RE: Welcome to Club SAITO !
Yeah just the other day it was in the $330's. I am looking for a new 125 for my gp gee bee but now I might have to go with a used one.
My Feedback: (56)
Hey genius, decided to look at some of your post. Do you mean the engine is changing color when you remove the glow?? There is a difference in dyeing and dieing. Oh by the way have you noticed the huge increase in Horizon's ARF price. Maybe that is why the Twist is worth $200. I'll keep checking you since you seem to have an interest in interfereing in my business.
VA
ORIGINAL: gjeffers
i run a 17x8 apc and its perfect, as far as the cline i used one and started having the same problems as you, first you need the regulator as close to the needle nipple as you can get it, if you still have problems you can do as i and take it off and toss it in a drawer, i also went to a side mount and i put my fuel tank back up front and went with a great running engine instead of all the hassels the cline presented me.
ORIGINAL: Race21
Any ideas on prop and fuel on a Saito 180? LS needle is perfect. HS wont get rich enough. 4, 5, even 6 turns out and it won't go rich. Running 15% and have tried a couple of props (16x8- too small I think, and a 17x6). In flight the engine goes lean after a few minutes and quits. Have a Cline regulator set up as illustrated. Is the prop the problem? Any ideas appreciated.
Move your Cline closer. Turn the nipple over so you can mount it up in between the rails and have nipple to nipple. I have run a Cline on my 180 with a 18x6W.
You should test the engine out on a stand to get your base numbers then you can trouble shoot the fuel setup.Take the time to see what a difference the Cline makes from one inch away to right on the nipple and also compare with a properly mounted tank with just muffler pressure.
PA
I have been flying for over thirty years and have owned many brands. Just recently bought a new Saito 115 for my Pica fifth scale Waco bipe. It"s my first Saito but it wont be my last. Love it.
Merril
Merril
One question guys:
Can I use the breather nipple that is in the bottom of the cranckcase of a Saito 82 to install a Perry Pump?
Thanks for your advise.
Happy Landings
Happy Landings
Yes
You have to put a Tee in the line. One of the three sides of the tee goes to the breather, another goes to the back of the Perry and the third goes through a restriction or valve to the atmosphere
ORIGINAL: Old Fart
Merril can you post a pic of that? i'm looking for a dcaff so i8 can bolt an fg36 to it.
is this one to your liking?
have read good things about them.there's one or two up on here for sale even. might be able to swing a deal minus an engine
http://rcguys.com/decathlon.html
Thanks for the answer
Wich pump would you recommend for a Saito 82, the oscillating pump VP-20 or the regulating pump VP-30?
Again, Thanks for all the advice
Happy landings
Happy landings
The oscillating pump certainly works out mighty handy for a Saito. If you do not have a pump yet and you are using a four stroke by all means by the oscillating model
PA
Old fart
I got this Waco from my son just reciently. Don"t know the ariginal builder. It must be over thirty years old, but still very nice shape. I have a very nice picture that I will post as soon as one of my kids comes over to show me how to do it. It had a OS 90 in it, but now I put the awsome Saito 115 in it. Now I"am in love.
Merril
Merril
Hi sod yes it is and what a whopper,very nice and may be too big for me,i'd like full span ailerons like the smaller ones because i want to hotrod one.Tired of looking at yaks and extras nice as they are.I want a dcaff that hoots and have three 65" blackhorse/seagull/pheonix kits in the shed.Flown one with the 62 which is adequate,this one has an 82 and maybe a new lightweight 100 for the third.No idea what i'm doing but it's fun.
cheers
cheers
Good one merril,do your kids do vids? if you get round to it stick it on you tube please,like to hear the sound of it.Waco's sure look pretty as do clipped wing taylorcraft,i'd like to hotrod one of those too.
cheers
cheers
Hi I have a Saito FA-56 on my Kyosho P-40 which is my first Saito and my second 4S. Been reading a lot from this forums and sure enough it made my way much easier in breaking in my new Saito. Love the performance and the sound, and I know it would get even better as I go over a quart on it. I hope I'm qualified to be a saito club member [sm=regular_smile.gif]
ORIGINAL: beeper0358
Have you flown that plane with the Saito FA-56 yet? I know a fellow that is selling one with a similar sized engine, and I was wondering if it had enough power...
How much does your plane weigh?
Thanks.
Hi Mike,
Yes I have flown it around 10 times on my Kyosho P-40 and that size has average power for flying it scale like. Besides it is nose heavy as it is with the FA-56 and I had to put a 25gm weight at the back. Unfortunately I don't have a weighting scale to check how heavy it came out. Maybe I can borrow my friend's bathroom scale and see how it come out with. Oh I am using a 11 x 8 prop and I believe it will be more happy with a 12 x 6.
Danny
Danny
Just borrowed my friends bathroom scale and it was coming at 5.9lbs. The manual says the plane weights 5 - 5.5 lbs so including the engine at .9lbs that would make it 6- 6.4lbs.
PA
[img][/img] Hi Old Fart! One of my kids came over to post this pic of my Waco for you. Enjoy!
Merril
ps let me know if this doesn't appear on your end and I will try again.
Merril
IA
Could some one please send me a message telling me how many turns to start out on a Saito FA 50. Im trying to get my twist in the air and it keeps dying. Need to get it tuned and have never had a saito before. Thanks
