UMS Evolution Radial Care and Operation
#76
My Feedback: (62)
RE: UMS Evolution Radial Care and Operation
Dambo, You are wise to run the engine first on a test stand. You will learn much doing this. Please read your manual carefully! Now about mounting... Do not use standoffs because you will be standoffing with standoffs! I know sounds silly but it is not recommended due to torsional effect. Look at how I did my corsair. My mount starts with 1/4 ply shaped like the engine mount base with cherry standoffs that are the same shape as the mount and ply base. Now you will need to use the outer holes on the bottom of the mount but the INNER hole on the top of the mount and the bolt will need to be reversed with the socket head from the back of the firewall forward. That way you will not need to make massive modifications to your firewall! Check out my pictures of my corsair earlier in the thread. Don't those BH corsairs fly ridiculously great!? -Tom
#77
My Feedback: (62)
It is very quiet around here, I see that many radials have sold, some sold out untill the next shipment! Soooooooooo what are you guys up to??? I am installing the evo 160 gas in my beast right now. It will be available soon. -Tom
#78
<span id="result_box" lang="en"><span class="hps">I'm sitting</span> <span class="hps">here waiting</span> <span class="hps">on the exhaust</span> <span class="hps">ring</span> <span class="hps">for my</span> <span class="hps">ums</span> <span class="hps">7-35</span> <span class="hps">from</span> <span class="hps">keleo</span><span>.</span>
<span class="hps">it</span> <span class="hps">is on its way</span> <span class="hps">from the USA.</span>
<span class="hps">Tom</span><span>, you have</span> <span class="hps">some pictures of</span> <span class="hps">160 and</span> <span class="hps">price
Lars<br type="_moz"/></span></span>
#80
<span style="font-size: larger"><span style="font-family: Arial">I recieved my EVO 9 cylinder about 3 weeks ago and have pulled it out of the boxevery fewdays...just look at it! Great looking engine, but more importantly itwill makethe1/4.5 scaleFW 190, I am building,sing :-)
Should have things ready for some breaking-in on an engine stand before too long. Really looking forward to that.
</span></span><p class="MsoNoSpacing" style="margin: 0in 0in 0pt"><span style="font-size: larger"><span style="font-family: Arial">Is there a conventional wisdom with regards to the use of an exhaust ring on a glow radial vs. running exhaust pipes individually from each cylinder to its respective scale exit?
</span></span><font size="3"><font face="Calibri">Regards,
Mitch</font></font></p>
#81
My Feedback: (62)
Well Mitch a collector ring will be cleaner and sound deeper. That plane will be outrageously cool! Lars, here is a photo of the 160. I call it the 10 10 10 engine! (+- 10%). 10 cu in., 10 or so Hp, 10 out of 10 in running qualities, 11 pounds with ring and 11 inches in diameter and insanely low vibration.
#82
<span id="result_box" lang="en"><span class="hps">Now</span> <span class="hps">today I</span> <span class="hps">received my</span> <span class="hps">exhaust</span> <span class="hps">ring</span> <span class="hps">to</span> <span class="hps">UMS</span> <span class="hps">7-35</span>
<span class="hps">And</span> <span class="hps">it</span> <span class="hps">is in place</span><span>,</span> <span class="hps">fit well</span> <span class="hps">and</span> <span class="hps">easy to assemble
#83
<span lang="en" id="result_box"><span class="hps">Exhaust</span> <span class="hps">Ring</span> <span class="hps">from</span> <span class="hps">Keleo</span>
<span class="hps">mounted on the</span> <span class="hps">seat</span> <span class="hps alt-edited">fit nicely</span> <span class="hps">and</span> <span class="hps alt-edited">easy to install
Lars
</span></span>
Lars
</span></span>
#85
<span id="result_box" lang="en"><span class="hps">Yes</span> <span class="hps">the engine</span> <span class="hps">is</span> <span class="hps">back</span> <span class="hps">in</span> <span class="hps">PT17</span><span>.</span>
<span class="hps">propellor</span> <span class="hps">is</span> <span class="hps">from</span> <span class="hps">Graupner</span> <span class="hps">18x8</span> <span class="hps atn">G-</span><span>Sonic</span><span>.</span>
