*** CLUB SUPER TIGRE ***
#1077
RE: *** CLUB SUPER TIGRE ***
G, you'll be interested to know that my Saito .80 and a couple of other engines actually have compression that is too high for Diesel use. When run on Davis Diesel fuel the .80 sound like a Black and Gold grenade if you try to open the throttle beyond 5,000 rpm. There is a device called a Lavona cell that can be used to reduce the compression on my .80 but I don't have one.
#1081
My st90 has not much power on the top end. I've tried adjusting and readjusting the carb to no avail.I want to try a different carb on my st90.Has anyone tried this if so what brand/size is recommended?
#1082
My Feedback: (14)
ORIGINAL: critt48
If your G90 carburetor is working as it should, another carb will not provide you with anymore rpm without sacrificing fuel draw, etc.
What kind of rpm are you expecting with which prop? There is a Tach Readings forum on RCU. There you will find information regarding others' results with this engine that will tell you what to expect regarding performance.
Ed Cregger
#1083
I haven't tried a tach on it but the idle is ok,midrange is ok but it seems like thats all there is for throttle. The power doesn't improve anymore after about 60% throttle. I have never owned a st before but many people in my club say all st are the same.
#1084
My Feedback: (14)
ORIGINAL: critt48
ST engines are of an older design. They were designed with different uses in mind than 3D flying.
What this means is that while the carb works fine for ordinary flying of a decade or two ago (once the engine is fully broken-in), it is not going to throttle like a modern day 2-stroke that has been designed and built especially for 3D flying. Nor will it throttle like a four-stroke glow engine, which is far more linear in throttle response than a non 3D designed two-stroke engine.
If you intend to 3D your ST engine, then you might find a serious advantage in switching to a slightly smaller Sanye carburetor for your engine. Yes, an OS carb might be even better, but remember to buy the next size down in total air flow. Doing so will eliminate the problem(s) that you may be having. The basic ST engine (other than individual units with warranty defects) is a terrific engine and will outlast many other engine brands over the years. I dare say that many ST engines that are discarded or abandoned today have been so because the owner was not aware that it takes a considerable bit of running before the ST engine reaches its peak perfection. Trust me, that peak perfection is there for those with patience. Sorry RCU. I didn't mean to curse by saying the word patience. <G>
If all you are hoping to do is just fly around in a sport-like manner (no serious 3D), just leave the engine as it is and fly the dickens out of it. The more running time that the hard metaled ST receives, the better it will run until you will eventually forget about changing the carb. This could take from fifty to one hundred flights. If you can't wait that long, go ahead and replace the carburetor. This will not break it in any faster, but you won't notice the lagging throttle response as much.
Ed Cregger
#1085
ORIGINAL: fabmaster911
Hey ya'll, where can I get head shims for my G90. I understand I need 3 of them to run 15% fuel. I don't want to haul around 2 jugs of fuel and i'm hoping I won't lose power. I would also like to find an extension for my stack to get the muffler further away from the engine. Any ideas?
#1086
I have been doing a lot of engine testing these last few years and I have never gotten my hands on a Super Tigger . Any word on what to expect and anybody have one to trade/borrow for a similar sized (40 something) engine in great shape? I just loves to speriment.
#1087
ORIGINAL: jeffie8696
My new, out-of-the-box experience with the G-61 ringed engine has been as good or better than any other brand I've owned. Not only would I not hesitate to buy another Super Tigre engine, I really can't understand all of the complaints about them that seem to be common folklore.
A G-40 ringed for $59.99 or a G-45 ABC for $74.99 new from Tower Hobbies will tell you everything you'd want to know about new Super Tigre engines. I can't imagine why more folks aren't flying these engines.
#1089
My Feedback: (14)
What do you have to trade that is worth about $60? A NIB Fox .45 perhaps? I'll send you a NIB (from Tower directly) ST GS-40, if you are so inclined.
Ed Cregger
#1091
#1092
My Feedback: (14)
Has anybody drilled and tapped a G90 for a pump? If so where did you go in and how well did it work out. Thanks
It depends upon the mood I am in and where the engine has the most convenient amount of "beef".
If the backplate screw hole/boss isn't vented into the crankcase, or easily made to do so, I drill a hole in the center of the backplate, tap it for the thread of the pressure nipple and install with Loc-Tite. Then, after the Loc-Tite has had a while to set up, I grind any protuberance that is sticking into the crankcase beyond the face of the interior backplate wall. Got that? 8>
Ed Cregger
#1094
KS
I have 2 S T and i absolutely love them both exspecially fro the price.
I have a 90 in a Little Toni and that thing flies great. The only problem i have with it is I get some air bubles in the fuel tank which i think is mainly an issue with the plane its self. My other engine is a 45 in a 40size model and it has great torch for 3D flight and i haven't had any problem with adjustment the only thing i have figured out is you will need to adjust the low idle but it isn't that hard.
#1095
ive heard its relitivly easy to convert this st s3000 to normal petrol/gas fuel, does anyone have a link to somewhere i can have the conversion done
#1096
ORIGINAL: qldviking
why go to the expense of an ignition system? just use an on boad glow driver if you need to. I just use $ stroke glowplugs with and idle bar, and rarely have a dead stick unless I run out of fuel. I have 7 big ST's, from 25cc to 45 cc and they all un like swiss clocks. Again, I dont run nitro at all, just methanol and 12% synth oil
#1098
OK, Super Tigre espertos, what is the G20 .23's favorite prop? I know these were popular engines in their day and that there's probably a prop or two that they like best. It seems more like a bored out .19 class engine than a small .25, so I was thinking 8x5 or 8x6. I just received this used example and it has superb compression. I can't wait to run it.
David
David
#1099
My Feedback: (14)
ORIGINAL: rainedave
David
David
For general sport flying a 16x8 to a 18x8.
I broke-in my G2300 running an 18x8 with the stock muffler, stock glow plug and 5% S&W fuel with 50/50 synth/castor mix. At that time, the pattern boys had become interested in this engine and some were flying it in competition with an 18x8 and resonant exhaust system. My G2300 did not seem to mind the 18x8 right from the start and never displayed signs of struggling with that much prop. A beautiful engine the G2300.
Ed Cregger
