Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
TMMY Scale Composites 35% scale Cessna
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 05-05-2011, 08:57 PM
  #1051
ausfly47
Default RE: TMMY Scale Composites 35% scale Cessna
Where are my photos. I have tried loading them both ways, they say they have loaded but where are they.
Regards.
Martin.
Old 05-05-2011, 09:07 PM
  #1052
ausfly47
See if this works or i give up, been trying all day.
My photos must be somewhere.
If they all suddenly appear i appollagise.
Regards. Martin.
Old 05-05-2011, 10:40 PM
  #1053
ausfly47
One photo wooo hooo.
See if these turn up.
Regards.
Martin.
ID:	1604904   Click image for larger version
Old 05-05-2011, 10:45 PM
  #1054
ausfly47
Hello.
Now it is sort of working.
Regards.
Martin.
ID:	1604906   Click image for larger version
Old 05-06-2011, 04:57 AM
  #1055
mario tavarez14
My Feedback: (37)
mario tavarez14's Avatar
Nice airplane you will enjoy this big bird
Old 05-06-2011, 06:15 AM
  #1056
mario tavarez14
My Feedback: (37)
Nice airplane you will enjoy this big bird , what side engine do you install , a good friend of my have the same paint skin , all hitec 7955 servos and DA 150 for engine , also make sure to post some video please , check YouTube and search my lates video with my cessna in Florida , search for makos field part 2 and enjoy best regard Mario Tavares
Old 05-06-2011, 10:02 AM
  #1057
TSHARK203
My Feedback: (206)
TSHARK203's Avatar
ORIGINAL: ausfly47
Regards.
Martin.
Your bird looks great. Nice colors. What wheels are you using on yours?
Old 05-06-2011, 10:07 AM
  #1058
TSHARK203
My Feedback: (206)
TSHARK203's Avatar
ORIGINAL: mario tavarez14
hey mario are you going to joe nall next week?
Old 05-06-2011, 10:18 AM
  #1059
Adrian_CH
Hello together,
Tommy will send my Plane next Week to Switzerland.
I have all Servos JR HV DS8921 with a Powerbox Royal, 2 Futabe 6014HS Recivers.
I`m not sure witch Motor,my Favorite is the ZDZ but i will see....
Greetings
Adrian
Old 05-06-2011, 01:28 PM
  #1060
slevin1
My Feedback: (23)
I'd love to see somebody install a Hacker A200 outrunner electric motor.
Saul
Old 05-06-2011, 02:54 PM
  #1061
mario tavarez14
My Feedback: (37)
TSHARK203 SORRY JOE NALL , NOT FOR THIS YEAR, , NEXT YEAR
Old 05-06-2011, 03:44 PM
  #1062
ausfly47
Hi TSHARK. The main wheels are the 7'' Sullivan with brakes and the front is the 6'' Sullivan.
Hi Mario. I also have the DA 150 in the plane. I will need some more nose weight though.
Thank you bothfor the nice comments.
Regards.
Martin.
Old 05-06-2011, 03:55 PM
  #1063
Ozflyboi
Hi Martin,
Long time no speak. How far off is the Cessna from being flight ready?
The new colour scheme looks great.
I am surprised that your Cessna is Tail heavy as mine did not require any additional weight to balance.
It will be interesting to know how much your Cessna weighs in at.
Regards,
Steve
Old 05-07-2011, 10:23 PM
  #1064
TSHARK203
My Feedback: (206)
TSHARK203's Avatar
ORIGINAL: Ozflyboi
Hi Martin,
Regards,
Steve
My thoughts exactly. I had to move my batteries back off the fire wall as well to balance out. The plane should be pretty much spot on if you are using the motor combo Tommy says to use. But noe the less once you get it done and flying you will love it.
Old 05-09-2011, 05:37 PM
  #1065
ausfly47
Hi guys.
The 3xfive cell battery packs on the engine box aren't enough to balance the plane.
I bought one of the E-Z balancers to balancemy planes now.
I used to balance my larger planes with a friends help, since i got the balancer i have
gone back and re balanced some of my planes to find out how much more accurate the balancer is.
As mentioned in a recent post, The Cessna needs the centre of gravity to be rectified, Pilot belted in,
and re do the wires in my wing.
Then ready to fly.
Regards.
Martin.
Old 05-09-2011, 06:07 PM
  #1066
Ozflyboi
Hi Martin,
Just a suggestion why not use MPX (Multiplex type) connectors in your wings for the Aileron and Flap servos.
