUT don't try to take your build to the level I did with mine. It takes a good amount of experience with the boats to do all the redesigning I did
- If you do decide to start over and want to make it out of better materials, use the kit parts as patterns
- I would make only one real change to the boat, move the joint where the bottom panels come together back to frame 6. This will require the bottom of the frames 2-5 to be raised between the sponson insides to allow for the different bottom profile. It would also require changing the shape of the engine mounting blocks. Otherwise, the frames would be the same as you had for the kit build
#53
Hydro Junkie,I decided to put the drain tubes in by the transom and in the engine bay,put the clear cover on the servo part and get the new propeller then sand seal and paint and see how she runs.Questions:you mentioned a 4-40 threaded insert,should I put that in the 3/16" brass tube?How long should the brass tubes be?Should I leave the radio tape on the clear cover when it's not being used?I'm getting ready to get a starting belt and I was wondering how long it should be?
#54
For the ones at the back of the boat, just long enough to get through the transom. As for the drain for the engine compartment, flush with the front of the radio box outer face and angled rearward as you see fit, again being flush with the bottom skin
