Official Jammin X1CRT Thread
#801
I have crt rtr what upgrades do I need to start racing. I already have the 16mm big bore shocks, high torque steering servo, and the bow tie mtr tires, is their anthing else this truck needs? And will the hyper 21 race engine be enough for the truggy?
#803
ORIGINAL: UG0TB4NN3D
What's the best motor I could buy for the X1 CRT to get the best speed and acceleration for under $250?
I was looking for something around .28 or .21.
Thanks!
Thanks!
#806
I'll be biased and say try the LRP .28 Spec 3. Can't beat the 175 dollar price tag. I've got 2 gallons of 30% though mine and it runs great and is so easy to tune. So much juice I stepped up to a 15T CB with no loss of low end power. If I had the space I'd step up to an 18T CB.
#808
NY
#811
ORIGINAL: docphysics
yea, but remember, you have to look at the power curve over the full range of RPM's, not just peak power.
#812
NY
I am definitely not knocking the LRP spec 3. I don't have one, but everyone that owns one says it is amazing. I just meant that different engines have different power and torque curves and some are smooth and some spike. Drake designed his engine for racing so the power curve is smooth over a broad range of RPM's. Its all a matter of money and application, to find something that works.
#816
IN
I just built my CRT about a month ago and I put an OS .28 XZ in it.
On my first outing to the track, I was politely told to 'tame it down' a bit before bringing it back to the track.
It now has a very small carb restrictor and 3 head shims in place and I can still run away from the owners LRP Spec 3 .28 powered 8ight-T on the long straights.
I run Byron 20% fuel and a P3 plug, with a JP-2 pipe. Everything else is stock as it came out of the box.
I can get 9-10 minutes run time per tank with my heavy trigger finger on the controls. I'm sure others could do even better.
Food for thought.
Scott
Food for thought.
Scott
#817
IN
ORIGINAL: phattracker
I cant wait to get some of those 16mm BB's on this pig.Any body know a good placeto get aluminium hop-ups for x1-crt??
Scott
#818
ORIGINAL: McFly505
Food for thought.
Scott
Food for thought.
Scott
#819
NY
What kind of track tells you to "tame it down"!?!?!!? Other people have to kick it up, if they can't keep up! ![Big Grin](images/smilies/biggrin.gif)
ORIGINAL: McFly505
Food for thought.
Scott
Food for thought.
Scott
#820
I was at the track today and I must say, a first happened, I broke a servo horn, that has never happened before so I didn't even think to take any extras with me. It snapped clean on the brake side after a very hard landing off of a double. I decided to keep running without brakes which proved to be very difficult, especially in the corners as I over shot most of them. Oh well, I still had fun
#821
IL
hey guys, havnt ran my crt in a while...been snowing latly here....but im gettin it ready for spring. i was wondering whats the best shocks to run on it and what shock oil weight to use? any suggestions would be appreciated! thanks
#825
VA
ORIGINAL: McFly505
Go [link=http://www.gshobby.com/index.php?main_page=index&cPath=785_880_881&sort=2 0a&filter_id=74&alpha_filter_id=0]here[/link] fo rthe best prices on King Headz parts. You won't be sorry with KHZ quality, it's top notch stuff.
Scott
Scott
