My Feedback: (7)
RE: Welcome to Club SAITO !
I would like to be a Saito Club member. Original 30 (open rockers) 2 40's, 2 45"s, 56, 60 twin, 80 and 91. 100 on order.
JimO
JimO
VA
ORIGINAL: stallwart
Once the engine is broken in, you'll have plenty of flying time with an 8 oz tank. I generally fly for 10 minutes at a time and usually only refuel between flights because it seems sensible. I estimate 20 minutes with moderate throttle settings with your tank.
Does this sound about right to others?
ORIGINAL: ILv2Xlr8
What size tank should I use for a Saito 82 that I'm putting on a [link=http://www.nitroplanes.com/yak543d5056n.html]Yak 54[/link] ?
The plane came with an 8.3 oz tank, but I think that may be too small for this size engine.
Since everyone is showing off their saito's, here is one of my 50GKs on a Sweet'n'low:
Sounds good to me!
Also take into consideration the weight of the plane. A 6pound plane gets great economy on the .82 with a 14x4W.
IN
ORIGINAL: Michaelh
Sounds good to me!
ORIGINAL: stallwart
ORIGINAL: ILv2Xlr8
SC
Advice needed....
Have run 3 tanks thru my test- stand mounted 82a; adjusted all according to instructions. Max rpm's are 8800. Transition is very good. It will idle scary-slow at 1700. I expected about 9800 rpm max. I'm running an APC 14-6 Pattern prop; am I expecting too much?
The Pattern prop has a wide blade, the Sport prop has a narrow blade but isn't offered in a 14-6; I wonder why. Since my 72 turns a 13-6 Sport at 9800, I thought the 14-6 would be ideal on the 82a.
I will be running the 82a on a Senior Slo Motion [about 7 lbs.]
Shack
# 580
Shack
# 580
michaelbbbb #603
JimO #604
I think that the moderators should be given some Saitos as gifts for the big party. What do you think, Jim? I need a .91 myself, and any radials would be most welcome.
JimO #604
VA
ORIGINAL: Shack
Advice needed....
Shack
# 580
Advice needed....
Shack
# 580
They do have a 14x6 sport also. The 14x4w works great though as said. Can tone the nitro down with it.
Guy in another forum posted 10,000 with 30% on the APC 14x6
http://www.apcprop.com/cgi-bin/store...c=6a&product=+
My Feedback: (7)
ORIGINAL: blw
michaelbbbb #603
JimO #604
michaelbbbb #603
JimO #604
SC
ORIGINAL: jdr43
What is a Senior Slo Motion ? and who makes it ? Just curious.
It's one of the Simitar series designed by Bill Evans. This one was in the '93 AMA mag.[build from plans]. AMA can provide plans & foam wing cores.
I built one in '93; best flying plane I ever had. Very easy to build.
Shack
# 580
Hey, sign me up for the club too...
Saito 100
Saito 150
The 100 is destined to go into my Great Planes Super Sportster 60 which is scheduled to be built this fall/winter. What prop(s) do you recommend for this engine? I just obtained the 150 attached to a Goldberg Ultimate biplane, from a member of my club who is getting out of the hobby.
Saito 100
Saito 150
OH
ORIGINAL: xlr82v2
Saito 100
Saito 150
Saito 100
Saito 150
Ken,
I like the 14x8 APC on my 1.00. I use a 16x8 on my 1.80. I am not sure about the performance on the 1.50 since I don't use that engine.
Maybe it's a 18x6 not 16x8!
Jim
Jim
On my ultimate Graupner 22% 1400mm 54 inch wing with my !80 I use1a 18*6 which is the bigggest size prop possible for that motor
It give very good slow tractor pulling power with such a low reving low pitch and big prop more like a helicopter blade
A 16*8 prop on the same plane with a 180 could risk to over speed the plane and would be a better prop for a fast flying heavy wing loading war bird Mustang spitfire
The type of plane tend to dictate the prop with a lot of guys on pattern with Saito 180 claiming to use 17*18 or 17*10 inch as the preferable prop
I susspect for ultimate class plane 17 t 18 inch would work best with Saito 180
I don't have a Saito 100 so cant say about that engine
Balsaeater
balsaeater
Balsaeater
balsaeater
OH
ORIGINAL: RC Specialties
Ken,
Jim
Ken,
Jim
VA
http://saito-engines.info/prop_sizes.html Good place to start , I think like said above its all about the type of plane and type of flying you do.
You have to find a prop thats fits you personally.
I have more props stocked now then my LHS does.
ORIGINAL: Michaelh
A pefectly good APC 16X6 prop and i lost the tip off it in a prop strike i'm wondering if i can just take the prop and make the other blade the same and balance it and use it again anyone takin the risk and done this with a prop i lost about half an inch or less of one blade tip.
WI
I have nicked the tips on a few props. I shave a little off the opposite side and re-balance. I am not sure if this is safe or not, but I have done it. I have never re-used one that was missing 1/2".
Clud Saito member #591
MI
I have done it, i built a jig that hooks to my grinder and it trims them even. i balance them and use them again. No problems with the 4-5 i have done.
I measured the amount that got nicked broke of the tip it's little over a 1/4 inch so i might try removing the same amount off the other side and using it with caution..
Hey Hobbsy,
I don't have that many but I do have a nasty one, it is a Barkley Speedmaster 10-10 with replaceable blades. I actually had this on a control line corsair about 25 years ago , but never flew it. I wish I never ran it , it was new when I got it and already older than I could figure out.
ORIGINAL: linkadrip
I can relate to that i've been to two hobby shops here lately and i have more props then they do in certain sizes and brands whats reall a bummer is when you get a new prop balance it put it on and only get one flight with it. Arrg how frustrating. Guess i have to buy more of that one size if i continue to have prop strikes. Tower is making a killing off me on props.
ORIGINAL: Michaelh
Problem isnt clearance. problem is the wind blowing 15 to 20 mph gust and trying to land crossways on a runway that doesn't face into the wind. I was hovering about 2 feet off the ground and the gust dropped suddenly from 20 to 15 real quick and the plane came down hard on the landing gear and the prop clipped the ground.
But trying to expalin to the people who grade the runway that the wind blows from the east to west here seems to be a lost cause. So as they say if you want something done right you have to do it yourself.. if we had a runway that faced the correct direction there wouldnt be a bunch of broken props. But learning to land in a cross wind is tricky getting better at it. or the other thing is just dont fly when the wind is blowing but usually it is.
So i have to take a weekend and go get a railroad tie load it up in my truck take it out to the field and hook it up and drag the ground to make a runway that will face into the wind then i dont think there iwll be anymore issues with props nicking the ground trying to land sideways on a runway that is only 50 feet wide..