This is what I am using in my big cessna. Just one connector will enable two servos as it has six pins and is polarised to prevent reverse connection.
Then all you do is solder your servo extensions to these connectors, but be sure you match the pins on the other connector to the respective servo/s. Care must be taken when soldering these up to avoid reverse polarity.
They work really well and are a great connector.
I heard you have not used the Axles that me we made for you? Were they not up to your standards?
The axles we made for my Cessna weren't perfect but structurely they are sound and I have not since had any problem with them.
Regards,
Steve
Old 05-10-2011, 06:48 PM
  #1067
ausfly47
Hi Steve.
The standard of the axles was good thank you, the problem was they were too short
there was no room for the nut on the undercarriage side.
I was going to use the mpx plugs and i had soldered them to the wiring on the plane side,
a freind of mine is right into RC and flies in the UAV challenge, the feed back on most plugs
especially the ones we use as standard extension leads with gold pinsetc have a short life span in regards
to pluging them in and unpluging them, so i am going to use the Ashloc plugs which have a
lot better life span and better conection.
Regards.
Martin.
Old 05-10-2011, 07:39 PM
  #1068
Ozflyboi
Hi Martin,
I think I know why the axles were too short. I know Tommy has updated the landing gear on these Cessna's and I wonder if by chance your new Cessna had this included when it was being made. If the struts are thicker alloy to the original then that would explain it.
If that is not the case then I am unsure as I simply copied the exact dimensions from my axles I am using in my Cessna along with the brakes assembly.
I am pretty sure I included photos earlier on in this thread showing the installation for reference.
With the wheel brakes I progammed the unit for Semi Proportional brake type and I am using a slider on my radio to activate this.
I recently had the opportunity to fly off sealed runway which was a good test for the brakes. They performed as expected and are really a necessity when flying off shorter runways.
I will definately look up those Ashloc plugs.
Regards,
Steve
Old 05-17-2011, 02:30 PM
  #1069
spidernad
My Feedback: (28)
spidernad's Avatar
Does anyone in the US have one of these planes that they are not going to finish that would consider selling or trading? I've been following this thread and would like to try to get one.
Old 05-20-2011, 12:34 PM
  #1070
spidernad
My Feedback: (28)
spidernad's Avatar
ORIGINAL: Adrian_CH
Hello together,
Greetings
Adrian
Hello Adrian.
What is the best way to communicate with TMMY. I am interested in the big Cessna and sent an email for info but no reply yet. I've been reading this thread and it seems like it's hard (or slow) to get a reply from them. Is email the best way, or ?
Dan
Old 05-20-2011, 12:49 PM
  #1071
huck1199
huck1199's Avatar
Martin,
Nice plane. What is the little grey car behind the plane?
Old 05-23-2011, 12:35 PM
  #1072
spidernad
My Feedback: (28)
spidernad's Avatar
OK, so I did get an email from Tommy with the info on the plane and shipping etc. It took 5 days (3 business days) so thats not to bad. I will order one and try to be patient.
Old 05-23-2011, 04:24 PM
  #1073
spidernad
My Feedback: (28)
spidernad's Avatar
So I was researching Cessna 182 color schemes and thought I would post my findings to save anyone else the trouble. Any mistakes just let me know.
The order is Photo:
1. 1997-1999 Cessna 182
2. 2000
3. 2001-2002
4. 2003
5. 2004
6. 2005
7. 2006
8. 2007
9. 2008
10. 2009
11. 2010-2011
ID:	1613653   Click image for larger version
ID:	1613654   Click image for larger version
ID:	1613655   Click image for larger version
ID:	1613656   Click image for larger version
ID:	1613657   Click image for larger version
ID:	1613658   Click image for larger version
ID:	1613659   Click image for larger version
ID:	1613661   Click image for larger version
ID:	1613662   Click image for larger version
Old 05-23-2011, 04:34 PM
  #1074
ausfly47
Hello Huck1199.
The little car behind my Cessna is my fathers restored Morris Minor.
Regards. Martin.
Old 05-23-2011, 04:45 PM
  #1075
spidernad
My Feedback: (28)
spidernad's Avatar
Here are a few older ones.
Photo:
1. 1969 Cessna 182
2. 1975
3. 1978
4. 1979
ID:	1613666   Click image for larger version
ID:	1613667   Click image for larger version
ID:	1613668   Click image for larger version
