Old 03-03-2009, 09:20 PM
  #14026
w8ye
w8ye's Avatar
The flex pipes tend to crack real easy
Old 03-03-2009, 09:41 PM
  #14027
Ken6PPC
ORIGINAL: jdkxtreme
I just picked up a new saito 80..Well it is a few years old but never ran. I am going to put this on a goldberg cub sometime this summer..There was no muffler with it. I was thinging od going a 90 deg adapter and flex pipe..Any ideas on that? Would it be nasty loud or sound ok?
The flex pipe is more restrictive than you might think. The ribs reduce the sound quite a bit. Often, the engine's performance is reduced as well.
Flexible Pipe for Saito FA80
http://www.horizonhobby.com/Products...D=SAI182TD1112
Right Angle Adapter for Saito FA80
http://www.horizonhobby.com/Products...rodID=SAI65140
You might want to consider a TurboHeader instead of the flex pipe. I have three of them. They sound great, they are more durable and lighter (I think) than a 90 degree adapter and a flex pipe. You will most likely get a modest performance boost as well! The price of the TH might be a little bit higher than the flex pipe and adapter, but not that much.
http://www.rcuniverse.com/market/item.cfm?itemId=483717
Old 03-03-2009, 10:46 PM
  #14028
jdkxtreme
Thank you..I think I am going to go with the TH..With the fa80 I do not think I will need the 90 deg adap..
Old 03-03-2009, 11:40 PM
  #14029
w8ye
w8ye's Avatar
Good choice. I like my Turbo Headers
Old 03-04-2009, 01:46 AM
  #14030
Slats!
Hi just wondering if anyone can rec a prop for a saito 82 on an extra 300. Is 14X6 suitable, just wondering which combo works best. Also are people using wood or APC these days. Thanks
Old 03-04-2009, 02:00 AM
  #14031
w8ye
w8ye's Avatar
The APC 14-6 is the standard sport prop for the Saito 82
Old 03-04-2009, 04:35 AM
  #14032
Rudolph Hart
Rudolph Hart's Avatar
Hello,like any other pipe that is mounted thoughtfully and carefully they mostly don't crack.With the saito flex pipe tho i've noticed some black flakey bits in the fuel tank when i removed it.Are they powder coated,dipped or anodized do you think?
Old 03-04-2009, 04:40 AM
  #14033
Rudolph Hart
That's great!..can you recommend an australian dealer so all the southern hemisphere readers of this forum can actually buy some of them?
A few cline or ironbay regulaters would not go astray either...is this a similar theme/promotion scheme re elvis never touring outside the states when he was alive
Old 03-04-2009, 11:17 AM
  #14034
Lidman
My Feedback: (41)
Hey guys, I am in need of a back plate for a FA 45 can't seem to find a listing at Horizon. Anyone know where I can find one new or used? Please let me know Thanks Mike
Old 03-04-2009, 12:41 PM
  #14035
w8ye
w8ye's Avatar
ORIGINAL: Lidman
The 45 MKII has a different carb mount than the 45S. You could use a 50 back plate on the 45S
Old 03-04-2009, 01:09 PM
  #14036
Timthetoolman1
Timthetoolman1's Avatar
Has anyone posted a link or information on the lbs of thrust on a .91 with the recommended props?
I thought I saw it somewhere but 550+ pages is a lot of info to go through.
Thanks, Tim
Old 03-04-2009, 11:22 PM
  #14037
davidgeorge212
davidgeorge212's Avatar
Hi, I am plan building a monocoupe 90a model and I am trying to decide what to power it with. Plans say it is .30 to .45 size, but of course I am going to put a saito in it so I was considering something like a saito 56. Lately though I have been looking at the 60 twin which would be kind of neat. If I were to get the 60 twin, what size tank should I think about using?
thanks, David G.
Old 03-04-2009, 11:33 PM
  #14038
w8ye
w8ye's Avatar
The 60T has about the power of a 40 single cylinder four stroke. You run a 11-6 or 12-5 prop
Use at least a 8 oz tank.
where do you fly at around Auburn?
AU '68
Old 03-04-2009, 11:48 PM
  #14039
davidgeorge212
I actually am not really flying in auburn anymore I just transfered to a diffrent school. I still make trips to auburn and fly though because they have one of the best feilds around. It is about a 30 to 35 minute drive from downtown auburn going south and turning on I think us 80. they have a little blog websight at: http://www.auburnrc.blogspot.com/ It is a big field with a grass runway and a little pond in the back. The guy that actually owns the field has a full size cessna 180 he flies in and out of that field so the grass is almost always cut down.
david g.
Old 03-04-2009, 11:54 PM
  #14040
davidgeorge212
*sorry I ment he flies a 182 not a 180
Old 03-04-2009, 11:55 PM
  #14041
w8ye
w8ye's Avatar
Is down in that barn leanto were the guy keeps the 182?
Old 03-04-2009, 11:58 PM
  #14042
davidgeorge212
yes thats where he keeps it, you can almost make it out, thats cool, I am assuming you have been there.
Old 03-05-2009, 12:00 AM
  #14043
w8ye
w8ye's Avatar
but I see you are in AZ?
Old 03-05-2009, 01:12 AM
  #14044
davidgeorge212
me?, I am still in alabama, I have just moved to jacksonville alabama. Its not as good though because there is not a descent flying feild within 45 miles from me, at least not that I know of.
david
Old 03-05-2009, 04:44 AM
  #14045
NM2K
My Feedback: (14)
Then it is time to start a new club! BTDT when nothing was available. If I had more energy, I would do that here myself. Driving any more than ten or twelve miles to fly bugs me. I used to drive 35 miles when I joined my first club after the USAF. By the time you got there in the evening after working day shift you were lucky if you had time for more than three flights. And that was hurring all the while and grabbing a hamburger on the drive to the field.
Our local clubs are fantastic and they are populated with super people, so that isn't the reason that I would like a place to fly that is closer. Besides, I would join both of them anyway just for the camaraderie, etc. In NJ we had a program named "Green Acres" which allocated government owned parcels of land to organized/incorporated clubs of all kinds. I haven't been able to find something similar in Georgia as yet. If anyone knows of such a program, I would really appreciate receiving the information. Who knows, the good news just might give me enough energy to get the ball rolling.
Ed Cregger
Old 03-05-2009, 08:30 AM
  #14046
sodbuster 1
sodbuster 1's Avatar
ORIGINAL: N2EC
Ed Cregger
Ed, can you give a little more info on the NJ Green acres program?
Still stuck here in Jersey and I'm afraid for quite a while to come.
Fields are almost impossible top find anymore that are less than 35-50 miles away.
If you could, PM it so as not to clog the thread
Thnx
Old 03-05-2009, 08:46 AM
  #14047
w8ye
w8ye's Avatar
ORIGINAL: davidgeorge212
david
Gadsden has a field SW of town that is South of I59 and North of the river and West of the airport
http://www.modelaircraft.org/clubdetails.aspx?club=1985
Anniston has a field that is across I20 from the Talladega race track
http://www.modelaircraft.org/clubdetails.aspx?club=1018
I know these are on the opposite side of the metropolis from Jacksonville though.
Old 03-05-2009, 12:38 PM
  #14048
Timthetoolman1
If anyone knows if there's a site that shows power to weight ratios of Saitos or something similar please let me know.
Thanks, Tim
Old 03-05-2009, 01:46 PM
  #14049
w8ye
w8ye's Avatar
http://saito-engines.info/specifications.html
Old 03-05-2009, 02:10 PM
  #14050
Timthetoolman1
It doesn't have power in terms of pounds of thrust.