<span class="hps">it</span> <span class="hps">is as good as</span> <span class="hps">APC</span> <span class="hps">but</span> <span class="hps">half the price
#86
<div id="gt-src-c" class="g-unit"><div id="gt-src-p"><div id="gt-src-wrap"><div style="width: 100%;"><textarea class="goog-textarea" style="-moz-box-sizing: border-box; overflow-y: hidden; overflow-x: auto; padding-right: 20px;" id="source" name="text" wrap="SOFT" tabindex="0" dir="ltr" spellcheck="false" autocomplete="off"></textarea></div></div> </div> </div> <div id="gt-res-content" class="almost_half_cell"><div dir="ltr"><span id="result_box" lang="en"><span class="hps">it's not</span> <span class="hps">all parts</span> <span class="hps">of</span> <span class="hps">evo</span> <span class="hps">radial</span> <span class="hps">engines that</span> <span class="hps">can be purchased</span>
<span class="hps">If</span> <span class="hps">viewing</span> <span class="hps">horrizon</span> <span class="hps">website</span><span>,</span> <span class="hps">hope</span> <span class="hps">there will be more</span> <span class="hps">in the future
Lars<br type="_moz"/></span></span></div></div>
#88
I received my Evo 7-35 a couple of weeks ago and it is a beautiful engine, i am glad i bought it!
I was positively surprised that the glow harness was top quality and ready to use, made in a ring pattern ,very clever! Also there is a spring choke on it ,like on the ASP 400. Very useful. And mine will be cowled in my Pitts 12 Python from Peakmodel.
Even the the throttle was made with a special linkage system.
I have test run it ,and the overall quality of the engine is top!
Now i will solder a copper exhaust system for it to fit in the Python.
#89
My Feedback: (62)
Nils, That wiring harness ring idea came from me! Horizon liked and used it. Pitts pythons fly really well so that would be a great combination. Those 7-35's should soon become a top seller with their low fuel consuption and smaller plane sizes. They look good just sitting there. Mine is so easy to start too. Send photo's.....Tom
#90
Has anyone ever taked to someone at Horizon Hobbies about a warranty issue?
After looking over my EVO777 I had notice that one of the exhaust tubes has a different radius than the others.
It looks like it may have been an intake tube used as an exhaust.
I sent a picture to HH but the only answer i got was to call back earlier in the day to talk to an engine person.
#91
Just call our product support on Monday and they can send you a new package of intake/exhaust tubes. They come packaged as a set.
1-800-338-4639
Pete<br type="_moz" />
1-800-338-4639
#94
Hi,
I just got the Evo 735 to put on my Staggerwing. I notice that the oil content can be quite low for this engine. Was 10% with the ester based oils that are more common in Europe or the PAG oil that is more common in the US? Would it be OK to get some Cool Power 10% Nitro ( I think it has around 20% PAG oil ) and mix it 50/50 with Methanol to get 5% Nitro and @ 10% oil?
Joel
Joel
#95
My Feedback: (62)
Yes that would work perfectly! Its what I did, Just dilute a good brand of glow fuel with high quality methanol. I do not know about the different oils you mentioned. Perhaps Pete could answer your question in the oil type differences. -Tom
#96
ORIGINAL: Joel_L
Hi,
Joel
Hi,
Joel
BTW - The installation looks great on that airplane!
Pete
PS - The collector rings for all the engines will be available shortly - we are waiting to receive the instruction sheets from the printer.
Salukijet (02-01-2022)
#97
Isthat combination (Cool Power 10% nitro /18%PAG oilthen mixed 50/50 with Methanol)good for the break-in of my EVO 99cc 9 cylinder?
Thanks guys...
Picked up a gallon of the Cool Power w/ 10% nitro and 17% syn oil... Didn't have time to get the methanol today, but "hiperfuels" here in the Houston area sells it in manageable quantities. The fuel color is much more green than in the picture and it recommends NOT to add any after-run oil as it contains it...that's a time saver.
I will try to get a video of the break-in of the radial and post it. I still need to order my 25" Solo Prop for the FW 190 A version. Going to get an off the shelf propto use during initial break-in until the big boy arrives.
Thanks again
Thanks again
