Top Flite B-25 ARF (Tecnical, tips, suggestions)
#751
RE: Top Flite B-25 ARF (Tecnical, tips, suggestions)
Europact.
Page 19 posting #452 and page 23 post #575 of this thread will answer some of your questions. I have flown this plane 5 times so far, would have flown more but we have a record snow falls so far and so much... for the props go back to post #11 page for different engine setting. The only thing I must add is that the CG should be made gears up if you intend to use retracts and heavier wheels. When the gears retract the cg moes aft significantly enough to make the plane tail heavy and become unstable. Another Gremlin is the servo hatch for the ailerons and flaps. They need to be reglued and you may put some 2 sided tape to secure your servos. This is only minor details that could be overlooked by some but i think should be adressed.
#755
Does anyone have any ideas on how to get the fog left by ca off the plastic tail gunners window? I tried one brand of ca remover and it made it worse.
#759
I just found out I am missing the elevator joiner wire. Anybody else have this problem? Where was it packed in the kit?
#761
Thanks. I looked again and everywhere else in the box and no luck. Also I can't get my servo extensions through the plastic tube with the heat shrink on my connections. The rudder extension came up about a foot short. The manual says to connect a 24 inch extension and the elevator has a 36 inch which works fine. I guess I will add a 12 inch extension to the rudder so it will reach. I will probably add a bigger tube since this one is to small.
#762
You can fish 2 48 inch extention through the tube with the connectors shifted by 1 inch, it makes it to the back easy.
#763
MI
more pics of bay door using nelson hinges. guys on the jet forum are telling me how to use air cylinders to run them, nice bunch of guys!
#764
I bought what the manual said to buy. I am not going to go buy a 48 inch extension. The heat shrink material is the problem. One connection by itself will not go through the tube with the heat shrink applied to it.
#765
If you are a competent solderer, just splice 48" into the servo lead - no plugs, no worries. Done right, it's more reliable, lighter, and in particular skinnier!
Hobby shop called today - it's FINALLY arrived.[sm=teeth_smile.gif] This will be the first shipment in Oz I believe - any other skippy's out there got one yet? Robart air set from Tower still on backorder though - anyone else have this problem??? Anyway, time to clear off the bench (and yet another 1/2-finished scratch build...) and have some fun.
Cam
Cam
#767
MI
nelson hobby 1/2 inch they are the best. here is the scale maechanism to open and close the doors one side already works great . Im sure ill have to fiddle to get the other side to close but thats ok. the servo is mounted to the other side of the bulkhead and moves the cam as per scale/ this will get covered up with a scale fitting. I had to move the n ose wheel servo up a little and ill refit that as soon as the doors are done
#768
Tim,
Seems like you decided to go with a servo... Good call I' using a JR791 retract 260 oz servo for my bomb bay. It sounds like the real thing. I am using 2 bell crank with a wheel on the servo positioned in the middle super adjustments capabilities and scale operation. A servo in the back may be needed in the back also because the closing there is weak and may shake and shafe excessively in flight. Pics wiill be coming soon, my 7 year old daughter decided to bath with my camera!!! That is fun.
Norm
Norm
#769
Tim,
Can't help noticing your gear door, did you cut the door and install a sequencer to close the door when extended?
#770
MI
thats the plan ems jomar sequencer i still am tweaking the doors for a nice fit/ takes time. well ive got the doors done! heres the proof. tomorrow ill reattach the nose wheel steering and work on the sequencers for the gear doors. the doors do not open as much as the full scale but im happy with them and they close so nice and perfect. The more i fiddle the more apt to mess it up!
#771
MI
electrics dont vibrate like glow so im not too worried. those doors are on to stay . ill pop a ball link if anything. ill drop the doors at slow speeds. 16 lbs need outer wings and lipos. she will be close to 20 lbs. my electric 310 is 22.6 lbs and she flys great so weight isnt a big deal
#772
Has anyone out there tried running an OS 70 ultimate with flexible pipes instead of the mufflers supplied, if so does this have any detriment to power?
#773
Nice job on the gear door Tim, but hurry to cover those electric motors! (you know my opin on those...)
#774
MI
oh dont worry i need a ball driver to remove the cowls and will get the radials on. Heres my new problem. I can fit 7s each side in my batt compartment. I really would like to make a short charge plug where i could recharge the batts without having to remove them. i can do this by making a short pigtail and y off that so i can charge the packs individually.
taking those batts out all the time will break details so i know saftey gurus will cringe but ive been using big lipos for a while and can correctly charge them.
#775
You gotta be careful charging lipos in or out of your plane. So tell the gurus that you may set a fire in or out the plane if one dont know what he's doing. The fire will still be set in the house!!! So if i were you i would install the pigtail and monitor the charge...
