Airworld Hawk Building thread
#76
RE: Airworld Hawk Building thread
Hi Mark and David.
Very informative work too both of you!
This thread will be very valuable, and save others alot of ploundering.
Soo, KEEP UP THE GOOD WORK!
The manual is allready added to my favourites..
I`m following your progress closely, and looking forward to the next steps here in this thread.
From the closeup of the retracted gear, it seems to be a stunning quality...
I guess the rest is in the same cathegory.. (?)
How many hours of work do you think will be spendt to complete it?
Can I get moore pics of the fuselage? Any will do.
Brg
Gudmund
Brg
Gudmund
#77
Gudmund,
There is a LOT of work to do on this model and as you can see it is, unfortunately, hampered by no clues or instructions!
I am used to opening kit boxes and seeing fully painted jets that are ready to go in 3-4 days (have a look at my Lightning thread ) so this is a bit of a change - should be worth it in the end though!
The retracts are probably the most impressive part of this 'kit'. They look ideal for grass field operation although I did find a 'problem' with my mounting rails. I can only assume they were installed very slightly at the wrong angle. This meant that with the gear retracted the main gear door would just hit the tire when closed. I checked and double checked to make sure my retract unit was fully raised and under pressure but it would still hit the door. As you can see from the main gear installation notes I made, I added some shims (approx 1.5mm) under the retract units and this solved the problem. Annoying nonetheless.
Will look to get the wing bolts/mounts in over the weekend. At least then I can stand it on its wheels and take some more pics of the fuselage for you
Hours to complete? Well, a wild guess would say you'd need about 80hrs to get it ready for final paint/install. David will probably be more accurate!
Rgds,
Mark
PS Will try and keep on top of the manual. As you can see from my other thread, my Lightning has turned up too so I will be moving between the two projects now!
Rgds,
Mark
#78
Great thread guys... would you consider me too greedy if I asked for some more pics to be added wherever you have a chance during the explanations of steps and/or modifications ?
This kit is high up on my list of "possibles" for the future (since I really love the Hawk), so the more details & pics you are willing to share, the better. I know it takes time cleaning the glue off your hands to grab the camera all the time (plus clearing the junk out of the way for a good pic), so don't think your efforts are unappreciated !
Cheers,
Gordon
#79
Hi Gordon,
No probs from me! I ummed and erred about the best way to do a "build thread" as the 'thread' always gets broken up with general chat/questions/answers etc
That's why I decided to produce the 'guides' which have all the photos/notes I've taken/made. I am not sure the best way to ensure they don't get "lost" amongst all the other stuff. May just repost links to them every few postings.
I'll try and throw in a spattering of general pics as we go too!
For now, in case you missed them, here are the notes I've made so far....
NoseGear/Former guide [link=http://www.mark.schroeder.dsl.pipex.com/Hawk/NoseGear.pdf]here [/link]
MainGear Install guide [link=http://www.mark.schroeder.dsl.pipex.com/Hawk/MainGear.pdf]here [/link]
Any better ideas of how to run a decent, controlled build thread?
Rgds,
Mark
Rgds,
Mark
#80
Don't be fooled! This kit is a KIT
Spent this evening faffing around with the wing mounting - infact spent most of the evening trying to rescue the smaller rear wing tube which disappeared into thin air. Thought I was going mad when I couldn't find it - then the penny dropped when I picked up the wing and heard a rattle!!! It seems they forget to 'plug' the end of the wing tube sleeve so it had simply slid through the sleeve and into the wing!! argh!!! Ended up having to cut a hole in the trailing edge and attempted to coax the tube out of it! NOT fun Little things like this bug me!
Anyway, have got the two front wing bolts in - just the rear to do. However, the fuselage has dihedral moulded into it and the rear rail is dead straight which means that when it is in place there is a 2-3mm 'cavity' that you either have to just fill up with glue or you'll need to fashion a wooden 'insert' - none of it hard but all just sillyness in such an expensive kit [:@] Should have it finished tomorrow evening. Instruction guide will follow (there are a few pitfalls to watch for even in this simple stage!) Pics of the front bolts... (Oooo, exciting!)
Rgds,
Mark
Rgds,
Mark
#81
Well, it's official - 8 week old children DO encroach on your building time
Finally, got round to getting the wing mounts in New guide for that step is here.....
Wing Mounting guide - http://www.mark.schroeder.dsl.pipex....ngMounting.pdf
As before, can other Hawk builders let me know anything I have missed!!!
