New BME 50cc Sport Model Engine
#101
RE: New 52cc Engine
ORIGINAL: Mitsu1
It will get its "arse" handed to it too .... if it goes up against a DL50![sm=what_smile.gif]
ORIGINAL: RTK
This is the sport line. It will compete with DL, 3MM, etc.
ORIGINAL: 3D Joy
I wonder why it does not have one of the 110 heads.
Let me restate. This is quality American made engine with some parts manufactured off-shore. All assembly, quality control and warranty work will be done here in the USA, not elsewhere. It is a piston ported engine priced at a bargain $299 that will compete price wise with Chinese engines in its class.
What does the DL-50 go for?? Don't have the numbers for the 58 yet, but it will have the 110/115 jugs
#104
My Feedback: (13)
AR
RE: New 52cc Engine
The DL50 goes for $370,.. a little more than the $299, but you are the one who said it will compete against the DL and 3MM. The DL50 is proving to be a raging bull. Ralph, I know you tested one, and it outpaced a G62 and a couple others. I own a DL50, but haven't run it yet, but just listen to the owners in its thread. They're going goo-goo over its user friendliness and performance. I'll glady "eat crow" if this new BME 50 challenges a DL50. I'll be glad to buy one of the mentioned new budget twins too, .. if its roughly 2 X $299!!!
#105
My Feedback: (85)
RE: New 52cc Engine
ORIGINAL: RTK
I am quite sure the DL-50 will out turn the BME Sport 50, but I really doubt the DL-50 will out turn the BME 58. Cubes are Cubes and the 58 will be reed induction too.
Kevin
#106
RE: New 52cc Engine
ORIGINAL: Kevin Greene
Cubes are cubes???---Why will a stock DL50 out perform a stock G-62???[8D]---The bottom line is that how an engine is designed (Carb placement, reed valve intake, porting and etc...) will determine output as well as cubes....I'm not telling you anything that you don't already know...---The jury is still out concerning the BME 58---It should be a good performer as all of the BME engines that I have owned performed well...I haven't kept up with the design of the 58---Is it a side draft carb or reed block intake or rear rotary intake???
Kevin
Kevin
Could be wrong but I thought the DL50 and 62 turned the same.... I am sure Ralph will clarify this. Ya gotta prop them a little differently too so as to hit each engines peak torque. Would be nice to have a dyno test on both.
#107
RE: New 52cc Engine
BME Sport 50 stock muffler
24x8 Bolly carbon fiber 6600-6700 rpm
22x10 Mejzlik 6800-6900 rpm
My G62 Abell muffler, rcign1 conversion
22x10 Mejzlik--7100-7400 I gave a range because I can't remember if it was 7200 or 7400 next time I run it I will post.
Oh by the way, what will the DL-50 spin those two above mentioned props at?? Hopefully someone has run both.
#109
DC
RE: New 52cc Engine
When I tested the DL50 with the same prop as my G62, it was 100 rpm better with its muffler than the 62 was without the muffler...I said somewhere here I wish I was the dealer...
The 62 will outlast it, but hardly anyone will fly either one long enough to kill it....
Reed valve VS piston port, side carb VS rear carb....I have been told there is a Chinese G62 clone about to be released, it's possible I might be a dealer for those...Price will be competetive.....Guarantee will be 3 years, awaiting a prototype to test...
#113
RE: New 52cc Engine
ORIGINAL: ghudgins
Are these engines out yet and if thay are where can you get it?
BME Engines
325 Whitetail Creek
China Spring, TX 76633
Phone: 254-836-0835
Fax: 254-836-0837
email: [email protected]
#115
RE: New 52cc Engine
Depends on how the engine is set-up, ports, port timing, etc. "Usually" the reeds have the advantage.
Funny that no one has posted any numbers on these two props (24x8 Bolly carbon fiber 6600-6700 rpm
22x10 Mejzlik 6800-6900 rpm) for the DL, I know prop numbers don't mean much, but with all those engines out there someone must have run one of these two props.
#117
RE: New 52cc Engine
ORIGINAL: Steve
My Taurus is piston port, and I am just wondering if the 58 will have a noticeble differance in power.
Keith,
Will the 58 also be double counter-ballanced like the 50?
Keith,
I "believe" it will be the same type of set-up as the 50, I know it will not be cantilever. It will have more power than the Taurus 52.
Keith will correct me if I am wrong.
#118
AR
RE: New 52cc Engine
According to DL the engine is 50.8cc, I have not had mine apart to measure. It turned a JXF 22x8 (aka Xoar) 6800 the first day I ran it, it's at about 1 1/2 gallons now. Will recheck when I get a chance. altitude about 1400 feet 83 degrees, high humidity about 65-70% this was after just turning the screws enough to make it run, NOT PEAKED
#120
OH
RE: New 52cc Engine
KEITH,IM IN TOTAL AGREEMENT ABOUT US MANUFACTURING EVERYTHING IS BEING Outsourced.!!!! IT IS GETTING TO THE POINT YOU CANT EVEN BUY AMERICAN MADE PRODUCTS.COMPANIES ARE BEING FORCED TO SHUT THERE DOORS OR MOVE THERE OPERATION OVER SEAS ....
HERES HOW I SEE IT.............IF YOU MAKE IT IN CHINA SELL IT IN CHINA
JOE LEWIS
JOE LEWIS
#121
DC
RE: New 52cc Engine
You gonna fly your airplane with the Japanese or German transmitter in the country it came from
With maybe the Czech made engine ?
Or the "assembled in USA" chainsaw cylinder engine ?
Dave Johnson published a list of ALL the parts of his engines and where they came from...All over the world....
Try going to a US company to buy engine short blocks.....
The last made in USA radios were ProLine, made on 21st ave in Phoenix...About 30 years ago...Mine is a 1972 Custom Comp, converted to a MicroPro 8000 and narrow banded in 1990...Still works just fine
#122
RE: New 52cc Engine
RTK
