Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
Please post Saito 125 rpms..
Old 09-28-2009, 09:26 PM
  #76
w8ye
w8ye's Avatar
Default RE: Please post Saito 125 rpms..
ORIGINAL: ton2di
Hello Tcraft, w8ye
I have tried a mejzlik 16-8 earlier and the rpm is only about 8,100 ( motor seems to be running hotter because of the load). It doesn't seem to make my p-51 faster. (maybe because is was too windy here in the east coast today). I think I like the apc 15-8 at around 8,700 - 8,900 because of the thrust and speed that it gives. My other option is an apc 14-10 with around 9k rpm , but the pull at take off is noticeably less and the top end is only a little faster. (We can't have it all I guess)
This goes along with my experience
Old 09-29-2009, 11:01 AM
  #77
TCraft Lover
Hey Tony,
Good to hear you're still using your 1.25. I've pretty much settled on the MA15-8 for my Edge. Seems to give me the most pull at take off and for hovering which I'm still trying to improve on.I checked the valve/tappet clearance this morning and found it to be .0065 to .007 on both intake and exhaust so Iset them both to .003 clearance. I have no idea what, if any, difference this might make in the motors performance. I am wondering what difference there might be between APC 15-8 and MA 15-8. I guess I'm not willing to spend the money on test props since I already have several that don't meet my needs.Good Luck!
Dave
Old 10-04-2009, 12:50 AM
  #78
w8ye
w8ye's Avatar
I run 16 X 6 and 17 X 4W depending on the plane
my 125's when new I ran a 15 X 6 on them for the first couple gallons. They wanted to run hot at first on a 15 X 8
I have three 125's and two FG-20's
I have some planes that I may have to use a 14 X 10 or 15 X 8 on though in the future
Saito 125 old and new compared
<!v.rpn345,RcmdId VISuperSize,RlogId p4%60bo7%60jtb9%3Fv%7F.rpn345-1242688a016>&lt;script src="http://include.ebaystatic.com/v4js/en_US/e635/BuyingApp_ViewItemDefault_e63510032076_6a_en_US.js " type="text/javascript"></script&gt;&lt;iframe width="1" height="1" style="display: none; visibility: hidden;" id="***rame"></iframe&gt;&lt;script type="text/javascript">(function () {var _r = vjo.Registry;_r.put('ic_js_vv4-0',new vjo.darwin.core.imagecontainer.ImageContainer({"er rId":"vv4-0_e","cmpId":"vv4-0","IDivId":"vv4-0_idiv","err":null,"width":800,"height":800,"bdrId ":"vv4-0_bdiv","imgData":{"src":"http://i.ebayimg.com/07/!BbyZi6w!mk~$(KGrHgoOKkUEjlLmVpKoBK)oZMGP-Q~~_3.JPG","alt":null,"href":null},"clkSrvId":"IMG _CNTR_CLICKED_vv4-0","reszOnLd":false,"ancId":"vv4-0_a","loadSvcId":"LOAD_IMG_SRVC_ID_vv4-0","clkLstrKey":null,"imgId":"i_vv4-0","thr":null,"thrbId":"vv4-0_t"})); _r.put('th_js_vv4-0',new vjo.darwin.core.thumbnailgrid.ThumbnailGrid({"inst Id":"th_js_vv4-0","cmpId":"vv4-0","width":32,"hrSrvId":"TH_HVR_SVCvv4-0","errUrl":"http://pics.ebaystatic.com/aw/pics/cmp/icn/iconImgNA_32x32.gif","divId":"vv4-0_div","imgData":[{"src":"http://i.ebayimg.com/11/!BbyZu4g!Wk~$(KGrHqUOKjsEq5TokYCvBK)o,PceoQ~~_14.J PG","alt":null,"href":null},{"src":"http://i.ebayimg.com/07/!BbyZi6w!mk~$(KGrHgoOKkUEjlLmVpKoBK)oZMGP-Q~~_14.JPG","alt":null,"href":null},{"src":"http://i.ebayimg.com/13/!BbyZo3!!mk~$(KGrHqEOKjUEq3-GyigbBK)oZtrndQ~~_14.JPG","alt":null,"href":null}],"padding":0,"pos":4,"brd1Id":"b1_vv4-0_","clkLstrKey":null,"rows":18,"brd2Id":"b2_vv4-0_","idList":["vv4-0_div","vv4-0_tbl","t_ivv4-0_","t_c_vv4-0_","b1_vv4-0_","b2_vv4-0_","pD_vv4-0"],"currSelImg":"t_c_vv4-0_1","scBarId":null,"errCss":"tg-e32","forcedLoad":false,"hvrBgClr":"#3881e8","clkB