RE: Welcome to Club SAITO !
Thanks!
I'm mostly concerned with keeping the RPM's in check with this fairly speedy airframe, and keeping enough ground clearance, although it isn't that big of a deal to make a new taller set of legs for the SS60.
WI
I have a Saito 150 looking for a new home. I was looking at the Extreme Flight Yak 54-74". Anyone have any experience with this set-up? I am afraid of under powering this plane. Any other suggestions??????
Mike
Mike
IL
HELP!!!!!! HELP!!!!!!
My Saito 100 Is running on 30% coolpower heli fuel. The engine idles great and runs 9300 RPM WOT sounds good!!! My problem is when I go WOT and chop to idle it comes down great and then dies!!!!! I've been tuning high and low needles and replaced the plug with new. It dies every time no matter how rich or lean th LS is. I have not had a problem when i was flying on 15% coolpower. All the fuel lines are new, new dubro fuel filter and there are no bubbles in the intake line at the carb. PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
My Feedback: (18)
Can anyone tell me approximately what page the post for setting the LS and HS needles is on? My 1.25 seems to be sucking too much fuel (14oz. per 9 minutes) at no more than three-quarters throttle. That seems to be a bit high. I'm running a Top Flite 15-8 at 8400 rpm.
Bob
Bob
Set HS needle at absolute peak with a tprop that wil;l let it rev to about 9,000 rpm
Then procede to lean LS needle 1/8th turn at a time checking top rpm and transition after every other change, at some point it will hesitate when opening the throttle a little. Back off 1/8th turn rich on the LS needle, richen top rpm down about 200 and see what you have at that point, it should be close to right on.
s10junky83
Try replacing your glow plug. Also, if it runs well on 15% Coolpower, why use 30% heli. I experimented with both of these fuels in a FA-100 and came to the conclusion that 15% works well and that 30% heli is not worth the extra money.
Capt Lou
Capt Lou
ORIGINAL: mbrennan1
Mike
Mike
yes.
box it up and send to my house..........
we take in ALL kinds of strays
I promise you it will be well taken care of and will live a very long and rewarding life.......
ive just ordered a NEW PLASTIC BACK PLATE FOR MY 82 as it has deformed and melted from a hot run. When i took it out i noticed some plastic particles inside.
ORIGINAL: mbrennan1
Mike
Mike
My Feedback: (18)
I flew the 1.25 in my Nitro Models Sea Fury today after leaning out the L.S. needle with corresponding adjustments to the H.S. needle. I used 8 oz. of fuel for a nine minute run. Much better fuel consumption. By the way, once I calmed down the throws on ailerons and elevator, it flew perfect with the sweet sounding 1.25. I only needed one click of down elevator trim. Haven't tried the flaps yet, but they need to be deployed to slow the beast down.
Thanks Hobbsy
Bob
Thanks Hobbsy
Bob
My Feedback: (21)
ORIGINAL: s10junky83
Hi Everyone,
I use an APC 14x4W on my Saito 82 for 3D. I have both a Saito 100 and 125 that I need a 3D prop for and I am looking for your suggestions.
Thanks Al
Thanks Al
OH
ORIGINAL: P47 Jug - Al
Hi Everyone,
Thanks Al
Hi Everyone,
Thanks Al
I haven't tried any 3D props on my 1.00. I have used a 14x6 and 15x6, and I prefer the 15x6. My 1.00 is on a Mustang, and it isn't a 3D plane.
Can someone help me? I need to put in new bearings in my Saito 100 and I'm not sure how to re time the cam shaft to the crank shaft. I do see the mark on the cam shaft gear, but how does that line up with the crank? Thanks, Dan.
Here is a good price on your new OS Type F plug:
http://www.gravesrc.com/OS_TYPE_F_PL...LE_p/osmpf.htm
ORIGINAL: hayman1
Have you taken your motor apart yet? It's been a while since I've had one of mine apart, but I seem to recall that there was a punch mark on the teeth of the cam and the crank that needed to be lined up. You have to put something down one of the pushrod holes to hold the cam gear from spinning out of alignment. I think I used a toothpick.... You definitely have to do something to hold that cam from spinning, though. You'll never get them together accurately if you don't.
Like I said, it's been a while. Can someone else smooth this out for Hayman?
Bob
The mark on the cam goes straight down with the piston at top dead center
Remove the intake valve lifter and insert the small end of a pushrod through the intake lifter cavity and into the oil hole in the cam that will be aligned with the lifter hole when the dot is straight down.
While holding the crankpin at the top of it's travel, insert the cam assembly onto the crankcase while holding the cam in the proper orientation with the pushrod inserted through the lifter hole.
Thanks for correcting me, Jim. It had been a while. I thought that there were matching marks on the cam and crank... Thanks for setting that straight for me...
Bob
Bob
