Reaction 54 Jet Kit
#1076
RE: Reaction 54 Jet Kit
I do the same thing as Tommy with all my connections. I've found that dental floss works great. It threads through the connectors real easy.
Cheers,
Cheers,
#1077
I use these little wire ties. If I'm all out of those I use dental floss.
(Sorry for the bad pic... my camera batteries died before I could get a good one)
#1078
My Feedback: (10)
OK guys I have some news for you - My kit arrived today and it's great. More importantly, Galen let me buddy box and I flew his R54. My first jet flight ever!!! It flew great
and I had a wonderful time. It's motivating me to get my started (and finished)!!!
#1079
My Feedback: (43)
WA
More good news - Chuck Kentfield put the maiden flight on his R-54 today. It flew great!! He was doing loops, Rolls and split S'es all on the first flight. Or maybe it was nerves doing all those maneuvers????
Anyway Look at the post flight happy face!!
Congrats Chuck!!!
Bob did great on his first turbine flight. I suspect he'll set a new build record on the R-54.
Galen
Congrats Chuck!!!
Galen
#1080
ID
Hi Dave,
I noticed that you switched out your braking system. With the UP6 valve requiring another servo, are you slaving it to one of your already occupied 9 channels on your 9Cap?
We flew my maiden yesterday - WOW! Beautiful bird. My son and I waited 5 months, everyday staring at it while making "jet noises." Watching the videos was getting old. The experience was thrilling in "real time."
Anyway, I'm going to be flying mostly on pavement and would prefer main wheel brakes. I'd appreciate any insight on this.
Steve
Steve
#1081
It was a gorgeous day here in Oregon yesterday and there I was cutting fin sockets and landing gear blocks for Delta Vortex kits, all the while thinking how nice it would be to be out there flying. Little did I know that two separate R54s were making their maiden flights just one state to the north and one state to the east! I'm really happy for both of you, Chuck and Steve, and hope you have a great summer of making (real) jet noise.
Galen is one of the "good guys" up here - thanks for giving Bob a taste. What a motivator!
#1082
ID
A little oversight on my part - I want to thank Molar Mender (Roy Holt) for helping me with our maiden flight. He's very knowledgeable, a great guy and I appreciate the time he spent with us. Thank you Roy.
#1083
My Feedback: (69)
ORIGINAL: samo
Hi Dave,
Steve
Hi Dave,
Steve
Congrats on the maiden!
Nope. The valave is on CH5 using the right hand slider. The flaps are now Y harnessed and I used the Hitec servo programmer to get them sync'd.
Dave Rigotti
#1085
Yes, Gary does make a tank for the reaction. It hold about 2 litres. I got mine with BVM fittings. Makes for a bullet proof instalation. (No rubber bungs to leak).
I just emailed him.
regards
I just emailed him.
regards
#1089
My Feedback: (69)
ORIGINAL: Shok
Here is some video I had of Barry's 54 last Saturday in Austin
http://media.putfile.com/Reaction-54
Dave Rigotti
#1092
ID
Thanks for the info Dave!
I created a mix for the proportional valve so that the servo is activated with down elevator only when the retracts are down. That way my right hand stays in one place. I'll also have more travel with the down elevator vs the slider. Hopefully it will work once the valve arrives. BTW, do most use the electronic switch or the proportional valve?
Thanks again,
Steve
Thanks again,
Steve
#1093
It is hard to beat the UP-6 (proportional valve). I have both the UP-6 and the JetTronics (electronic) valve and find the UP-6 easier to use and adjust. The problem I have with the Jettronics valve is leaking. It is not the fault of the valve, it just requires an absolute square edge cut of the tubing in order to get a really good seal on the Festo valve. I am not that good and sometimes I get a leak and have to keep cutting and replacing, cutting and replacing. Eventually, I am gonna perfect using it and will probably change my mind, but for simplicity sake it is hard to beat the UP-6.
Mine is set up with a slider switch. I like to pull up to the runway with my Panther, set the brakes, spool up the turbine, and let her go. Looks like a carrier take off!!!!
Tommy
Tommy
#1094
ID
Thanks Doc,
....'and have to keep cutting and replacing, cutting and replacing".......
I hope you're not a surgeon??
I appreciate the help from those [8D] in the know,
Steve
Steve
#1097
My Feedback: (45)
LA
I think it is hard to beat a simple on/off button switch operated by a mini servo. Set the gas pressure in the tank to provide the kind of braking you want and forget it. A small air tank will provide more air than you will ever need in a single flight.
#1098
ORIGINAL: samo
Thanks Steve and Andrew for letting me fly your Reaction-54. I trully enjoyed your hospitality.
Roy
First edit -- It wouldn't upload the photo so I will work on my laptop and get it squared away.
Second edit -- Finally got it
#1099
Thanks to Bruce Tharpe for a great flying jet. I was finally able to test fly my R54 today after a series of weather (dry grass) problems and a minor engine problem. As expected from other accounts, everything went perfectly. Takeoff in about 150' and landing roll less than 100' with a 10mph headwind.
Bruce, this is one great flying machine!!!
Dennis
Dennis
#1100
Dennis - I love the Snowbird 54! This maiden's been a long time coming - seems like you've that beauty finished for quite some time. As they say, patience is a virtue And WOW - what a field! Thanks for the compliments on the kit, but all the congrats really belong to you. Great job.
