Reaction 54 Jet Kit
#876
My Feedback: (81)
TN
I use the crow set up ,works great for small runways I have a 350 foot runway and with the crow set-up have no problem getting in. I have the same set-up with the BVM Bobcat. SKS video has the R54 flying at Georia jets.
Mike Grant
Mike Grant
#877
My Feedback: (43)
WA
Tommy & Dave - All good advice. Each individual has their own technique that works for them. I was probably making too much of the landing speed. I have a 2000' paved runway to land on and landing fast presents no problem. What I'm trying to do is be able to touch down within 20' of a spot on the runway. I want to fly it out of a grass strip that is 275' long, so I need to be slow & "spot on" to do that. Between my schedule and the weather I've only been able to get out about every other month. Just need to fly more!!!
Galen
Mike - I've also used the crow setup on both my Bobcat and Kingcat. I'll probably set it up on the R-54 as well.
Galen
#878
My Feedback: (81)
TN
Yes, I would do that it"s almost the same set-up works great,but if you have a strong head wind I would not use the crow may get to slow. I have it set-up with the landing switch so I can turn off with or without flaps.
Mike Grant
Mike Grant
#879
My Feedback: (18)
Well I've been asking questions in this thread for a while and since I'm almost finished with mine, I though I'd post a few pics. When I say almost finished, I'm just missing a few minor things like a TURBINE and other finishing touches. I might make it to Florida jets this March so maybe there will be some turbine deals to be had.
Marty
Marty
#887
My Feedback: (18)
Thanks Bruce. Should give good visibility.
Barry, it looks good out on the flightline. Are sidewinders in the works for the wingtips? Would definitely up the cool factor a few notches.
Marty
Marty
#888
My Feedback: (37)
sidewinders? why not. give me a trip or two to the hooby shop and sidewinders it shall be. those red tips are a top secret laser banger only fitted to the navy seal flying squadron.
this baby can be launched from a sub and morph into a raft. back to reality, barry
#891
ON, CANADA
Things are coming along well on my build. Here is a picture of the wing almost completely sheeted. I have chosen to due the full sheeting, as I will be glassing the plane.
#892
Dave
After looking at the pic of the other airplane just sent me, I can just imagine how good your R54 will turnout, looking great, keep it up.
Gaston
Gaston
#893
OK R54 pilots. Do you think the rudder is large enough? I'm looking for low speed knife edge and smooth point rolls. Would enlarging the rudder be a waste of time?
#894
My Feedback: (69)
ORIGINAL: causeitflies-RCU
Dave
#895
Only in the video Dave. If it flies like a Kaos it'll be fine. It's just that I GOTTA change something in every kit I build![EEK!](images/smilies/eek.gif)
I was going to change the wing but so far have only changed my mind
#896
ID
Hi Dave,
I figured out my 9cap radio problem. I had to exchange it for a new one. The transmitter wasn't transmitting. Just my luck. The new one is really nice though. A little different than what I have been using. When going thru the start up procedures for the jetcat, the "idle" position is max. throttle trim. Is that above the center point and clear to the top? (The trim adj. is a little different on this Futaba than I'm used to. ) Then when I go max. throttle,to start ignition, and drop the stick to idle, the light won't turn green unless I drop the trim on this new radio to neutral. Is that sound right?
Steve
Steve
#897
My Feedback: (69)
Dave
#898
My Feedback: (69)
ORIGINAL: samo
Hi Dave,
Steve
Hi Dave,
Steve
Not how I do it. I'm working from memory as I'm not near my TX......
Set the end points on the throttle to 75% each side
activate throttle kill on a switch you prefer
I THINK the throttle needs to be reversed..not sure about this..
low trim in the ECU is with throttle cut on
high trim is with throttle cut off
low idle is low stick.
I NEVER touch the digital trims.
Use single channel ECU setup.
To start...
stick low
throttle cut off
turn on TX, RX
flip throttle cut to on then off
You should hear the tones cycling
move stick to high throttle (this starts the start sequence)
move the stick to low as soon as the starter engages. Actually you can move to low at any time
wait until start sequence finishes and you get a green light on the I/O board.
Go fly.
Shut down
throttle down
throttle up to about 1/4 stick and hold for several seconds to cool down the turbine
flip the throttle kill switch and lower the stick.
Should shut off and enter the cooling cycle until 100C is reached.
Hope this helps and I'm not too far incorrect!
Dave Rigotti
#899
My Feedback: (24)
Finishing up my R54 and have 2 (more) questions ..........
As far as the forward facing clunk in the fuel tank....... is this setup suseptable to picking up air in climbs when the tank is less than 1/2 full ? It seems like the clunk would be out of the fuel ? ...... or will the UAT take care of any air that is picked up. I know this is a very well designed kit ..... I probably just need some mental assurance ...... since I have never before set up a tank this way.
As far as the antenna ..... if I use the standard reciever antenna (and mount it inside the fuse) it will run past the ECU (probably within a few inches of it). Would a Revolution base-loaded antenna (mounted inside) in the nose area be a better option ?
Thanks again. Bob
Thanks again. Bob
#900
Ask Dave Rigotti (rcguy!) about forward facing clunk. Mine is rearward clunk and the UAT mounted in the ecu tray, with the ecu mounted in the boat tail.
I get a lot more range with a whip antenna. Why take the risk.
Regards
Regards