gClr":"#666","trPfx":"t_r_vv4-0_","height":32,"cellHeight":43,"cls":["tg-tb","tg-clp","tg-td","tg-tbL","tg-tbT"],"prDivId":"pD_vv4-0","spacer":{"src":"http://pics.ebaystatic.com/aw/pics/s.gif","alt":"","href":""},"clkSrvId":"TH_CLK_SVCv v4-0","moutSrvId":"TH_OUT_SVCvv4-0","tdPfx":"t_c_vv4-0_","cols":1,"resizeOnLoad":true,"tblId":"vv4-0_tbl","imgPfx":"t_ivv4-0_"})); _r.put('vv4-0_js',new vjo.darwin.core.viewselector1.ViewSelector({"cmpId ":"vv4-0","icJsInstId":"ic_js_vv4-0","width":800,"height":800,"gtId":"gt_v4-0","mnImgData":[{"src":"http://i.ebayimg.com/11/!BbyZu4g!Wk~$(KGrHqUOKjsEq5TokYCvBK)o,PceoQ~~_3.JP G","alt":null,"href":null},{"src":"http://i.ebayimg.com/07/!BbyZi6w!mk~$(KGrHgoOKkUEjlLmVpKoBK)oZMGP-Q~~_3.JPG","alt":null,"href":null},{"src":"http://i.ebayimg.com/13/!BbyZo3!!mk~$(KGrHqEOKjUEq3-GyigbBK)oZtrndQ~~_3.JPG","alt":null,"href":null}],"spTd":"vv4-0_sp","hiResImgData":null,"thWidth":0,"zoom":false ,"thImgData":[{"src":"http://i.ebayimg.com/11/!BbyZu4g!Wk~$(KGrHqUOKjsEq5TokYCvBK)o,PceoQ~~_14.J PG","alt":null,"href":null},{"src":"http://i.ebayimg.com/07/!BbyZi6w!mk~$(KGrHgoOKkUEjlLmVpKoBK)oZMGP-Q~~_14.JPG","alt":null,"href":null},{"src":"http://i.ebayimg.com/13/!BbyZo3!!mk~$(KGrHqEOKjUEq3-GyigbBK)oZtrndQ~~_14.JPG","alt":null,"href":null}],"scJsInstId":null,"thHeight":0,"scrollCnt":0,"mnI mgId":"i_vv4-0","thJsInstId":"th_js_vv4-0"})); })();(function(){var _d=vjo.dsf.EventDispatcher;var _r=vjo.Registry;function $3(){return function(event){return this.catchElement(event);};};_d.add('body','load', function(event) { this.placeBdr(null, "b2_vv4-0_1", 1, "click"); },_r.get('th_js_vv4-0'));_d.add('body','load',function(event) { this.startLoading(); },_r.get('th_js_vv4-0'));_d.add('vv4-0_div','mouseout',function(event) { this.movingout(event); },_r.get('th_js_vv4-0'));_d.add('vv4-0_div','click',$3(),_r.get('th_js_vv4-0'));_d.add('vv4-0_div','mouseover',$3(),_r.get('th_js_vv4-0'));_d.add('b1_vv4-0_','click',$3(),_r.get('th_js_vv4-0'));_d.add('b2_vv4-0_1','click',$3(),_r.get('th_js_vv4-0'));_d.add('b2_vv4-0_1','mouseover',$3(),_r.get('th_js_vv4-0'));})();(function(){var _s=vjo.dsf.ServiceEngine, $se=_s.register;var _r=vjo.Registry;$se(4,'TH_OUT_SVCvv4-0',function (message) {_r.get('vv4-0_js').UpdateImgContainer(message); });$se(4,'TH_HVR_SVCvv4-0',function (message) {_r.get('vv4-0_js').UpdateImgContainer(message); });$se(4,'TH_CLK_SVCvv4-0',function (message) {_r.get('vv4-0_js').UpdateImgContainer(message); });$se(4,'TH_CLK_SVCvv4-0',function (message) {vjo.darwin.pres.buying.cmp.itempictures.ItemPictu res1.setSelectedIdx(message); });})();</script&gt;&lt;script type="text/javascript">vjo.ctype("vjo.dsf.FirePageLoad").endT ype();vjo.dsf.EventDispatcher.load(document.body); </script&gt;
ID:	1287929   Click image for larger version
ID:	1287930   Click image for larger version
ID:	1287931   Click image for larger version
Old 06-12-2010, 10:12 PM
  #79
ton2di
My Feedback: (182)
I'm starting to doubt my saito 125. I have been running an apc 15x8/14x10 on my h-9 p-51 and my friend flying his new h-9 p-47 with an OS 110FS-a with the same prop/fuel combo. (15x8 apc) with 15% omega is a bit faster than mine. For some reason even if our rpms on the ground are almost identical (8,700 on the ground- because of humidity) his engine will slightly unload more in the air ... I don't know the reason for this, but I'm thinking that his OS FSA110 engine has more power than my saito 125.
