Reaction 54 Jet Kit
#801
AB, CANADA
The 54 is aerobatic like pattern ship...actually, very much like a Kaos. I'm pretty sure it would do rolling circles - pilot skill permitting - however, if you flub the manoever, you can't just blast out of it like a prop plane ...no propwash over the tail feathers!
Also you would have to burn a lot of fuel to make up the price difference between an MW-44 and a P60, MW-54, PST, etc......
#802
ORIGINAL: Goekeli
Thats cool of you Bruce. Can you describe the dimentions of the 44 size that man is working on? I'd like it half the size of the R54 as the 44 puts out 32N and or about 7lbs.
Joe Kelley
Joe Kelley
But something like 75 to 80% scale would be about right.
To have the smaller one have the same visual "feel" as the big one, it wants a somewhat lighter wing loading, but having it feel a bit hotter would be fine, so you could even be able to go down to 70% scale (half the wing area).
Bob
#804
ORIGINAL: A10FLYR
How about those of us stuck with the larger turbines?
ORIGINAL: Ron Stahl
I have been toying with scaling the drawings for a small one say 30% for EDF power and a bigger one 125% myself for P-120 power.
RH
#806
[/quote]
No problem for me![Big Grin](images/smilies/biggrin.gif)
[/quote]
That is some jet hauler. It reminds me of my younger days although you probably got four/five feet extra on me. I use to carry five airplanes when I went to the flying field, two D/F's (Byron Kfir and Parkenson F-86) and three prop's (Nosen 9' trainer, MIG-21 and Kyosho twin). Now I complain about getting one in and out of the back of my pickup.
Roy
Ask me about disposable income; I fly R/C jets.
No problem for me
[/quote]
Roy
#807
Bob,
I think that 82% would be about right. Sensible weight saving and it should have the same wing loading as the R54.
I will find out soon!!!.
82% R54
Wing Span 64"
Length 66"
Approx wing Area 1050 Sq"
82% R54
Wing Span 64"
Length 66"
#809
My Feedback: (18)
Tom, your on the deal now mate. That 82% is a good number. 1000 sq and under 5k would be great. Preferably 8lbs for me. This design really grows on me. It looks like an old CL model. If I build one I might look back for a scheme from the past. I loved there look! You guys still have a fire ban?
The 120 version sounds neat too. My, talk about a floater!
Joe
Joe
#810
Dean, you want an enlarged R54? I'm surprised you don't want to strap two turbines to the top of the fuselage, A-10 style ![Smile](images/smilies/smile.gif)
Believe me, I've considered reducing and enlarging. It's a nice, solid design that would do well at any size. The problem at my end is time (the lack of it!).
FWIW, I think Bob Parks is right on in his advice, as always.
#811
ORIGINAL: A10FLYR
Molar,
Looks like a mid 70's Ford. I started with a '64 Ecnoline. Then a '76 E-150, then a '90 15 pas club wagon, then that '99 15 pas. wagon. Great, reasonably secure, plane haulers.
Molar,
It is an early 80's Dodge and after the wife complained about fuel smell, I bought a extended cab long bed P/U with topper. I built a rack out of garage door rails so I could slide planes and large wings (like the Reaction 54) in and out. Wife is now happy and I had more access as well as enough power to pull a 24' camp trailer to go to all the jet meets.
Roy
#813
ORIGINAL: BruceTharpe
Dean, you want an enlarged R54? I'm surprised you don't want to strap two turbines to the top of the fuselage, A-10 style![Smile](images/smilies/smile.gif)
There are lots of the larger turbines out there. So I would guess there would somewhat of a market, something to consider. At least maybe marketing just the plans.
#814
ORIGINAL: Molar mender
Dean
Roy
Dean
Roy
After the wife complained about fuel smell, I bought a extended cab long bed P/U with topper. I built a rack out of garage door rails so I could slide planes and large wings (like the Reaction 54) in and out. Wife is now happy and I had more access as well as enough power to pull a 24' camp trailer to go to all the jet meets.
But just think of all the excitment you are missing by not driving one of those dangerous vehicles that are just a rollover waiting to happen! I've been closer to rolling my wifes Escort than I have in all my years of driving a van.
Great idea using the garage door rails.
#815
Hi Bruce
I'd like to share the method I used to install the leading edge sheeting on my R54.
The first step is to apply medium or thick CA all along the balsa quarter round leading edge and glue the front of the leading edge sheeting, don't force the sheet down on the ribs, leave it at an angle which will best fit the quarter-round. Use masking tape for a better fit but remove it as soon as possible, it will be too hard to remove later.
Spray some Windex ( the one containing ammonia works best ) to the first couple inches of the forward section of the leading edge sheeting and let it soak for a few minutes.
Force the sheet down on the ribs and position it on the spar and using a straight edge, cut it to precisely fit on half the main spar.
Apply carpenter's glue to each rib with an applicator or a small brush, then apply medium or thick CA to the forward half section of the main spar.
Use masking tape to force the sheeting down at each rib while stretching the tape a little for a better contact and if needed use small clamps to close any gaps at the ribs.
You can remove the masking tape within an hour but it would be preferable to let the assembly sit overnight due to the longer cure required for the carpenter's glue.
I hope this will help.
Gaston
Gaston
#816
Hey there Bruce, trouble is it wouldn't be QSAA legal even with two turbines
I think the Ziroli Panther just makes it, and the R54 is a LOT bigger than the Panther.
Bob
#820
My Feedback: (12)
The Reaction 54 is IMAA qualified just as it is since it is 158 wing span plus length. The QSAA says the plane has to be scale 80" monoplane or smaller if it is 1/4 scale unless they have changed the rules.
I decided to start the scaling process so at 125% it would be 97.5" span and 100" long and will be about 2265 square inches; the smaller one looker better at 38% to give a 30 inch span, 30.4 long with 211 square inches for a wemotec 480 EDF. Updates to follow
#822
My Feedback: (37)
the paint is first gray primer and then fleck stone paint (frome any hardware store). it hides all the seams, wood grains etc, and makes for a good looking interior. you see some of the large aerobatic planes done this way in the cockpit. i test fit everything, pull it back out and paint. reinstall. barry
