Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Truggy
Official Jammin X1CRT Thread
RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Old 03-11-2008, 12:30 AM
  #876
phattracker
phattracker's Avatar
Default RE: Official Jammin X1CRT Thread
i think the jammin 28 is a great motor, and you be jammin mon.
Old 03-12-2008, 08:44 PM
  #877
Fher Raul
Now i run the stock Jammin .28 motor, but i have a PRO kit, the last weekend i finish third in a A class main race, because my motor heat and stop 2 times, my pitman and anothers guys said me that i need a race engine like a OS, but i need more option because i like to buy 2 engines, one for stock, and the OS is spensive for me now, thanks for opinions guys
Old 03-12-2008, 08:49 PM
  #878
docphysics
docphysics's Avatar
I like the LRP .28 Spec 3, or the Losi mach 427. Both great engines at a reasonable price.
Old 03-12-2008, 11:11 PM
  #879
SlideZ32
ORIGINAL: Turboprop130
The O.S. V-Spec is a good motor, but on the expensive side. No doubt O.S. makes a good motor, just got to pay for it. I tried a .21, and then I dropped in a .28. The difference is night and day. Just the other day I ran my CRT against another CRT. I was running the LRP .28 Spec 3 and he had the Axial .28RR. In comparison, the LRP puts out so much more power. I would give the LRP a try. I've got over three gallons through it so far and it only cost $169 vs $300 for the O.S. V spec. If I were going to spend $300, I would throw in another $20 and get the O.S. 28XZ. A .21 is good for a buggy, but a truggy needs a .28 in my opinion.
This is good advice and to the point. My OS engine for my buggy has served me well.
Old 03-15-2008, 08:30 PM
  #880
Rye_rucker81
What all is required to run a os .28xz in a stock crt... can i use the stock backplate for my autostarter? will the stock exhaust work?
also same question about the LRP .28 Spec 3
Old 03-15-2008, 08:32 PM
  #881
Rye_rucker81
dubbed it ^^^^^^^^^^
Old 03-17-2008, 12:11 AM
  #882
Turboprop130
Turboprop130's Avatar
As far as I know, the OS .28xz is bump start only and not able to be converted. If you want to keep the roto start, you'll need to look into a pull-start engine or one with a roto start. For example the [link=http://www.osengines.com/engines/osmg2078.html]OS .30VG ES[/link]. I will do some more research, but pretty sure you'll be buying a starter box if you want to run the OS .28xz, also you might need the pro kit low profile engine mounts. The stock exhaust will hook right up, but I would suggest buying a better pipe.
In regards to the LRP. I have the pull start version and had to buy the LRP backplate and HPI roto start. I also had to get the tall engine mounts since the pro kit only comes with the low mounts. Works awesome, and no need to carry around a starter box. Will add some pics for you to see.
ID:	905539   Click image for larger version
ID:	905540   Click image for larger version
Old 03-18-2008, 02:41 PM
  #883
Rye_rucker81
Great pics how do you like the LRP .28 Spec 3?
Old 03-18-2008, 04:12 PM
  #884
Turboprop130
I like it a lot. I took some video the other day. I need to edit it, and upload it. Send me a PM and I will send you some video.
Old 03-18-2008, 09:47 PM
  #885
Fher Raul
Nice engine, actually i have installed the low profile engine mount and i use a JP-3 Pipe, i see the Exile engine RR on ebay, also some poeple talk tome about the Jammin.28 engine is like the OS V-Spec, i think is a big deal, wht you think?
Old 03-23-2008, 11:06 PM
  #886
Rye_rucker81
I know this answer is some where in the 35+ pages but what diff. wt is everyone running for a race track setup..... (Front center rear diff wt) ALSO what brand oil to use?
Old 03-24-2008, 04:53 AM
  #887
docphysics
docphysics's Avatar
I use Losi and Associated oils. I run 10F - 30C - 3R.
Old 03-24-2008, 07:22 AM
  #888
Turboprop130
I use ofna oil and my setup is 15-30-5
Old 03-24-2008, 11:52 AM
  #889
eirk66
eirk66's Avatar
my friend use's 7,10,5 in his Jammin
Old 03-24-2008, 05:55 PM
  #890
rageworks
AE oil 7-20-3
Old 03-24-2008, 08:57 PM
  #891
UG0TB4NN3D
This is my CRT's new body. RT Symbio T2.
Old 03-30-2008, 06:58 AM
  #892
evad1
Ok, i just pulled the rear diff out to change the grease that factory put in it to 3k silicon. Now my problem is when i put it all back together the pinion gear makes a winning noise it. it has not been ran sence i have done this so i know i did not ruin the gears. It has shims and i put them back the way they came out if that helps also it had some thick grease on the gears. what did i do wrong. thanks
jake
Old 03-30-2008, 05:13 PM
  #893
SaVaGe MaN SS
SaVaGe MaN SS's Avatar
great body banned what is it? kyosho
Old 03-30-2008, 08:27 PM
  #894
JB COMP
JB COMP's Avatar
I know this has more then likely been asked in this thread, but I don't have time to read through 36 pages.
I need to know how to make my CRT turn sharper. It don't turn well off power (it will turn around in about a 10" circle) but on power it won't turn for nothing (but I'm using 30K in my center diff but I'm about to put thinner oil in it)
My tires are towed out (maybe 2 or 3 degrees) and I'm, running a 3.5 in the back (don't know what its called)
Old 03-30-2008, 08:46 PM
  #895
docphysics
docphysics's Avatar
for better on power steering, thicker front diff oil, thicker center differ oil, and less tow out, also there is an ackerman adjustment, decrease the ackerman. All should help.
Old 03-30-2008, 08:53 PM
  #896
JB COMP
JB COMP's Avatar
Whats an ackerman? Sorry its been a while since I've worked on my CRT.
How dose thicker center diff oil help on power steering? the tires are barely touching the ground as is.
Old 03-30-2008, 09:07 PM
  #897
docphysics
docphysics's Avatar
it will send more power to the rear, allowing the rear to slide instead of the front, in turn the slower spinning front tires will get more traction and the truck will rotate through the turn better.
Ackerman:
http://www.rctek.com/handling/ackerm...principle.html
Old 03-30-2008, 10:38 PM
  #898
Rawdawgga
Anyone have any news on the new jammin x2 truggy release
Old 04-01-2008, 02:30 PM
  #899
SaVaGe MaN SS
ORIGINAL: Rawdawgga
dont really know, it was suppose to be released april i heard[]
Old 04-01-2008, 07:03 PM
  #900
Turboprop130
jake
It is normal for the diff to make some noise but the diff should operate smoothly. If you're rotating the diff and feel it get tight at any point you need to move a shim over to the other side. The manual says start with 2 and 2. My diff shims for example are 3 and 1. Every diff is different. Make sure to put new grease between the pinion and ring gear and that the pinion is seated all the way back against the diff housing.