Older ones.....
NoseGear/Former guide - http://www.mark.schroeder.dsl.pipex....k/NoseGear.pdf
MainGear Install guide - http://www.mark.schroeder.dsl.pipex....k/MainGear.pdf
I can't believe David and I are the only people building this kit!! Let's see some others chime in!!
Rgds,
Mark
Older ones.....
Rgds,
Mark
#82
Mark wrote ...
<snip> ... I can't believe David and I are the only people building this kit!!
Cheers.
Mike
#83
No progress on the Hawk as I've been working on my Mig 29 getting it ready for its first flight, hopefully on Friday, (and writing up the Hawk build report for RCJI) but some help please:
Does anyone know if there is a 2k primer available, such as PPG available in WHITE (the old K+B stuff would have been perfect !)
Stephan Volker's big Hawk had a double pulse strobe light, anyone know a source of these.
I am not getting any reply to my emails and fax to Air World which have included an order for as second kit, seems strange, anyone know what gives?
Regards,
David Gladwin
Regards,
David Gladwin
#84
I saw a car primed in white yesterday. They used Standox 2k primer. So if you can`t find what you`re after, a visit to the local car-paint dealer might solve it.
Btw, great review on the Hawk!
Brg
Gudmund
Brg
Gudmund
#85
David,
Not sure what's going on with AW - have sent them a couple of e-mails but had no reply. Interestingly, I normally get a read receipt on the mails but have not had one for either mail. Their e-mail is down or they're not around to pick up the mail I guess? Or, of course, they're just ignoring us
Rgds,
Mark
Rgds,
Mark
#86
Just had an email from Hans -Dieter. He has been away and coms. should be back to normal. My second kit should be ready in February and I will design and build a mod. for a removeable fin and the fuselage with a transport joint as per the real Hawk. I will pass it on for those interested. May also do a larger duct for AMTNL Pegasus HPES power but the duct will need to be flattened at the bottom (a bit like the 737-300 cowls) as space above the wing is limited. Anyone interested let me know.
Regards,
David Gladwin
Regards,
David Gladwin
#87
David,
Would be VERY interested to see those items - especially the removeable fin mod!
I'm about to cut the speedbrake out so as to give me some better access at the rear for mouting rear formers/tail/rudder etc. Could you take a photo to show how you hinged your speedbrake for me please??
Mark
Mark
#88
Well, cut the airbrake out tonight.
A word of warning - don't use the moulded lines in the fuselage as gospel. Cut inside them by 2-3mm and then slowly and patiently work on opening up the hole to the right size all round and you should end up with a nice fitting airbrake.
Now I have access to the rear of the fuse I hope to get on and install the tailplane/rudder/rear formers etc
Rgds,
Mark
PS Any luck with an airbrake hinging photo David?
Rgds,
Mark
#91
My Feedback: (26)
ORIGINAL: schroedm
Hi John,
Is Henry building them for a well known pilot from the UK?
Rgds,
Mark
Hi John,
Rgds,
Mark
Yes, one of them is going back to the UK I believe.
Mine will get here in February also. Hope to get one of your manuals then
Have you decided on a paint scheme yet? I want to do something non-arrows. Do by any chance have any photos of Hawks in military schemes with lots of armament hanging underneath?
#92
Hi John,
I keep thinking I should do a scheme that is going to be different to all the other "Red Arrows" that will be out there. There are one or two 'celebratory' schemes that I quite like as well as several camo schemes but something still keeps making me want to do the 'Arrows' scheme
Here are a few schemes I've been tempted by - maybe you'll be inspired by one of them....then again, maybe not!!
Rgds,
Mark
Rgds,
Mark
#93
A military jet with sivil colours is always nice..
The grey variants can be too much sometimes...
A table of goodies is easily exposed by a quick search on Google.
I know what I want on that table......
Brg
G
Brg
G
#94
I will do some airbrake photos later, been away for a few days at our big Australian jet meeting. Still on Cloud 9 afer succesful first flight on my FC Mig 29. What an awesome machine !! Second Hawk starts in February. Target weight with AMTNL Pegasus HPES 19.99 kilos ! Should manage that with my first with Jetcat 160.
Regards,
David Gladwin.
Regards,
David Gladwin.
#95
Photo attached.
Method:
Pass one CF tube through both arms of brake.
