Official Tamiya TT-01 Thread
#926
WA
ORIGINAL: egagnier
Hobby Town only had the airbrush type of paint and Hobbyworks didn't have anything
Is there anyplace online or any other chain hobby stores that will have it?
#927
MD
I just found it on Tower Hobbies! The only thing is, the paint that they show isn't for lexan...this won't work for car bodies will it? Everyone I've talked to at the hobby stores that I go to have told me that if I use anything other than lexan paint (they carry pactra paint) then it will end up chipping and falling off because it doesn't seal to the lexan.
Are they full of S*?
#930
WA
ORIGINAL: egagnier
#932
MD
Not to sound stupid, but how do you prep the paint for non-lexan paint? I know how to do it for lexan (soapy water and let dry for a couple hours...)
Is it any different for plastic paint?
#933
WA
To prep body before painting:
1. Wash with warm soapy water using scuff pad
Thats it! Make sure it is completely dry before painting. What paint are you gonna use?
#934
WA
#936
NY
i am looking into getting a decent beginer on-road car and i was wondering if i wood be able to compete with the hpi sprint 2s, losi xxx-s's and tc4s at mi local track with a tt-01?
#937
ORIGINAL: Rare
Just make sure it can be used on plastic. Plastic pain can chip to due to poor paint job. You need to prep the car perfectly before painting.
ORIGINAL: egagnier
That's all incorrect. The paint has to be compatible with lexan/polycarbonate (same thing). No matter how well you prep the body (which you are supposed to do anyway) non-compatible plastic modelling paint will eventually crack and look terrible. You need to use some of the many brands of polycarb. paints in order to get the paint to flex with the body. Eberyone you phoned was on the ball.
Also; it is illegal to send an aerosol can through the post. However; it is also illegal for the post office to open your parcel, so just find someone willing enough to send it and hopefully you'll be fine.
BTW Tamiya tinting or 'smoke' paint is under the code PS-31 (PS=Polycarb. Spray)
Anything else I can help with?
Chris
#939
WA
ORIGINAL: egagnier
Do you know of any other brands other than Tamiya that has tinting paint? Both of my LHS carry Pactra only for lexan...
#940
Wonder if anyone can help...
I've installed a trinity D4 9X2 motor and Mtronics pro digi ESC which is hardwired to the motor, but the ESC uses different battery connectors to the battery. I don't want to cut the connecters from the battery because they won't fit the charger, and the ESC wires look too thick to attach to the standard battery connection block.
Any suggestions?
Any suggestions?
#941
MD
#942
I thought they may be the answer, though I wasn't sure if the battery would clip onto the charger if I put Deans on the battety aswell
#947
NJ
Does anyone in here have any experience buying anything from Rcmart.com? I've heard from others that there not one company to deal with if orders are wrong and also that there isn't a way to contact them. Unless it's through an e-mail, is that true? They have a lot of aluminum parts i'd like to get and from what i could find they seem to be the only ones to get them from? Any other options?
#948
MD
I bought a bunch of stuff from rcmart.com
I didn't have any problems with the order at all. The only problem that I had was that it took almost 3 weeks for the order to arrive! I'm impatient as hell and that was a killer
The only contact I had with them was through email and that was very limited.
#949
i bought my part throught ebay. any more questions tell me.
RC_MALL seller:
GPM TAMIYA TT-01 Alloy complete Tie Rod Turnbuckle Set
GPM TAMIYA TT-01 Alloy Front / Rear Upper Arm Mount
GPM TAMIYA TT-01 Alloy Steering Assembly Set (BEARING)
GPM TAMIYA TT-01 Alloy Complete Damper Shock SET RED
GPM TAMIYA TT-01 Alloy Complete Arm Set Blue
GPM TAMIYA TT-01 Alloy Driver Washer Hex Wheel
Jason's Store seller:
Tobee Craft Gear Box Joint Set Tamiya TT01 TT-01
Tamiya TT01 Stabilizer Set Rear TT-01
Tamiya TT01 Stabilizer Set Front TT-01
Tamiya TT01 TT-01 Carbon Upper Frame
RC_MALL seller:
