Skymaster 1:6 A10 Build
Old 07-30-2019, 07:47 AM
  #801
DHC6
DHC6's Avatar
Originally Posted by JJP
I am curious now as to the actual capacity of the fuel tanks on the skymaster A-10. Does anyone know? Or the difference between a dry weight and the wet weight would be helpful. I just need the total weight of the fuel load.
Each tank is 4ltrs, so 8ltrs total of fuel.
jnayjaso (04-05-2020)
Old 02-18-2020, 11:18 AM
  #802
Dave Wilshere
I’m finally back on the A-10. The factory hand ‘hacked’ the pod inlets ( actually a little over trimmed since the dumpy fans already leave a gap on the mounting lip) I decided the only way to sand flat was make this, it needed flats to get through the former. Quick spin in a drill and done.
Old 02-18-2020, 11:25 AM
  #803
JJP
Originally Posted by DHC6
Hello guys,
I am concerned about the weight if my G2 A10. Dry weight is 68lbs, and about 74lbs with fuel. Mine doesn’t have an stores, but has the rest of the scale details. It’s got plenty of power, I’m using ATJ 140s, so power isn’t an issue. I’m just concerned with the all up weight? Should I be?
I have the same A-10 and my all up weight is 74.3 lbs with fuel no ordnance. It fly's great and has stood up well. Having said that I do inspect the plane prior to every flight for signs of fatigue.
Old 02-18-2020, 11:40 AM
  #804
DrScoles
My Feedback: (18)
DrScoles's Avatar
wow, 75 pounds! What turbines? Mine is sitting on a rack taunting me... too many other projects in front of it
Old 02-18-2020, 11:42 AM
  #805
JJP
I am using Jet Central 140"s.
Old 02-18-2020, 12:17 PM
  #806
Dave Wilshere
I have saved a tonne of weight in the pods, I expect it to save a lot of nose weight. Using JetCat P-130RX, so over 300N will give the A-10 some performance. Had Grumania make me some tail pipes rather than use the restrictive originals.
Old 03-15-2020, 01:31 PM
  #807
Dave Wilshere
Finished lining up the tailpipes. P-130Rx mounted on composite balsa rails.
Old 03-15-2020, 07:52 PM
  #808
DHC6
DHC6's Avatar
Mine is also the same weight and it flies very good. I’ve had a few less then perfect landings (down to Cg I think) and it’s held up very well. I feel the heavy weight of mine might be due to heavy turbines which needs more weight up front to counter act the heavy turbines. That being said, it really does fly just fine at that weight. Mine is powered by ATJ 140s and I never feel that it needs more power.
Old 04-04-2020, 12:38 PM
  #809
Dave Wilshere
Decided I couldn’t live with the gap on the fan install-when I looked I needed to sand even more to remove the rough cut inlet lip. Why the factory can’t leave the lip much larger so it could be trimmed to match the fan housing. Decided to fill and paint the void...joy!
Old 04-04-2020, 12:40 PM
  #810
Dave Wilshere
I also finalised the tail pipe mounts so I can get them in and out.
Old 04-05-2020, 05:16 AM
  #811
Mikey5547
Looks good Dave, the A10 is very nice project, please keep us updated on it
Old 04-05-2020, 05:25 AM
  #812
Dave Wilshere
This one should at least be lighter than most. I’m saving everything I can at the rear end to save weight needed in the nose.
Dave
Old 04-05-2020, 06:19 AM
  #813
Mikey5547
Dave
please let us know the weight when you are finished. Is this the G3 version?
Old 04-05-2020, 06:35 AM
  #814
Dave Wilshere
I got the kit end of 2017. Not sure what that makes it!
Old 04-05-2020, 09:17 AM
  #815
DrScoles
My Feedback: (18)
DrScoles's Avatar
Please keep posting! I've got one on a shelf, your pics are good motivation for me to get started!
Old 04-05-2020, 09:32 AM
  #816
Mikey5547
Maybe G2. I’ve asked Anton with the difference is between them but haven’t heard back.
Old 04-05-2020, 10:06 AM
  #817
Dave Wilshere
It’s not light, but also does not scare me when I pick bits up!! Paint chips easily, there is a lot of excess resin in certain places, I’ve cleaned as much away as possible.
Old 04-09-2020, 01:50 PM
  #818
Dave Wilshere
So pod finally finished after having to move the two turbines back...seems SM wood work position varies, so don’t mount the starter too close to the fan until you check the other pod!
Finished weight of the pod averages 2473g ready to fit.
Old 05-29-2020, 06:14 PM
  #819
AKB
Don't mean to hijack the thread, but those of you that contribute to the thread, would probably know. I am trying an experiment this year with Skymaster A 10 wheels and brakes on Mibo A-10. When you fellows mount your tires on the rims do you glue them on and if so do what glue do you use.
AKB
Old 10-18-2022, 05:02 AM
  #820
leventx
Skymaster latest version A-10 with two T16 turbines, Futaba BLS 177 servos , 2 x 500cc smoke tanks , 10pcs lights installed, take off weight with all tanks full 30-31kg
Old 10-19-2022, 04:40 AM
  #821
Dave Wilshere
Have about 2 hours on mine now.
Old 10-19-2022, 06:39 AM
  #822
DrScoles
My Feedback: (18)
DrScoles's Avatar
I have a gen 1 kit. I have the nacelle mod, but wasn't there something about the elevator attachment needing reinforcement as well??? Obviously don't want to add weight back there, but don't want the tail flying off either!
Old 10-19-2022, 10:40 AM
  #823
Dave Wilshere
From memory the failures here were more the tailplane folding, so the spars were capped from within the servo opening
Old 10-20-2022, 06:29 AM
  #824
DrScoles
My Feedback: (18)
DrScoles's Avatar
John from Skymaster got back to me and shared pics... as did some others farther up in this thread..... I finally read through the whole thing!
Old 11-27-2022, 07:46 PM
  #825
gonzalom
gonzalom's Avatar
New fans we did for my A10! The quality is superb and I already got 20 flights with no difference compare to the original fans.
