Old 12-04-2008, 11:54 AM
  #13026
w8ye
w8ye's Avatar
On the 91 there is no performance increase power wise. You do get less mess in the engine compartment and better fuel economy
On the 125 the Saito stack cuts the performance by a couple hundred rpm according to Hobbsy so he made his own.
Old 12-04-2008, 12:28 PM
  #13027
Capt Lou
ORIGINAL: w8ye
Guys:
This was my experience as well. When I put the velocity stack on my .91, I burned noticably less fuel (around a 20% improvement) and there was less mess in my engine compartment.
Capt Lou
Old 12-04-2008, 12:31 PM
  #13028
Slats!
Do you need to put a filter on the stack??
Old 12-04-2008, 12:40 PM
  #13029
Capt Lou
Slats:
You do not need to put a filter on the stack, although you could if it is necessary to keep dirt out of the engine. I have not used a filter and have had no problems. However, when you put the velocity stack on the carb, you need to put a seal or gasket between carb body and the velocity stack body to seal area around the carb air intake hole. If you just put the stack on the carb there is a space between the two bodies that is not flush and this will allow air to by-pass the stack and make it less efficient. I used a small o-ring that I bought a plumbing supply store.
Capt Lou
Old 12-04-2008, 02:54 PM
  #13030
mike early
mike early's Avatar
Hobbsy has a custom velocity stack for his 125 you say? I'd like to see that.
Old 12-04-2008, 03:43 PM
  #13031
RPMcK
RPMcK's Avatar
Mike,
go back to page 478 in the forum and you will find a discussion about veliocity stacks and a discription of the one Hobbsy made for his 125 I believe it was. I'm gonna try making one for a new 115 I just bought.
anyway - lots of information there.
Ron
Old 12-04-2008, 06:02 PM
  #13032
BountyHunter51
BountyHunter51's Avatar
W8ye, Thanks for your help. That puts my mind at ease.
Cheers! BH
Old 12-04-2008, 06:25 PM
  #13033
w8ye
w8ye's Avatar
Original: Hobbsy 8-26-2008
Thanks Harvey, yep I responded to the wrong guy, sorry.
Also, someone mentioned the velocity stack I made, the current velocity stacks Horizon sells are too small for the 1.25, they have a smaller ID than the carb venturi at full open so I wasted a stock one by drilling the hole in the steel bracket larger and using an appropriatley sized piece of K&S tubing. I have now cut it down to about half the length you see. I worked that out with the help of the late Mr. Robison. Bill said cutting the tubing off at a 45 degree angle would approximate the effect of the bell on the stocker.
Original:w8ye 8-26-2008
The Golden Knight Saito 100, 115, and 125 do not come with a velocity stack from the factory
However the Saito 50GK velocity will bolt right on the bigger engines. This is the only velocity stack that sait installs on the medium case Saito engines.
What is being talked about here that although the Saito 50 velocity stack will bolt onto the 125 and look perfect - its small size robs the engine of close to 300 rpm on the top end.
Old 12-04-2008, 06:27 PM
  #13034
Hobbsy
Hobbsy's Avatar
OK
Old 12-04-2008, 06:44 PM
  #13035
Hobbsy
Hobbsy's Avatar
Woops, sorry Jim, I was too slow.
Old 12-04-2008, 06:48 PM
  #13036
mike early
mike early's Avatar
I like the look of the new stack on the FG-20, but I don't imagine it'd work on the 125.
Old 12-04-2008, 07:04 PM
  #13037
w8ye
w8ye's Avatar
Those of you who are not completely aware of the FG20 look here . . .
http://66.102.1.113/translate_c?hl=e...n10D0VM4apw8pg
Old 12-04-2008, 08:01 PM
  #13038
mike early
mike early's Avatar
Comparative fuel consumption
Gasoline
FG-20
Per minute 10cc
Glow
FA-125
Per minute 45cc
good fuel mileage of gasoline engines and their features of the plane dirt cheap low!
