#8726
Well , Ole Faithful, my Saito .50 decided to give me problems. I was not getting full power at wot , adjusted low end and then high end. At appox 1/2 throttle the engine ran max and started to decrease RPMs as I open the throttle more. [X(] After readjusting the ls and hs again, then back off about 300 rpms ,the engines chokes out going from idle to wot. If I fatten it up it bogs and if I lean it I cuts off quickly at wot.
Never had a problem in years with this engine ( this was on a very hot day last week) and I wonder if that affected it??
anyone?![Big Grin](images/smilies/biggrin.gif)
Saito # 108
![EEK!](images/smilies/eek.gif)
anyone?
Saito # 108
#8727
My Feedback: (8)
MA
on a cub, i would not go any greater than a 6" pitch. the 13x6 MA on my .70 FS (goldberg clipped wing) gives much more than scale flight speed and lots of verticle for big loops and stall turns.
jon
jon
#8729
My Feedback: (8)
MA
i have a saito 1.00 i plan to install on my GP .60 extra 300s. expect it to be a good match (w/APC 14x8?). considering upgrading to the 1.25. it really seems that i hear about a lot of people having trouble w/that engine. if i do use it, what's a good prop for that a/c? apc 15x6? does the velocity stack work on this engine also?
jon
jon
#8730
I have a velocity stack on mine. It seems to do OK. Most people are running a 15-8 on the 125 but I like the way it runs with a 15-6.
The 125 seems to be OK. I like the way mine runs. There's a lot of them out there. Problems seem to be with the muffler coming off or coming apart and rusty bearings.
#8735
OH
I had a Saito .82 on a Funtana X50 - for a short while! It was great fun, until the left wing decided to go its own separate way! That engine and Rx is now running happily in a Showtime 50. The ST50 has a wing tube, and the X50 did not. I wonder if there had been a wing tube......
I felt the wing wasn't put together very well on my Funtana. It snapped right at a spar, and it looked like there was hardly ANY glue on it. I would have had to remove the covering to add glue in that area. But to be fair, I was NOT easy on the X50!
However, since I did NOT want a repeat performance on the wing, I bought the ST50 to replace my X50. The X50 was more wildly acrobatic than the ST50, but the ST50 ain't bad! And.... the wing is staying on - so far.....
#8736
My Feedback: (34)
Bob, I've been flying that plane with a Saito .72 and just LOVE it...the .72 was very adequate in the vertical department - and now with an .82 hummmmmm....
Prop? Don't even have it out of the box yet
Suggestions are welcome.
For fuel, I've always used Omaga or Powermaster - w/ castor and have never had a problem - just wondering if I should try some all synthetic...heck, I just might read the instructions and follow them this time![Smile](images/smilies/smile.gif)
Jerry
Jerry
#8737
P51delta,
re: .82 engine
I ran mine on a Twist w/ 14 x 4 and that was awesume. Mucho power on a light airframe made for 3D
( didnt get a kick out of 3D )
Moved the .82 to a SeaGull Decathlon w/ a 13 x 6 Plenty of power. I believe the boxy airplane weighs about 5.5
Again, very nice engine, Pulls that airplane around no problem.
good luck w/ it
Biil
re: .82 engine
good luck w/ it
Biil
#8738
JB86
I am running an APC 16 x 6 prop on my 1.25 . I have the engine on a GP Super Skybolt 9.8 lbs, and it hauls tail. The engine is flawless. ( and is sounds soooooooo sweet too ! ) Its mounted inverted and wont miss a beat.
good luck !
Bill # 108
good luck !
Bill # 108
#8739
Have a 91 great motor...but now its time for bearings. I have never put them in a four stroke before.....any thing special I need to know? Should I use OEM or aftermarket ones. Thanks for any help.........
#8740
IA
Good day
I bought a Saito 100 last fall and put it on a new 4*60. From the first start up it ratteled loudly. So bad that we brought it down on the maiden flite to see what all the racket was about. I have flown it a dozen or so times and it is getting worse. Going to take it off and send it back to Saito. A new engine that cost this much should not do this and now I have to spend more money to send it in. Still it runs good with a lot of power. Sorry but it happened. So far not pleased.
But thats just me
Mike
But thats just me
Mike
#8741
i had a simuler problem with one and ternd out i did not tighten the prop. i was running a wood prop. it soundeed like it was comming apart. be for you get to disceraged try to tighten prop. c-crunch
#8742
At this link along the top of the title page there is a selection about how to install R/C bearings. It is about 2 strokes but we can talk you through the timing issue.
http://www.mcintoshcentral.com/rc-bearings/
#8743
well today i sliced my finger open to the bone 9 stiches the 125 kicked back and the next blade got me good funny thing is it realy didnt hurt to bad but the doctor bill of 300 dallars that hurt now i have to putt my 40 size satio on hold well i could go and buy it but this finger would have a fit trying to put it in. and it looks like my big toe it swelled and throbbing good now
its ok to laugh about it . the back of the apc props are sharper than i thought by the way your not as fast as you think your are
#8744
My Feedback: (30)
Ok so I see you are my next door neighbor but I always file the back of my APCs and round them off before balancing I also learned to back flip my Saitos after getting bit one ttoo many times and it hurts LOL ......
#8745
So I guess I'll just use a 14x4 APC and fire up my brand new, very first Saito engine (FA-82) tomorrow. It's been waiting for me patiently on the shelf for months now. I've only had YS 4-strokes until now, but the time has come. I Have high expectations and I expect to be very pleased by this shiney, good looking motor.
#8747
ORIGINAL: p51delta
Hi Fellows!
What's the best APC prop for a FA 82. I want to try some 3D. The plane weighs just under 6 lbs. I had a YS.63 in it until now and it just wasn't quite enough. I hope it will hover now with the FA-82.
Hi Fellows!
My Feedback: (8)
MA
in the gp .60 size extra 300s i'd like to stay with a 15" or 14" prop. 16" would be just a bit large. could i use 15x8 apc or 14x10? either a good choice? what should i expect for rpm w/20/20 fuel or w/30% nitro?
any idea of what i should be getting for rpm w/the 1.00 w/14x8 prop/20% nitro?
jon
jon
#8749
NC
Sure, I fly my H9 81" span cub on a Saito 56 and off water with floats and it flies great. I can't imagine using any more power. I like flying more scale-like but it takes off quick if you nail it. Good luck.
#8750
Uh Oh!!! That would be disappointing if the FA 82 & the YS .63 are similar in power. The .82 has ca. 3.5 ccm displacement more than the YS. I was hoping for a massive increase in power. It's all the same plane. a Kyosho Edge 540 in orange. 1440 mm wingspan. just changing the motor.
