Old 05-03-2008, 01:20 PM
  #10776
Kmot
My Feedback: (24)
Kmot's Avatar
Old 05-03-2008, 04:39 PM
  #10777
mike boxtall
I saw an add for the Turbo Head muffler and was wondering if anybody has had any experience with them on a 125? Also what is it that they are supposed to do?
Old 05-03-2008, 07:01 PM
  #10778
linkadrip
linkadrip's Avatar
turbo muffler..
http://www.rcuniverse.com/forum/fb.asp?m=7318581
http://www.rcuniverse.com/forum/fb.asp?m=7318744
http://www.rcuniverse.com/forum/fb.asp?m=5626245
http://www.rcuniverse.com/forum/fb.asp?m=5729773
I could go on but all you have to do is scroll to the bottom of this page were it says search this thread and type in Turbo muffler and you will get a page with all the post that realate to it.
Old 05-03-2008, 10:53 PM
  #10779
s10junky83
I posted about the idle on my saito 100 a few days ago and it dies at all settings exept above half throttle. It will idle for 5-10 seconds before it dies at all settings. If I leave the glow starter on it won't dies so my question is could it be my GLOW PLUG? What are the stmptoms that the plug is bad in a four stroke? The coil is in great shape but could the catalyst be burned off? What would cause this? This is the saito SS plug and it has no carbon build up on it!!!! PLEASE HELP fast, I want to fly tomorrow!!!!!!!!
Old 05-03-2008, 11:20 PM
  #10780
NM2K
My Feedback: (14)
ORIGINAL: s10junky83
You need to give us a bit more information before we can help you. It is not uncommon for a new out of the box engine (never ran before) to not idle or transition properly, even with a perfect glow plug.
1. How much running time has the engine accumulated?
2. Did you break the engine in according to the instructions with the recommended fuel, prop and glow plug?
3. what size prop are you using?
4. which fuel are you using?
5. How is the fuel tank mounted? Is the centerline of the fuel tank higher than the center of the carb's rotating barrel?
Ed Cregger
Old 05-04-2008, 08:49 AM
  #10781
N1EDM
It almost sounds like your LSN is set just a bit lean.
And yes, the plug could be bad. I've had plugs go bad on brand new engines after a few runs, possibly because some machining by-product got into it and contaminated the element. Replace the plug and it runs OK.
After checking all the issues such as tank position, etc., see if the LSN could be adjusted, only 1/8 or 1/16 turn at a time.
Just my $.02
Bob
Old 05-04-2008, 04:00 PM
  #10782
Sharpeye22
Sharpeye22's Avatar
Perhaps someone can help. I want to pipe my exhaust out the bottom of the cowling so as not to cut it up sticking the muffler out the side. I have a sato 82a installed inverted. I found a flex pipe but it does not have a pressure tape for the fuel tank or threds on the other end to install the stock muffler. The engine has 12mm female threads into which the muffler is installed via a short pipe.
Larry
Old 05-04-2008, 04:38 PM
  #10783
linkadrip
linkadrip's Avatar
Sharpeye22
you might consider a turbo muffler it has solved my problem of cutting up my cowling. and i'm going to purchase another when i get the funds for another saito for my U Can Do 46. So i can keep my cowling intact as much as possable. Just a thought or you can tap the flex pipe for a pressure nipple.
Old 05-04-2008, 05:00 PM
  #10784
Sharpeye22
Sharpeye22's Avatar
thanks I will look into that option.
Old 05-04-2008, 09:20 PM
  #10785
s10junky83
thanks guys!!! I replaced the plug this morning and she flew like a champ!!!! Thanks Again
Old 05-04-2008, 11:26 PM
  #10786
Shack
Just a few days ago a friend of mine who has a 82a on a Piper Pawnee has the flex pipe which he tapped for the nipple. Even without the muffler it wasn't all that loud. The flex pipe broke from metal fatigue it should be supported somehow on the end [some kind of "soft mount?]
Shack
#580
Old 05-05-2008, 08:08 AM
  #10787
bzizzi
My Saito is Newest version and I cannot find the low speed adjustment,I think they did away with it because there is a hex head
insert were the adjustment should be and it is not adjustable,it runs awesome and idles fine though.