Old 06-15-2010, 12:15 PM
  #80
airraptor
My Feedback: (66)
ton2di are you running the muffler on the saito? Also you cant compare speed on a different plane. With no muffler you can expect about 300-400 more rpm on the Saito. All saito engines respond best with more nitro. I usualy run 35-45% in mine. 20% nitro is the lower limit to me for the Saito's. My Saito 125 on 45% is very close in power to the OS120AX with muffler both will spin a 13x11 APC at 11,300
Also run the 15% powermaster fuel i dont think omega is that great of a fuel could be wrong if your going to run 15%.
Old 06-16-2010, 10:42 PM
  #81
ton2di
My Feedback: (182)
Thanks for the advice airraptor. I will try a 30% fuel this weekend and see if there's a speed improvement... or if I could fly faster than the os 110 with a 15x8.
thanks,
ton2di
Old 09-12-2011, 08:05 PM
  #82
jriley1974
Going to maiden my H9 p-47 with APC 15x8 (Omega 15%). Engine has about 5 tanks through it on the ground. Any prop advise? Would a 15x7 be better for its first flight?
Old 09-12-2011, 08:13 PM
  #83
ton2di
My Feedback: (182)
Jriley1974,
Apc 15x8 should be fine. THat plane is very forgiving and is fun to fly. MAke sure you lean the low end needle after break-in because it will consume a lot of glow fuel at the original setting.
ton2di
Old 09-12-2011, 08:31 PM
  #84
mike early
mike early's Avatar
I really like the 14x9 3-blade with my 125 on warbirds....
Old 09-29-2012, 12:50 PM
  #85
GoNavy
My Feedback: (15)
ORIGINAL: w8ye
I have three Saito 125's and two Saito FG-20's
The APC 15 X 8 runs less RPM than a APC 16 X 6 on a 125
A 15 X 10 or 16 X 8 is too much prop for a 125
I realize this thread is old, but I found the results interesting and thought others might be interested in the results I had with the Saito 125. 65 degrees, 1450 feet asl, 15% nitro Wildcat Premium with 16% oil, after 80 ounces and about 90 minutes breakin. All readings rounded down to nearest 100; Static testing.
Zinger wood 16 x 6, 8500 rpm
Master Airscrew 4 cycle 16 x 6, 8500
Master Airscrew 4 cycle 16 x 8, 8400
APC 16 x 8, 8500
Zinger wood 16 x 6-10, 7300
Zinger wood 16 x 4 three blade, 8500
I did not expect the engine to do so well on 16-8's; Like W8ye I thought they would have been too much. (I calculate that the load of a 16 x 8 to be 133% the load of a 16 x 6 of the same design).
I want to run three bladers on a scale model, and 17inch diameter would be scale. Looks to me like I can go to a 16 x 5 or 17 x 4 three blade and still be within the engine's comfort zone.
I'm impressed with the Saito 125.
Reliable idle was 2100 except APC @ 1900. I have not touched the low speed setting; transition was flawless
Old 09-29-2012, 01:27 PM
  #86
ton2di
My Feedback: (182)
Hello,
What pane do you intend to put it in?
Ton2di
Old 09-29-2012, 07:53 PM
  #87
GoNavy
My Feedback: (15)
Twin Otter, 1/6th scale by John LaBelle, 132" wingspan, about 38 pounds.
Old 11-01-2012, 08:27 PM
  #88
kochj
Reactor bipe
20/20 YS fuel..
Master Airscrew 15x7 3-Blade don't have Rpms....
Pleased to say, the prop performed almost as my MA smintor 16x6 2-blade....
I had broke my other prop and wanted to fly...so I placed the 3 blade on it...
The MA 3 blade instructions says to NOT do violen snaps ect... with this prop on the engine...
I did some anyway....no issues.... ran out of gas and the gear needs reapair....
Old 11-02-2012, 08:03 AM
  #89
GoNavy
My Feedback: (15)
I ran the second Saito 125, on 15%, at 49 degrees, with same props as first engine turning about 100 rpms less than first engine at 65 degrees. Also ran the following:
17 x 6 Xoar wood two blade, 8200 rpm
15 x 7 MAS three blade, 8700 rpm
16 x 8 Zinger wood two blade, 7600 rpm
(Aside: the Xoar prop was a thing of beauty; it is the only prop I have ever had that came balanced, both tip to tip and hub to hub, out of the box.)
Old 07-14-2019, 06:22 PM
  #90
Jesse Open
Jesse Open's Avatar
Originally Posted by Hobbsy
J, you're using a very poor choice of fuel, get some decent fuel with an 80/20 syn/castor blend and you see about 9,200.
Two thumbs up!
