#8678
RE: Welcome to Club SAITO !
Changed the carb from another Saito 82 and it still won't run! When cranking I see the fuel shoot up the line to the carb so I believe the fuel supply is fine. Even after cranking for 10 seconds, the plug is dry. I'm beginning to think that vodoo did some damage while it was in storage for 1 week! I would throw it in the garbage can except now it's a challenge to find the problem. ;- )
Phillip
EDIT: compression is very good
Phillip
#8680
ORIGINAL: w8ye
Phillop,
Just send that 82 to me. I'll do something with it?
Phillop,
Seriously, I am out of things to try. Any suggestions other than taking it to the aluminum recycling plant?
Phillip
#8681
As regards the 82, one thing that has not been mentioned is the possibility of a intake manifold leak. . . . .
The 72 and 82 have the plastic back plate and the plastic mashes out from under the screws and becomes loose. This in the long run lets the intake pipe jump in and out of the head or at least vibrate at this point. And in turn wears out the Viton O ring at that point and creates the most exasperating vacuum leak that ever troubled anyone. It is usually very inconsistent and hard to pin down. But will cause erratic fuel draw and mixture problems.
The fix is to replace the intake manifold seals at the head and the carburetor and to put washers around the back plate bolts and to tighten them down.
Both BLW and I have experienced this with our 72's but our 82's do not have enough time on them to have experienced this phenomena.
#8683
ORIGINAL: w8ye
It also helps to put some silicone around the joint at the head during assembly with the new O-ring but make certain that no silicone gets into the running part of the engine.
STILL WON"T START!
Phillip
#8684
After 10 hours of labor and raw fingers I found the problem! BAD FUEL!!! I just bought a fresh gallon of Wildcat 20/20 YS 4 stroke fuel, the same I've been running for several years and after switching motors that was the only remaining possibility. I am so pissed off I'm turning blue from lack of oxygen. :-O I wasted a trip to the field and half a weekend diagnosing somebody else's mistake! Thanks everyone for their help and suggestions. Maybe someone can benefit from my ordeal.
Phillip
Phillip
#8685
The higher the nitro level in your fuel the more sensitive to sunlight it is. Keep your fuel in the dark!
Severely exposed fuel will frustrate the day lights out of you. You cannot ever get the needle set and if you do, the plane will quit on take or shortly there after.
#8686
I purchased the fuel just last week and the LHS does keep a fresh supply. I would say that he sells out at least once a month. How could the fuel be so bad that the motor wouldn't even start? It doesn't sound possible.
Phillip
Phillip
#8687
The one you got wasn't fresh. Been setting under the fluorescent lights for a year or so.
Ultra violet light is what messes up the nitro. The light emission from fluorescents lights is pure ultraviolet light from the Mercury vapor. It activates the phosphor coating inside the lamp and therefore the lamp emits light in the color temperature ranges from 3500 degrees Kelvin to 6500 degrees Kelvin.
#8688
w8ye,
That's probably what happened. Have you heard of this before? I thought that a 4C would actually run on very low or possibly no nitro in the fuel. Just to double verify my findings, a friend is willing to try the same batch in his Saito 1.25 tomorrow.
Phillip
Phillip
#8689
I learned all this the hard way 3 or four years ago. I went through fits with fuel that wasn't but a month old but had been out in the sunlight everyday. I got out some old fuel that had been sealed up in the dark for 3 years and the engines ran perfect.
I buy my fuel by the case and still sealed up in the case. I keep the fuel closed up in the box until I get one gallon out and put it in a metal gallon can. Now my metal can may set out in the sun but I try to keep a rag thrown over it to keep the temperature down.
I haven't had any trouble since.
#8690
boy that sounds like when i worked at the LHS and kids would buy a new rc car and they would go home run it for a couple of times, leving the lid off and seting in the sun the hole time. by the 5th or 6th tank thay would bring it back and say the thing is junk. me i just loved to dumping out the fuel, put new in and have it run like a top. makes you look good! ha ha.
jimmey i would have never thout of that with airplane guys, you just dont think of that problem. we all go throw fuel to fast to have it.
glad you found it and are able to go flying. we all lernd a little to day. c-crunch
#8692
I have two Saito 91S's. Great engines. One is in a Sig AstroHog and the other was in a Yellow Extra300L and is now being installed in a Great Planes Super Skybolt ARF inverted with on-board glow. I run Wildcat Premium Xtra 15% with an ounce of Sig castor oil added for good measure.
#8693
Jimmy Hoffa:
I have a FA-65 engine in a Tiger 60 and have been running Power Master 20/20 fuel only since I put it in service. The engine starts on the first turn and runs great. I have started on my fourth gallon of fuel and haven't had to adjust the valves. This fuel is expensive but performance wise I got my monies worth.
#8694
ORIGINAL: Capt Lou
Jimmy Hoffa:
Jimmy Hoffa:
My bad fuel is the same brand and blend that I've been running for over a year. I guess I just got a old gallon of it because it's always been very good. I also have friends that use it with no problem. I'll look for the Power Master 20/20 at my LHS. I learn something new all the time and hopefully others have as well.
Now I'm wondering if it's possible to get fuel that is of marginal quality but still allows the engine to at least start?
Phillip
#8696
My Feedback: (19)
I was wondering if the 91 four stroke would be too much for the Kadet Senior.....any problems with installing it.....i want the ARF version....trying to gather all my info
#8698
lol i come out to the r/c club with a can of traxxas fuel can but that is not what's in it if i could get my hands on some blue fuel dye i would have them going. my Hangar 9 Tribute 4D 36 has the fuel tank out side. its handy to be able to see how much fuel you have in it .... <<< is it true you can no longer get a saito 45 in the us . and dose any one have the spec on it,s bolt down size with and wide or is it the same as the 40 i see it on the web page the carb looks back not good were im going to put it >>> .it looks like a fa-40 will be what i want to put in my tribute going to find a converter for 300g to 10.3 oz find who is heaver and by how much .the motor that comes in the plug and play .its all most all it can do to hover it . a tad bit more power is all that it has to climb up it has a macs pipe on it . it sounds good but it has no rumble and i must have rumble <<edit i see it is no longer hear >>>>[]
#8700
ORIGINAL: alucid1
