RE: Welcome to Club SAITO !
First, always make sure you're using a 4 cycle glow plug as they have a better element for the demands of a 4 cycle engine. In fact, I use a 4 cycle plug on my 2 cycle engines and notice a difference in performance. Regarding your burble, that sounds more like a carburetor adjustment issue than a glow plug matter. Regarding the plug that came with your engine, I have bought 4 Saito engines that came with plugs and have found the plug to be good and reliable and they last a long time. When I replaced them, I used an O.S. F type plug. I have found the O.S. plug to also be very reliable and they last a very long time which is good because they are expensive. You'll probably get a lot more recommendations for other plugs as this is a loaded question that I have seen on this thread before.
Capt Lou
Capt Lou
Over the hundreds of runs you'll get out of an OS Type F plug, it is an insignificant price difference. A penny or two. No plug is better. Some are close, maybe. I definitely respect the opinions of these guys that have been running engines longer than I have by a factor of 20. But they won't tell you that any plug is better.
VA
For real, you guys actually change your glow plugs? I think I do it just for the hell of it every once in a while.
ORIGINAL: Old Fart
You guys are all spoilt,i'm happy when it starts
I spend the kind of money a premium engine costs and it better run balls to the wall with no issues because otherwise it was wasted money.
I have no problem making an adjustment as simple as a better glow plug if that brings out the true potential of an engine.
I've had many 2 strokes that absolutely needed experimentation with different plugs to find the one that made it run right.
Also with more fuel efficiency.
ORIGINAL: sodbuster 1
I'm sticking with Saito SS plugs right now. They seem the same as OS Fs, and are priced much better.
If the coil in the plug looks good - do not throw it away. I put them in a little container in my flight box to be run some other day.
ORIGINAL: w8ye
or to sell if Platinum ever comes back to $2100 an Oz!!
I'm kind of doing the same thing with my stock certificates.....lol < not really laughing.....
i still have all the original SS plugs in all three of my saitos going back 5 years and have not had one fail yet. i think that the plug in 4 strokes are and easy target for blame on bad tuning. JMO
not me, not for the price they cost.
ORIGINAL: Old Fart
hello to all!
does anyone have a mount for a saito twin 90 mark 2? the one i have has a couple of extra holes drilled in it, and its driving me nuts! i also have an older 45, can it be mounted horizontaly on a 25 size cub so the cylinder is seen on the right side of the cowl? what do you guys think? i was also thinking of using the twin 90 on a 80 inch cub. just looking for some advise. i have sort of collected older four strokes for awhile and was thinking of putting these to use.
Dave
Dave
Is there a velocity stack available for the Saito FA-100? I've looked all over the Horizon website, and can't find one for the QQ engines...
I'm putting one in a GP Super Sportster 60, and was curious if anyone else is flying the same setup? What would the recommended prop size be? I've been flying 2 strokes since 1982, this will be my first 4 stroke airplane and trying to get a grasp on this new technology... I'm thinking a 14-8 or 9 would be a good matchup for this airplane.
What do you guys think?
The velocity stack fits all the small block engines, it seems.
http://www.horizonhobby.com/Products...odID=SAI50GK93
Might as well pick up one of these, as well:
http://www.horizonhobby.com/Products...?ProdID=BRU202
http://www.horizonhobby.com/Products...?ProdID=BRU204
