how to make a flowing checkerboard
#76
this didn't really damaged the plane, I have been able to remove the sticker easily.
but I'll give one advise here coming from my first experience using clear oracover.
DON'T PLACE CA HINGES AFTER COVERING. I made the mistake, and the CA when drying made fume inside the surfaces. This made grey zones at the position of the hinges.
#78
on the ailerons you can see grey clouds at the position of the hinges. I added the whitte strip to mask most of them, but they are still visible
On the rudder and elevator, I reduced the lenght of hinges so they doesn't extrude the wood, but there is still a small grey zone
#80
Banned
Hey Gator, have you experienced the problem with clear monocote and CA, or is it exclusive to Ultra? I knew CA would screw up canopy plastic, but never thought of clear covering.
#81
yes, I have seen it turn the transparents cloudy...I like to get alot of CA on the Hinge. I have even had streaks of CArun on the inside of the covering....G
#82
SALMONBUG -
So THAT'S what was in my rudder! I built up a rudder to test some transparent red covering, covered it, hinged it, and when I looked at it later it had haze on the inside, just as you describe.
Not to fear - I fixed it by reheating it with my hot air gun - Came out clear as can be. That was using monokote. Good Luck . . .
Spidey
Spidey
#84
Sorry. I've been too busy to take pics of the process....for one I was kinda W.A.G.'n it as I went along and also trying to get it finished before June....G
#86
that slash, its so random, let it looks like only a artist could pull it off and make it look good.
what with the graphics design contest on the giant scale thread my heads spinning
#87
It worked, reheating with eat gun made the clouds disapear.
here is my laser 3D with the new stickers aplied (dry) and ready for the maiden
#93
RE: how to make a flowing checkerboard
hey Gator, you asked that when i get my plane covered get it on here, well heres my Gator ( use products ) inspired covering.
click the link for thumbnails of larger pics.
http://www.philsrcworld2.fsnet.co.uk/capichepics.htm
heres a taster
heres a taster
#95
My Feedback: (15)
And I was proud of myself for laying out 1 inch and 2 inch monokote checkers basically by hand, I am not worthy of plugging your monokote iron in...
#98
heres my plane mid week...
don't add the trim after flying it for 2 1/2 months, it's bad luck.
in reality my prototype funfly wing for this plane has spars that were too soft. a simple dive ended it's good looks
