Official Tamiya TT-01 Thread
#1176
NJ
Would anyone in here say that foam tires are better than rubber ones? I've heard else where that foam will last longer... Is this true?
#1177
ORIGINAL: joeyhatch11
#1178
some other brands making good hop-ups also except tamiya for this chassis check them out,one i preffer is gpm racing it does a good job on this,except the shock he made all others are good.
#1180
I agree, i prefer foams, unless i drift, then i like to use rubbers with foam inserts taped up.
RiCeY i am running a Trinity Revenge of the monster motor (27t i think)
#1181
Yeah when drifting I use the rubbers that came with the TT-01D they seem to work pretty well.
If you want a lot more power/speed you can go a much lower turn motor with the TT-01. All you need to do is get an ESC to suit and be a bit more carefull to save the gears ie no full throttle off the line with the foamies on (its ok with the drift tyres on because they slip and dont load up your gears).
Im running a 9 turn and so far have gotten 60kph (37mph) out of the TT-01 and it does high speed drifting pretty well
#1182
nice, what sort of ESC and motor would you reccomend me getting, i would probably be racing and drifting with it.
what sort of ESC ad what make of motor are you running, and how much do they cost.
Also if i went to fast motors what gears would i need ?
thanks luke
#1183
that one if for me,try to find from ebay a novak tc2 esc or a tekkin 411,used or not,the will give as much power as you want for race only.as for motor a revolution one will do the job try use the 12x1 high speed version.
#1184
TT-01D - Team Atlas Modified Excel 9 Turn - PCLine No Limit ESC - 55T/25T
The motor was (in Aus dollars) $60 and the ESC was $80 and I had it geared for max top speed
#1185
Banned
I'd want to get a tt-01r and out my neo 3-star in it, and drop a 5700 or 7700 in my evader![X(] nice set-up for sure it'd cook!
, im seriously lookin into the tt-01r
#1187
WA
WoW![X(] WHen i created this thread the only people that used to post was me and bigmik! How it has grown!![Big Grin](images/smilies/biggrin.gif)
I still didnt pick up that pinion and my tt-01 is still in pieces...
#1188
Thanks for your help guys.
RiCeY where did you get your ESC and Motor from, or where could i get my hands on them, because they sound like amazing value.
thanks a lot Luke
thanks a lot Luke
#1189
ORIGINAL: Rare
Dudelive
#1191
WA
Original: Dudelive
I have read all of this since it started and all the discussion between you and Bigmik was very interesting. I am still waiting for you to GET THAT GEAR........LOL.... I want to hear of YOUR test results. Oh by the way get 2 gears 'cause you may accidently get throttle happy. Good Luck
Dudelive
Dudelive
![EEK!](images/smilies/eek.gif)
#1193
oh my oh my.
my body shell is scrwed. the painted cracked. I need to repaint the celica body with polycarbonate paint this time. Winter is coming guys. need to clean up and put it aside for awhile
![Frown](images/smilies/frown.gif)
#1194
WA
ORIGINAL: xflames
oh my oh my.
oh my oh my.
#1196
WA
ORIGINAL: xeliman
what the max rpm of this motor?
my lrp hits 47.000rpm at the same turns
never heard of that esc i use novak.
#1200
RiCeY
soz i meant the ESC,
a little typo from me there
also do you know if they will post to the UK
thanks rcluke
thanks rcluke
