My Feedback: (10)
RE: Welcome to Club SAITO !
LOL you wally!! Better a prop than the Workshop ha-ha
Thought you appreciate the pix ol' farty pants and yip your right about the hangers... one of which is now the Airforce Museum
ORIGINAL: mike early
Thanks. I was wondering just how much they unwound in the air.... Pretty hard to determine that, I imagine....
hi, i have a saito .82GK. engine runs goods, except for at a few clicks above idle, revs start rising and falling again, like it going lean then rich lean then rich... what could this be? also the throttle arm can be pushed in about 3-4mm when at idle, i noticed when i went to adjust low end, arm pushed in a little, engine went lean and conked out! the spring inside seems too weak. why do they build them with so much slop in the throttle arm? That's definatly somthing that can be improved!
At w.o.t. i peaked then backed her off 500rpm. for the low end i just went in a bit at a time till it started to hesitate, then went back from there. only happens when i am a few cliks above idle and when engine gets to op temp. am i too lean on the bottom end?
Thanks for any help!
That's what i'm thinking! is there a way to stop this? or reduce the amount of slop in the throttle? maybe a stronger spring in the carby?
That looks good! thanks for that! my set up is a little different, but i get what youve done and think i can do a simular thing! have others had the same problem before, if so how did you go about fixing this? just want to get more ideas off everyone!
The beauty of forums!
My Feedback: (10)
Dang you're good Hobbsy! Mind reader too, I was just going to ask about the best slop-free throttle control methods used.
Good on yer mate
Good on yer mate
what about using ball links for the connections? i use ball links on my dl-50 cause that is also sensitive around idle and it works great! might have to do a simular setup on the saito! any thoughts?
VA
like 2/56 dubro's, scroll down to page 23
http://www.3dhobbyshop.com/private_i...7Sukmanual.pdf
I guess you got the hooded and swivel . I use a hooded but will go to the 2/56 swivels as the hooded ones are tight.
OH
ORIGINAL: salerno
has any one else used ball links on a saito for the throttle link? any down sides?
OH
Here are the ball links that I have used.
http://www3.towerhobbies.com/cgi-bin...&I=LXK091&P=ML
I'm sure the others would work well too, but I sometimes use those for control surface links.
The little 2-56 ball links are plenty robust for a throttle, and weigh practically nothing.
The only kicker with the ball links is that they take up room where you may not have any. However where you can use them they are smooth and can handle angles if any are necessary.
VA
ORIGINAL: salerno
yes now i see. is that a plane you have? it looks good. never had a sookie (sukoi).
.82a's work perfect in these size planes.
Mike
My Feedback: (10)
Where does one get these "Turbo Mufflers" from?? I can't find them. If they're as good as yo'll saying then maybe I best get one??
CHeers, Paul
CHeers, Paul
VA
I guess you could almost say its like going from 15% to 30% using one of these ? Im taching 11,000 on my .82 with it on a 14x4w .Others are reporting mid 10,000's if that.
i have the extreme flight extra also! just got it and have not flown it yet. this is what my .82 is on. i mouted the rudder servo and elevator servo in the back of plane for balance and put the rec. batt where the fuse cut out is behind rudder servo mount. still had to add 35gr weight to get it to balance. did you mount your throttle servo where recomended in manual?
VA
Yep, its up under the motor box, I made a battery tray for the RX pack and regulator right behing the Pull/Pull rudder. Im going to throw another elevator servo on it though as I feel the joiner is a little flexable. Still I love the Extra . Im sure the Sukhoi is going to be every bit as good if not better.
The first time I locked into a harrier with the Extra I melted awsome tracking on IMAC also.
Seal the canopy on it from getting oil up in it.
Mike
Mike
Nice pix hobbsy,does the handbrake polish your models for you..if so we are all coming over for dinner at your place tomorrow night matey i'll settle for corned silverside and mashed spuds,beaver likes kumara's(sweet potato)any other orders/requests???..pls pm hobbsy