When glued in, trim off excess tube flush with arms (this ensures axes are concentric.)
Tap tube to hold SH bolts which act as pivot pins.
Make brackets (1/4 ply) to glue to fuse. in which pass two CF tubes which act as bearings for unthreaed portion of SH bolts.
Tape brake in place and tack glue brackets with CA. Chexk fit and function.
IF OK glue in brackets with Hysol. (more to be added in this pic)
Make sure hingle point is as close to fuse skin as possible. Works very smoothly over entire travel (60 degrees is correct angle )
Using this method means that the brake can be easily removed if neccessary and is very strong and smooth acting.
Regards,
david Gladwin.
Method:
Regards,
david Gladwin.
#96
Wings are joined. No problems. Some light sanding of the root flanges produces a perfect fit. It may appear difficult to push the wing halves fully home. This is because the phenolic tubes are such a good fit on the aluminium wing spar that pushing the wing panels together compresss the air in the wing tubes as it is trapped, acting like a piston !
The canopy is done. The frame requires some light sanding to allow a perfect fit of the transparency, also useful for growing tomatoes it is so big ! Careful work is required here and the canopy can be easily scratched.
The frame was located using two CF rods to locate the front and two glass tongues on each side. The latch at the rear was located as high as posible in the fuselage but even then would not locate properly in the canopy frame. A slot was filed in the frame and a short length of brass tube glued into it to capture the latch "prong". The tube was secured with two strips of glass board glued AND SCREWED to the canopy frame. The suction on this canopy is likely to be considerable so it must be firmly secured by very solid mounting of the latch and the receptacle, brass tube, in the canopy frame.
The more I work on this kit the more I like it, no. 2 will be even better.
Hawk equals Red Arrows. The sad news is that Ray Hannah, leader of the Reds for four years died last week, aged 77 STILL flying Spitfires.
Finally, DO take care when using Dremel cut-off wheels. When cutting slots for the locating tongues in my Hawk canopy frame a wheel exploded and the bits hit me in the face. I have badly cut lips BUT it could have been my eyes that recreived the debris. I have to wear glasses to see my work but if you dont need corrective glasses DO wear safety glasses.
Regards,
David Gladwin.
Regards,
David Gladwin.
#97
Well come on guys SOMEONE must be progressing with his Hawk. Just the flap and aileron hinge fairings to go and mine is ready for primer. Second one arrives soon, that build will be much quicker.
Regards,
David Gladwin.
Regards,
David Gladwin.
#98
David,
New job, burglary, new house and new baby have put a big brake on my progress [&:]
You are now the upholder of the build thread for the next few weeks so step up to the plate and fufil your duties
Lets see some pics!
Rgds,
Mark
Lets see some pics!
Rgds,
Mark
#99
You asked for pictures :
A few points. The canopy has been finally trimmed ready for glueing to the frame. I trimmed the frame to allow the canopy to sit slightly below the fuselage line so that the reinforcing straps at the front and rear of the canopy will be flush with the fuse/ forward windscreen profile. This is wrong, the straps are chamfered to mee the profiles. I will make the straps from .005 glass board, looks about right.
The access hatches have been hinged and stiffeners added. The hatches have distorted very slightly after removal. My next Hawk will have a couple of layers of glass cloth added in the hatch area to stiffen them. One hatch will allow access for fuel, gas (if still being used) and air. One will be for switch access, charging sockets and viwing the Power Box status lights.
The various vents, scoops on the fuselage sides can be seen, aluminium and plastic tubing used.
The ventral fins are installed. The longitudanal formers need to have spacers added to which the fins are fixed. You cannot move the formers inboard to mount the ventrals direct as the speedbrake (airbrake in RAF terms, been flying American aircraft too long !) will collide with them. After final glueing of the ventrals to the spacers the interor will be lined with 1/64th ply faced with litho plate.
Also visible is the bracket strip mounted at the tops of the ventrals made of thin glass board. The ventral mounting strap moulded into the fuselage is not quite right. It should be thicker and wider with two rows of rivets and three lugs where the strap is mouted to the fuselage former.
When the ventrals are added I suggest that a block of foam is taped to the fuselage between the fins so that they do not get damaged when placed on the bench etc.
For all these small details the photo CD which I shot at Scampton will shortly be available from Traplet and is invaluable.
Thats just about the fuselage finished, now for the wings, mainly flap hinge fairings and fences. Regards, David Gladwin.
