Old 10-22-2008, 07:32 PM
  #12551
salerno
Hi All, in regards to the throttle stop screw that holds the barrel in, i decided to try and temper the scew by heat treating it to see if i could harden screw and make it last longer so it does not wear out so quick. i just grabed the screw in some big pliers and got my gas torch on it till it went blue then dunked it in water till it was cold. dont know if this is the right way to do it, but last night flew about 6 tanks of fuel through it it it did not need retuning! when i got home i took the screw back out and it was not worn at all!
i was on getting about 4 tanks before screw would wear before!
If anyone is having problems with their screws wearing out and making it hard to adjust the low end, try this!
Old 10-22-2008, 07:58 PM
  #12552
Hobbsy
Hobbsy's Avatar
I have about 18 Saitos and have been flying them since 1991 and have never had that problem.
Sod, I can run a 14x7 MA and a 14x7 Graupner on my 1.15 tomorrow on 15% WildCat 2/4 fuel if you like.
Old 10-22-2008, 08:45 PM
  #12553
mike early
mike early's Avatar
I'd be interested in the those results, Hobbsy.
Do you normally prefer MA or Graupner 3-bladed props?
Old 10-23-2008, 07:44 AM
  #12554
Hobbsy
Hobbsy's Avatar
Mike, I prefer the Graupners purely because of their cool looks, the Graupner blades are about 1/8th inch wider so the MA will turn slightly faster. I don't see the results differing much on the 1.15, but, I'll be back.
Old 10-23-2008, 08:03 AM
  #12555
sodbuster 1
sodbuster 1's Avatar
ORIGINAL: Hobbsy
Thanks Dave
really appreciate it.
How's it going with the Bingo? Working on putting mine back in the air this week.
Salerno did you try doing a scratch test with a file to see if the screw was now harder than the barrel?
Old 10-23-2008, 08:19 AM
  #12556
Hobbsy
Hobbsy's Avatar
SB, my wife was stung by a yellow jacket about a week ago and has been in out of the Hospital twice. As to the BigBingo, I have the fuse, tail and the right wing complete. More later.
Old 10-23-2008, 08:24 AM
  #12557
sodbuster 1
Wow she must be extremely allergic.
Hope she feels better soon....
Old 10-23-2008, 08:36 AM
  #12558
Hobbsy
Hobbsy's Avatar
She sure is, from now on the rule is, Epipen in the thigh and then straight to the hospital. I probably didn't spell Epipen right.
Old 10-23-2008, 08:46 AM
  #12559
AJsToyz
AJsToyz's Avatar
Dave,
Hope she's feeling better. My wife is allergic also , but we have plenty of time to get her in. Its more like , oops , got stung , finish the dishes , pack up the kids and we'll go to the hospital. Do you have money for an ice cream on the way ?? Hope she's feeling ok
Andy
Old 10-23-2008, 01:58 PM
  #12560
Hobbsy
Hobbsy's Avatar
Here are some numbers for four different props, two runs with a TurboHeader installed and three runs with stock exhaust.
Saito 1.15 plain
Fuel===WildCat 15% 2/4 cycle fuel with 18% synthetic lube.
Graupner 14x7 with TH installed, rpm ===8,450
MasterAirscrew 14x7 with TH rpm======9,450, much greater difference than I experienced with Diesels.
MasterAirscrew 14x7 with stock exhaust==9,200
MasterAirscrew 14x9 with stock exhaust==8,450
MasterAirscrew 13x8 with stock exhaust=10,100
Idle with all props 1,900 except 13x8 which needed 2,100 to be smooth.
The 14x9 was very noisy.
Old 10-23-2008, 02:12 PM
  #12561
sodbuster 1
thanks for the test runs Dave
wow!
BIG difference in the Graupner vs MA 14 x 7
think I'll get one of each of those and see which performs better in the air
Old 10-23-2008, 02:26 PM
  #12562
mike early
mike early's Avatar
Powerful engine, that 1.15!
The graupner 14x7 bogged my 1.25 as well.
I like the MA 3-bladed props as a result.
Thanks for the numbers, Hobbsy!
Old 10-23-2008, 05:38 PM
  #12563
boogermancan
boogermancan's Avatar
humm now i got a 82 on the old pts p51 it has a 14x10 apc on it at 8200 on byron 30% heli 24% lube plus the spoon full of castor i add to it and the nitro speed scent must be smelling blueberry dont you know
the 14X14 apc it to much for the saito 82 i have 20 hr showing on this motor <hobbsy > any chance you got any 30% to test the rpm out
Old 10-23-2008, 06:04 PM
  #12564
Hobbsy
Hobbsy's Avatar
Boog, I've never owned any 30%, I did own one jug of 20% a couple of years ago when I had a few YSs, I got rid of the YSs and used up. I now have 5% and 15% and that's it, Sorry.
Old 10-23-2008, 06:13 PM
  #12565
boogermancan
is there a big drop in rpm's over the 15 to 5
Old 10-23-2008, 06:21 PM
  #12566
Hobbsy
Hobbsy's Avatar
I'll have to do a comparo between them, I know that all the Saitos I own run fine on the 5%, the only one that has a little problem is the little .30, it does'nt idle very well on the 5%. I'll check the power out on a couple of larger ones though.
Old 10-23-2008, 08:37 PM
  #12567
mike early
mike early's Avatar
Hobbsy is a wealth of info, past and future!
Thanks!
Old 10-23-2008, 09:48 PM
  #12568
punkin438
Do any of you guys have an extra carb kit for a FA-50?I would be happy with just a high speed "O" ring.Seems everyone is out of stock now.
Old 10-23-2008, 10:47 PM
  #12569
w8ye
w8ye's Avatar
You may find one at the hardware
Old 10-24-2008, 07:37 AM
  #12570
AircamperAce
AircamperAce's Avatar
Hello everyone at Club Saito! I was given an old Saito 65 to hang on my Hangar9 Cub. The engine came from a friend of a friend's dad, so gummed up it wouldn't move. It was soaked, cleaned and given to me. I was so blown away at how nicely this thing ran, flew and idled, I sent off my YS 63 to Canada to trade for a Saito 72 to use on a Hog Bipe I'm building. So here's my question, I often read about people replacing the bearings in their Saitos, sometimes just for being gummed up. After my experiance, I just can't understand why.
Old 10-24-2008, 09:22 AM
  #12571
Hobbsy
Hobbsy's Avatar
I wonder the same thing, a lot, I think a lot of guys are paranoid about it and replace them unecessarily.
Old 10-24-2008, 09:41 AM
  #12572
w8ye
w8ye's Avatar
I replace a lot of bad bearings but they are in other people's engines
Old 10-24-2008, 09:53 AM
  #12573
AircamperAce
W8ye, How did you know they were bad? Excessive noise or play?
Old 10-24-2008, 10:04 AM
  #12574
w8ye
w8ye's Avatar
roughness
Old 10-24-2008, 03:17 PM
  #12575
tundraman
I love my Saito's! Best value for a 4-stroke IMO. Plus the Golden Knights look awesome!
