RE: Welcome to Club SAITO !
Yes i'd like to see it hobbsy and unless someone says for Gods sake don't do it,i'm going to carefully put a scriber mark on the plastic arm and then wind the low speed in and out again gently so i know where i'm at.Andy let me know how you go please.
cheers
peter
cheers
peter
Pete, I'm not a very good judge of those little millermeters but it looks like the adjusting screw is 1.5mm inside the face of the throttle arm and 1.75mm outside of the naked steel barrel. Sorry abou the lousy pics, I have new camera and haven't mastered close ups even though its on full auto.
Hello captinjohn
He has a point re focus hobbsy or you could down a scotch or two and lean back a bit ..i've already had a couple but still had to take my glasses off so the second shot was sharp as!!
Marked and then wound the needle in gently.If it makes any sense i applied the same force to the screw driver as to the weight of a full box of matches in your hand,think i'm 2 and 3/4 turns out.
cheers
cheers
My Feedback: (19)
AZ
W8ye,
There has been little to no discussion on the 200ti. I have heard that it sounds great but puts out the power roughly of a 150 to 180. I have installed one in a 150 size mustang and here is my question...Why does the mannual call for such a small prop? It calls for a 14x6 or 15x6. I run a 17 on my 180 in a P-47 and have used an 18 on a 150 in a cub.
The 6 inch spinner will make the 15 inch prop look pretty small and out of proportion. Just guessing...is it because each cylinder is only a 100 and the prop has to work with each cylinder and not the combined power of both?
Could the mannual be in error?
Club Saito Member #399 but still with a lot to learn.
Jerry,
I just got this from Horizon,
Specs
* Type:4-stroke
* Displacement:2.00 cu in (33.00 cc)
* Bore:1.10 in (28.20mm)
* Stroke:1.03 in (26.40mm)
* Cylinders:Inline twin, chrome plated
* Engine (Only) Weight:51.5 oz
* Crankshaft Threads:M8x1.25mm
* Benchmark Prop:17 x 8 APC @ 8,900
* Prop Range:16x8 - 18x10
* RPM Range:2,000 to 9,200
* Fuel:10%-30% synthetic
* Mounting Dimensions:160 x 110 x 142mm
* Muffler Type:Pipe
* Cylinder Type:16.5cc x 2 / AAC
* Carb Type:Barrel, 2-needle valve
* Crank Type:Ball bearing
Andy
Specs
* Type:4-stroke
* Muffler Type:Pipe
Andy
NY
[ul][*] Hello Again thank you for the info on the 100 and 115 it saved some frustration and errors making less trials needed [*] and what makes a saito club member ???
Thanks again
Thanks again
Now that very nice!! at last.. a nice, compact, light and powerful 20cc 4 stroke gas engine!
I will definitely buy one!
Also an excellent chance to convert my glow versions to gas economy!
Perhaps a different cam profile or whatnot and the peak power will be at a lower RPM, maybe.
The 125 has power to spare for a 60-90 sized plane, that's for sure....
The 125 glow is great. I have one setting on the shelf and the guy I fly with has two of them one in a UCD3D60 and the other in a Twist 60. He thinks they are the greatest engines ever made.
Where do you guys run your engines??
Got ticked off today by the next door neighbours son for running my engine up.What i would'nt do for a glass of good quality port and a guitar hobbsy.How are you guys getting around it??
I live in a semi rural area. There's enough distance that I've never heard a complaint.
Four strokes are quieter and at a different frequency than two strokes. You mostly run your engines at lower throttle settings - the irritation is greatly reduced
Hello Saito experts !
Sunday I'll go break-in my new 72 GK at my local flying field.
When I received my engine, there was no clearance to the valves. Is that something usual ?
It was such that I had no compression at all...
I've adjusted the valve clearance using the supplied gauge.
Did I mess up something ?
Thanks for answering,
Paul
Paul
If the engine feels correct in that it has compression every other full turn then it is probably OK.
Probably the safest was to set the valves is to set one valve while the other is fully open
No, I've checked that also. The pushrods were at their place, inside their housing.
Well never mind, that won't keep me from loving Saito engines.
Is there any advice for the breaking-in of the 72 ?
My Feedback: (24)
ORIGINAL: Old Fart
So now I just run in my engines in my backyard. I have not had a complaint yet. But if I ever get one, I will tell them as long as their gardeners are making a racket from 7AM to 7PM. seven days a week with lawn mowers, string trimmers, and leaf blowers I will run my engines as I please.
My Feedback: (10)
Tell em where to go Farty pants! No more noisier than a lawn mower. Not like your running it up hour after hour is it??
I had a neighbour like that and I told him that if he wanted quiet serenity to bugger off and live in the countryside ( like Ayres Rock! )
What size Saito do you think I could fit in my lastest project?? lol