Old 12-04-2008, 09:51 PM
  #13039
balsaeater
ORIGINAL: mike early
Gasoline
FG-20
Per minute 10cc
Glow
FA-125
Per minute 45cc
Thats debatable on how much the engine cost to buy compared to the glow version and how often you fly. Then there is the issue of possible lesser power compared to glow as in what sizes props the engines can turn at what RPM . I worked out for my Saito 180 in glow compared to gasoline it could take me some few years to get back the difference in fuel costs to break even on the extra expense to do gasoline . Also for me if I did do gasoline I would probably only do Aspen fuel which is a more cleaner more highly refined gasoline that hasn't all the whacky chemicals that ordinary gasoline has .This is so as to reduce risks of fuel gumming up from age issues and it stops all those nasty odours that gasoline has .(Aspen fuel costs are 50% to double the normal gasoline costs ) .Others ight chose to use Colemans but that often in Europe cost 4 to 10 times the price of normal gasoline if you can find it . If I don't use Aspen fuel I would have to buy a seperate tow trailer as the odour and pong from gasoline is wicked inside my small hatchback compact car.For a guy that fly several flights a time and several days a week the gasoline is probably better idea for the bigger engine planes coupled with a tow trailer or roof rack for the plane
Balsaeater
Old 12-05-2008, 09:29 AM
  #13040
Capt Lou
Gasoline
FG-20
Per minute 10cc
Glow
FA-125
Per minute 45cc
Mike:
In my experience, this is a no brainer and I agree with you. Gasoline engines are more efficient and cost effective. I principally fly Saito .91 and 1.00. I pay $35 for a gallon for glow fuel. I also have an Extra 300 with a 50cc gas engine that costs about $3.50 per gallon of gasoline/oil mix. Since I have had the 50cc, I have used 10 gallons of gas in it or a cost of $35. An equivalent amount of glow is $350 or a savings of $315. My gas engine is just about broken in so I have a lot more flights to go before I replace it. At a 10 gallon break even/comparison point, I have recovered my cost differential between the 50cc and my Saito engines and have a lot more flying time to go on my gas engine which is incremental savings.
Capt Lou
Old 12-05-2008, 10:08 AM
  #13041
mike early
mike early's Avatar
I was just repeating the quote from the translated web site. I love it. But I do agree, it seems a great advantage.
Good fuel mileage of gasoline engines and their features of the plane dirt cheap low!
Old 12-05-2008, 01:46 PM
  #13042
blw
blw's Avatar
1.5 oz per minute is high. I wouldn't go by those numbers.
Old 12-05-2008, 01:50 PM
  #13043
welder1
Hi guys I have two saito .82s and two 1.80s. I am having a problem with them idling they will idle for a while and start to kind of make a poping noise and then die. I know how to set the high speed needle and ive been leaning in the low speed needle transition is good. It still has a popping noise almost like a miss after it idles for a minute or so does it sound like my low speed needle is still to rich? Any help would be appreciated thank you in advance oh and i would like to be a saito club member
Old 12-05-2008, 02:17 PM
  #13044
mike early
mike early's Avatar
I would think the LS is too rich still. Perhaps it is loading up and dying. Keep leaning the low side out until it cannot transition smoothly from idle to WOT and richen just a hair (1/8th turn)
Old 12-05-2008, 02:59 PM
  #13045
welder1
Thanks Mike for your input i will keep leaning low end needle. How does cold weather effect these engines its about 35 degrees colder than the last time i have started these engines is this normal to have to lean the low end in colder weather?
Old 12-05-2008, 03:04 PM
  #13046
mike early
mike early's Avatar
I'd think it needs more fuel in the cold... Colder air=more oxygen per cc.
Hmm, we better let one of the experts answer that one.
Old 12-05-2008, 03:58 PM
  #13047
Rudolph Hart
Rudolph Hart's Avatar
ORIGINAL: N1EDM
Old Fart,
Are you Brian Winch????
Bob
No,but i'd love to have his job when he karks it
Old 12-05-2008, 05:30 PM
  #13048
N1EDM
Bob
Old 12-05-2008, 06:19 PM
  #13049
Hobbsy
Hobbsy's Avatar
Part of what is happening is that the glow plug is cooling from the rich LS needle and eventually just goes out. Cold will have very little effect on the LS needle but may change the HS enough to need tweaked a little.
Old 12-05-2008, 07:16 PM
  #13050
welder1
Hey guys thanks for the help i will lean it in a little more tomorrow and see what happens thanks agian.
