The new Tornado sport jet
#1301
RE: The new Tornado sport jet
ORIGINAL: DrYankum
Yup, plain old Multiplex for Aileron and flaps, second one for rudder and elevator. Make sure you make the connections opposites!
Greg
Now you've done it ..you got me confused. What second one? I'm planning on using a 6 pin multiplex with the signal wire form the aileron,flap, rudder and elevator connected to each of 4 pins and then all 4 positives to one pin and all 4 negatives to the 6th pin.Will there be a current problem all going to one pin? Also not sure what you mean about making the connections opposites.
Jerry
Greg
Jerry
I make sure that the A/F is male, the E/R is female. That way you always plug in the correct servo pairs.
I don't want to find out the hard way that there was a current flow issue! [X(]
Greg
#1303
Jetflyr...thanks; now I see the light. Your picture showed only 1 muiltiplex...probably the R/E connections. Did you put those on Ys or separate channels?
Jerry
Jerry
#1304
#1306
ORIGINAL: DrYankum
Jerrye
Jerrye
#1308
There are plenty of pics on this thread.... just look through each page
I have a k80 in mine, no weight added, shes nose heavy also but thats not a real problem.
I had three flights today and went very well. This week i repaired some small damage to the undercarage and added extra epoxy to all three retracts.
Upon inspection at home i noticed that that one retract mount that i didnt completely remove, just added extra epoxy to visable mount points had broke. Was three very smooth landings too. So i removed the built up ply on and added heaps on every joint.
Most of the retract mounts had no visable glue.. just looks like zap or something. Very disapointed that this bird still needs so much work to get things solid. Hopefully now that all three retract mounts have been removed and properly glued in it should be good as gold.
Anyway see second flight vid her, enjoy
http://www.youtube.com/watch?v=FSni3-7tbpo
#1309
Nice video really good job.
i just saw one of your other vids of a startup. Word of advice you might want to make a start tube, if you get a wet start you will melt the covering instantly. You can also dropone or two of the startup paramaters which will help reduce flames during start. I think pump pwr ignt to 22 works well
#1311
ORIGINAL: warbird51
I am working on the new Tornado and I have a couple of questions. How is the balance coming out? Do you have to add nose weight? I'll be using a Jetcat P60. Also can people post pics of their equipment placement?
Wayne
Wayne
ENJOY
Greg
#1313
My Feedback: (12)
ORIGINAL: jetflyr
Wayne-she comes out nose heavy to begin with....get everything as far back as you can (hold in place with doubled pieces of tape until you check the balance). I have the two LiFe packs behind the spar all teh way in the rear.
ENJOY
Greg
ORIGINAL: warbird51
Wayne
Wayne
ENJOY
Greg
Thanks Greg,
That's just the kind of info. I am looking for!!!
#1314
My Feedback: (81)
Just a public Thank You to Modellbau and Henry himself! I havent met another company that awnsers calls/questions/concerns like this guy. Henry, you are a great example of what this hobby is all about.
Thank you from Texas for taking all my questions and concerns!
I think you just earned a customer for life.
#1318
The fill valve for the air system that I got as part of the package has no check valve in it. How do you keep air in the system after unscrewing the filling nipple? Also what brake valve are people using. A mechanical on/off valve with greased O rings is what I've been reading on other threads. Proportional electronic brakes seem pretty pricey for an entry level jet.
#1319
My Feedback: (7)
WA
ORIGINAL: DrYankum
Don't waste your money on the Jetronics proportional valve. I have one on my Tornado and it works, but the proportional part does not! It uses (read that as wastes) too much of the air in the small tank while trying to get some proportional braking. I just maidened my Tornado this past weekend at JOW and I've noticed that if you just let the plane slow down some after touch down and then just give it full brake then she stops gently and effectively. I use my right slider on my 9503 and I don't have the brakes lock up at full application. My .02...
On another note, the jet flies beautiful. Got some dual with a great gentleman from Canada (DW) this past weekend, and then got my waiver. It was a BLAST!... All works as advertised on the throws. I did add a little more elevator, as I'm a bit nose heavy, but it's fine like that. Also, the ailerons were way too sensitive for my liking, so I dialed in 45% expo and she grooves real nice like that. The only weak point in my opinion is the gear. The gear works well, but the stamped metal sides that hold the axles on the mains are very weak. Mine were tweaked real bad after a normal (not hard) landing to the point that the sides of the tires were rubbing up against them and were acting like locked up brakes. I quick fixed it by holding on the main part of the strut while bending the wheel back straight.
Good luck
Z
#1320
Jaime I'm glad everything went well. As for the gear that is a problem that we discovered after wards and has been fixed. Anybody who bought older gear we warranty it 100% all you have to do is call bill at spring air and send him the older gear and he will make the fix or replace the gear so it never fails.
#1321
I have the Jetronics proportional valves in four of my jets and with the disc type brakes they work perfectly, minimal air loss if set up correctly, the problem is mixing old (read O ring brakes) and new tech, they don't mix very well.
Mike
Mike
#1322
ORIGINAL: BaldEagel
Mike
Mike
agreed, never been able to get good proportional breaking with an O-ring brake system (you're lucky if you can get both to just be equal without pulling to one side). with the O-ring you're better off with an on/off trigger valve (it's cheap) and just lube the brakes so they won't lock.
#1324
ORIGINAL: BaldEagel
KC
Nice to hear from you, did you sell your tornado or build it in the end?
Mike
KC
Mike
finely decided to build it about two weeks ago and it's 90% done.........wishing i'd of sold it tho.
waiting on the screws for the servo horns, they were none in the servo kit, Henry sent me replacements a few weeks ago, but they were just in an envelope and were ripped out of it when they went though the belts of the postal service and i've yet to receive the replacements.
i've had several issues that i haven't seen mentioned here but overall i guess it's a decent kit.
#1325
WV
Hi guys....I haven't posted any thing latley so I have a thought on the servos that I got off of Henry. I pluged in the rudder servos into the rudder slot on the receiver and turned the radio on and almost instantaly the one servo smoked and the other servo froze up. I have never seen a servo smoke and I have been flying for over 30 years. I talked to Henry about this but they are not using these servos any more, so I ordered a couple of hi tec 225's and now I have to modify the servo opening tol use these servos.
