Official HPI E-10 Thread
#726
Hey guys i am new on here i recently got a e10 hpi car. i have a link to the exact car i got down below. i am really enjoying the car i and just wanting to upgrade the motor in it. I am very new to the RC world and dont know much.. i am really jsut wanting to make this car very fast with the minimum amount of work. i was just planning to upgrade the motor system to brushless first and go from there. i really am not trying to go crazy on price but i do want it to be very quick. i just dont know what motor would be best for what im looking for and do i need to just get a moter or do i need a motorand speed controler or will my stock one work with a new brushless motor. would it be bad if i jsut stuck a new motor in it? i am pretty sure it is a 540 can motor sizebut is that all i need to know when buying a motor? which motor would you guys recomend and if needed what speed controller too? thanks
#727
this was the motor i was looking at getting any opinions?
http://www.ebay.com/itm/Trinity-Spee...item1e80e37da6
#729
Hey m8,
To run a brushless motor u will need a brushless ESC and ideally lipo batteries.
to do it on the cheap with great reliability get a Hobby Wing Ezrun 35a 4300k combo.
On a 2s lipo its going to be way faster than stock and on a 3s lipo it will be mental.....
but on 3s things will start braking or wearing out excessive fast and the cars handling limits will make it hard to drive.
for brushless u really want to fit some ball bearings, alloy main shaft, HPI CVD's, oil filled shocks, and the metal pinion mod to both diffs and shim them.
#730
QC, CANADA
Hey guys, I'm at a friends house and he's looking for a rally car, preferably 1:10 so he can get the body he likes. We want to know how much of the brama 10b will fit on the e10? We heard they share the same chassis.
#731
from what ive seen they don't share much at all... its very similar, but different in some way. I think they share is the diff's but even then its a different diff housing.. oh and I think they share bellcranks and battery holder
#732
But make it into a rally car?
the Brama 10b was insanely brittle too honestly if you want a rally buy a Tamiya as for how much you will be flushing down the toilet in parts every time you run it you would pay a Tamiya off in 10 runs..
#734
Even the TT01 I've hit cement going damn near 40 made it fly 3-4 feet into the air from the hit, and land on its tires with no damage lol
The rally was the DF03RA
#735
QC, CANADA
He installed a vxl with lipo and somehow hit a tree after launching off a ramp, bad 1st test run lol. Wish I was there to see it. He said the chassis had hair lines in it and when he pushed it it split. The other chassis was an old s10 he got used, it's got a 10t brushed motor and a lrp. Landed off a ramp and cracked at the front.
#736
Just for the record not many RC's would survive that 1st example even ones with aluminum chassis plates would bend if hit good enough
#737
Ok, I just picked up an E10, and now after the fact trying to look at upgrades for the Spur and such, I find that everyone says the E10 is crap...
I can only find that it has one stock spur spec plastic, and it says it isn't 48 pitch, some odd metric .6, so there is no changing pinions ?
The car I have picked up is mint, looks right out of the box with very little run time, with Stock 27 turn motor, stock everything...
So I guess, what I am needing to find out is do I really need to waste time putting any money into this car, or just trade or sell it for a
TC3 TC4, or maybe TC5 which has better upgrade options,?
New to street here, and just looking to bash for the moment, but there is a local track that runs, so if time permits, racing could be down the road...
I have read some threads about the aluminum upgrades for motor mounts, and one possible metal gears for the diffs, but if this car
can't be upgraded to brushless, it looks like it isn't worth putting the money into... All ideas and input is appreciated, thanks...
#738
The Associated TC's would probably be better out of the box(and even after TT01e upgrades)
There is also the Ofna JL10e which is what I would buy if I bought another on-road as its pretty cheap, and looks well made.
As for pinion... you can use Tamiya pinions on the E10. Upgrades are slim to none outside the propeller shaft...
#740
I've found plenty of upgrades. I'm not sure where you got slim to none from.
http://www.rcmart.com/advanced_searc...pi+e10&x=0&y=0
Here is a whole page of stuff. Just the first one on the page will change damn near the entire suspension and steering parts. Then there's adjustable shocks and locked diff gear through HPI. From there you've got dozens of wheel and tire choices.
About the only thing I haven't found for mine that I want is the front one-way differential as its been discontinued. I'm sure one will pop up out there somewhere on the internet.
Not a bad place to start for a drift/on road RC car out of the box. Not sure if he's trying to slide or not, to me it seems like he just wants it to go fast on-road which can be counter to drifting on-road. They say this car can go either way but I feel its focused more towards drift.
#741
As u can see from the first 1/2 of this thread I fitted a lot of upgrades to my e10..... It was never really that good. And I ended up selling it.
sure it could drift in carparks but on a track it was hopeless, it just didn't have the pull u needed, I found it would drift way to wide and did not like changing directions.
im now running a old HoBao Hyper 10e, and the difference is night and day, because it's so easy to drift it makes me look like a pro at the track... Lol
i sware drifting has more to do with the setup than skill.
if ur drifting with a front one way will make it harder....sure it will give it rear brakes only (handbrake style) but it will essentially lock the front diff under acceleration... I find a loose front and a lock rear is the best.
#742
Thanks for the replies Crawler and Maximus, and yes I did find some upgrades on ebay, just meant that the model is older, and not like a Newer TC5 or 6.0 with more recent turn outs of upgrade products,,,
Basically what is left out there will be it,,, Sucks getting older,,, lol... And yes, mainly looking at road coarse racing not into Drifting... I have picked up some extra pinions, backup spur, and Alum motor mount, so far,
now gotta get a alum drive shaft, and time to get it all installed and tested out... Trying to get my shop setup, so it isn't such a mess working with all my different projects,,, I am sure it will be a decent car for beginner
learning on the street...
#743
The e10 is a epic fail. It's got quality and design issues. It doesn't matter if u are a beginner or expert. The design flaws don't discriminate.
Personally i I wouldn't recommend a single upgrade. Sorry.... I use to love mine.... But not I hate it with a passion.
#745
Personally I thought he design was superior to tamiya's, but the quality severely lacked.
#747
Did some lighting on the body. Picked up Yokomo S13 light buckets and did some slight modifications to get them to sit in the ABC body. Who knew this thing would take so many lights? The control unit I got runs 10 LEDs and I'm still missing 10 lights on the car, the corner markers up front and another 8 in the tail lights.
#749
Most 195-200mm bodies can work I believe. ABC Hobby has nice quality bodies. Just check the wheelbase spec of the body your interested in and the spec of the chassis (I can't remember it at the moment). HPI website has the wheelbase dimensions listed.
