Aerofoam T-45
#102
https://www.bananahobby.com/main-acc...2424-prd1.html
Looks like that's it there, 7th picture, just cant see it very well with white been on white.
FYI I bought one and hopefully fly it in the next 1 or 2, I installed a SW80. Quality is better than expected.
#104
#105
#108
The photo is the gear door servo arm from the AeroFoam T-45 foam turbine. The arms were clipped too short by the factory and now there is not enough throw even at 125% to close the doors. If I adjust the pushrods to close the doors then the nose gear will not clear the door when they are open. Anybody have any ideas where I might be able to purchase this double arm servo. It goes to a 12g servo with a small fine toothed shaft.
#109
My Feedback: (28)
#110
I ended up going with a standard horn for the servo that I had laying around and connected the two sides adjusted accordingly and opened the nose gear bay to allow more throw. Works great now. I am also using the Xicoy LG-15 gear controller which allows me to adjust the servo door travel.
#113
My Feedback: (24)
https://www.chiefaircraft.com/radio-...-matchbox.html
Bob
#114
I have a couple of questions that I would appreciate knowing what everyone is doing. The manual calls out 2x 3S batteries connected to the EBEC. When I watch Utube videos and builds they all are using 2x 2S batteries connected to the EBEC. What is the correct battery setup? I have two manuals. A small one that came with the plane and a second one from Banana Hobby (also marked Global Jet.club). The manual with the plane shows CG of 168mm and the Banana Hobby manual shows the CG of 178mm. Both provide an identical diagram of the CG which shows the CG at about the midpoint of the turbine access hatch release catch in both manuals. I measured from the leading edge to the midpoint of this release catch and it is in fact 168mm. 178mm would not be as depicted in the Banana Hobby manual. What is the correct CG for the plane? Thanks for any inputs!
#115
I have finished my build and just setting in the electronics to get a feel for the CG. I am curious how others have done this. As you will see from the pics I using 2x2S batteries for the EBEC and a 3S battery for the ECU. I have placed them all way back against the main fuel tank and my Xicoy balancer says I will still need 146g added at the very end of the tail. This is with an empty UAT and no pilots. Is this what is normal? I am really curious why AeroFoam has the battery strap in the nose? Thanks for any help!
#116
I do agree with the earlier comments that this plane is not plug and play by a long shot. I have repaired 24 different manufacturing defects including an entire wing that had to be replaced. This plane has by far been of the poorest quality and highest defects of any plane I have ever built. With all the fixes done I am sure it will fly fine but I truly wish I had never bought this one. What is sad is that all the defects could have been avoided if the assemblers were properly trained and/or would pay attention to their work. It is also clear that the manufacturing plant does not have adequate process controls in place or these issues would have caught.
#117
T45 Aerofoam
So, a few counter-counter points if I may...not intended as a poke in any individual’s eye, just a furthering of the discussion:
1) Weak gear support broke on a first flight
2) Gear that won’t retract (how was this not clearly known to the mfr before release?)
3) Not-visible UAT (critical preflight item)
4) Sloppy control linkage (perhaps usable but at least questionable)
This isn’t a race for the bottom, two wrongs don’t make a right, folks jumping off of a bridge doesn’t mean that others should follow suit etc...So...The fact that some other mfr’s have something as bad and/or worse and/or more expensive neither changes the basic premise that of the above are clear signs of lack of development/testing before being released to consumers who then find themselves having paid hard earned $ for the privilege of doing the manufacturer’s work. Nor does it somehow excuse the foisting of known defects upon consumers.
Being fun to fly once the consumer works out inherent defects? Check. Great. But one should be clearly informed and forewarned when buying any product and that is the clear value of this thread IMO. Buy this model with the understanding that it’s a Harbor Freight jet that looks good in the color advertising but doesn’t live up to the job in reality and needs work.
Lastly, I respectfully disagree that “Plug and Play” is in the eye of the purchaser. By definition, the play part should..play. Right? Using an electronics or software analogy here, PNP doesn’t mean plug then re-solder connections or re-write code to achieve the basic intended functions. While some of the above squawks could admittedly be subjective, the play part w/r/t the landing gear structure and retract function isn’t working here as stock. This may be a simple case of semantics though as the quoted post did clearly indicate that this is PNP with the exception of the gear.
To each his own obviously because that’s what a free market is all about, but I’d offer that this jet is “Plug, Work On It, Play”, and because it’s not advertised as such I define that as a mess. All the more so because I can’t imagine the mfr not knowing of certain issues before shipping.
None of my opining should be construed as detracting from the OP’s and others’ efforts, volunteering their time to educate and inform. That’s both laudable and invaluable.
#119
This is not a matter of not being supported by Ralph or Mike. They are not the ones responsible for the poor workmanship coming out of the plant in China. The plant clearly has no quality control or process controls around their manufacturing processes. Unless Ralph or Mike is the CEO of the manufacturing company they have no control over what is being shipped to us.
458destroyer (04-01-2022)
#120
Of course they do, since they are the "approved" reseller or agent for the company that makes them. I would expect at the very least to get a standard quality jet from the company, that's what you paid for and its their responsibly to make sure at the very least you get that. I bought their AF L-39 and other some slight issues here and there, yeah one landing gear motor had to be replaced but over all it was fine, even after 60+ flights. The T-45 I have is same as yours only issue so far is the left airbrake does not fully retract after it closes. I haven't flown mine yet, but overall it's acceptable and haven't run into any other issues.
Anything defective IMO needs to be replaced as long its not broken by the user. I've never had an issue getting items replaced. My experience is if I am that unhappy due to defective issues, Ralph had provided me with options which did include returning the jet (not the AF jets) we worked it out and life moves on.
Anyways you clearly have a different view of things like this than I do, hopefully some how you work it out and get flying.
#121
Can someone give me guidance on GC? I've used the recommended CG 178mm from the leading edge. Started with placing the Ecu (2200 3S) and 2 x 3000 2s RX batteries at the front where the velcro strap is. Using the SW80 turbine, standard 12 channel Spektrum rx and using the bottom fuel tank for my fuel, top tank is empty.
I take off and it's tail heavy lol, today as I was burning off fuel you could clearly see the CG was going aft, ended up up cutting the flight short and landed using no flaps and scratching my head.
I looked above and didn't see anyone say about putting lead in the nose, and also I'm using the Xicoy CG balancer telling me I am .3lbs nose heavy.
Thanks..
Thanks..
#123
Can someone who's flying their T-45 look in the very front of the nose and see if there is lead weight in there. I'm told the AF L-39 has lead to balance it out otherwise it would be tail heavy.
Looked in my T-45 front nose and there is no lead which could explain why mine is tail heavy.\
Best way to look is through the nose gear door at the front .. thanks.
#124
My Feedback: (52)
I use 3 2200m 3s LiFe batteries. Two at the front of the equipment plate and one thru the opening in the forward part of the fuselage held in place with the provided velcro strap. All other equipment is in stock location. Using K-70 for trubine. Picture attached. Balances using ez balancer at the 7" mark. No lead in the front.
Paul
Paul
#125
Thanks Paul.
Here is what I did on the 1st 2 flights, All 3 batteries were strapped in right at the Velcro location.
What's interesting is I switched to heavier rx 3000 x 2 batteries on the 3rd flight same location and it was way worse with the CG been aft.
What I will do is pick it up (full uat) upside down at the 7" mark and see where its at. Its just strange I never an CG issue like this before.