Old 05-05-2008, 08:31 AM
  #10788
w8ye
w8ye's Avatar
What size is your Saito
Old 05-05-2008, 08:35 AM
  #10789
Sharpeye22
Sharpeye22's Avatar
Do you think that taping the flex pipe will provide enough pressure for the tank. I can not tell from the picture of it, but it looks like a open pipe with no restrictions as best I can tell.
Larry
Old 05-05-2008, 09:10 AM
  #10790
bzizzi
It is a Saito .82
Old 05-05-2008, 11:32 AM
  #10791
Vinnie6
Vinnie6's Avatar
ORIGINAL: Shack
Shack
#580
This is how I supported my flex pipe in my GP Super Skybolt ARF with a hose clamp. I used a chunk of plastic from a servo wheel to serve as a washer between the hose clamp and the fuselage bottom.
Old 05-05-2008, 01:23 PM
  #10792
swixtt
swixtt's Avatar
any chance we can see bigger versions of those pics?
Old 05-05-2008, 01:52 PM
  #10793
Vinnie6
Vinnie6's Avatar
ORIGINAL: swixtt
Try this link to another thread where the pictures are normal. I need to learn how to copy pictures from one message to another.
http://www.rcuniverse.com/forum/fb.asp?m=7364163
Old 05-05-2008, 02:58 PM
  #10794
TheDenter
TheDenter's Avatar
Hi everyone,
I finally got to maiden my P-51 on Saturday.................it's back in one piece!!!!
It seems slow though, what recommendation for prop size would ya'll have for the Saito 100?
Thanks a bunch,
Tom
Old 05-05-2008, 04:15 PM
  #10795
Ken6PPC
ORIGINAL: TheDenter
Hi everyone,
Thanks a bunch,
Tom
I use a 15 x 6 MAS on my Saito 100. Coincidentally, my 100 is on my 60 size P-51!
Old 05-05-2008, 04:43 PM
  #10796
TXRCPilot
Older Saito 80 has a strange problem. I could use any advise.
I have a Saito 80 mounted inverted in my World Models Clip Wing Cub. It starts easily, run fine up to half throttle, but not beyond that. I've had the cowl off - with no difference. I do not think it's a over heating problem. I've had a couple of Saito guys, try to tune the engine all to no avail. They are puzzeled too. I'm at about 2 1/2 - 3 turns on the high speed, and about 2 1/4 on the low spped. Transistion is good as long as you I don't advance past 1/2 throttle. It then start to run REAL rough and wants to quit. It WILL then Quit - even with a glow starter attached! If I run the throttle back to idle or so, it will start to run again. We move the back pressure tap closer to the exhause (thinking that might help) as I have an extended pipe on it, rather than the standard muffer. I've had it rebuilt/adjusted about a year ago from an Authorized Service center here in Texas.
Any clue as to why it will not run past half throttle?? Oh, I've tried different fuels to eliminate that as an issue. I generally run Omeaga 4 stroke fuel, but a friend loaned me some YS 20/20 to see if that would help. No difference. Plug is the OS type F, for 4 strokes.....
Thanks David W.
Old 05-05-2008, 05:17 PM
  #10797
fredira
Hey Sigman
I have a question for you.
How much thrust does a Saito .56 have?
It is the newer one. I have a Edge 540 with a all up weight
of 5.5 lbs. What do I need for a prop to make this engine
hover this plane? Or is it to small. Any advise would be great.
Thanks Fred
P.S If any body knows please let me know.
Thanks again
Old 05-05-2008, 05:36 PM
  #10798
Sharpeye22
Sharpeye22's Avatar
I have settled on the muffler offered by "Performance Specialties". http://www.pspec.com/default.asp It comes with a 90 degree elbow, a pressure tap, and the ability to route exaust out the cowle via silicon tubing. According to the dimentions provided it should all fit nicely inside the cowle. It has about the same dimentions as the TurboHeader Muffler. All for $59.00 shipped.
Thanks to all for their input.
Larry
Old 05-05-2008, 07:21 PM
  #10799
Michaelh
Here some video of a .72 and a .82 in profile desighns I took this weekend. Music may be a bit much for some so turn it down.
http://www.vimeo.com/975813 Gotta get some of my .82 and more of the 1.80 Hopefully this weekend?
Old 05-05-2008, 07:28 PM
  #10800
Kmot
My Feedback: (24)
Kmot's Avatar
ORIGINAL: Sharpeye22
Would you like to listen to a Saito 120 with the PSP muffler?
http://media.putfile.com/Saito-120-On-The-Test-Stand
