RE: Welcome to Club SAITO !
ORIGINAL: GaGeeBees
I have to disagree with the "deadsticks rather frequently" statement. I mount the vast majority of my single cyl four strokes inverted and rarely - if ever - deadstick. That has just not been something I've experienced.
ORIGINAL: N2ECW
You won't see it from the ground when the model is flying. To have an absolutely reliable engine (sidemounted) versus something that looks better, but deadsticks rather frequently is a no brainer for me.
Ed Cregger
ORIGINAL: jdkxtreme
Crap..lol... I figured That is what I would have to do..It sure does look good inverted though..lol
Ed Cregger
ORIGINAL: Hobbsy
Mikester, I put a set of BOCA Ceramic bearings in my well worn Fox .50, they are very precise. The Fox is converted to Diesel operation. I have inspected the bearings twice since installation and all is well. I have a set of the BOCA ceramics here to install in an Enya .46 MKII. Its a shame you had a ball bust, that would be very disheartening.
I think I might be a new Boca convert....
ORIGINAL: jdkxtreme
My main question about it being inverted is..Do I still need to cut out more of the cowl than just the bottom for cooling?
Follow the 1:3 (air intake to air exhaust openning respectively) and you'll be fine.
Tim
My Feedback: (14)
ORIGINAL: mike early
ORIGINAL: Hobbsy
I would lean more toward RC Bearings. Lower prices and the same quality.
Ed Cregger
TN
I am going to mount it horizontal after all the reading..I just wished I had not cut the hole in the bottom of the cowl already..
ORIGINAL: N2ECW
Ed Cregger
ORIGINAL: Hobbsy
Ed Cregger
The bearing was brand new, from RC-Bearings. I've bought sets from both companies. Only one has exploded in the first 5 minutes.
My Feedback: (14)
So, you can draw a conclusion from one sample? Baloney.
Paul doesn't make the bearings. He only sells them. Just like Boca.
Whatcha gonna do when Boca's bearing does the same thing?
I know Paul. I've been dealing with him for a decade or so. Let him stand behind his product. He doesn't need this kind of bad press.
Ed Cregger
Ed Cregger
Saito .91 = 12 lbs of thrust
OS .61FX = 7.7 lbs of thrust
Does that sound right?
The guys flying SPA are saying the 4 strokes are not working for them, but they are also using OS 4 stokes. The planes are weighing between 6-8 lbs.
TN
I have the twist 40 out side tied down running more fuel thru it..I have almost a gallon thru the saito 82..What should be a good idle?
ORIGINAL: rangerman
With a stadard prop on both engines
There are a couple reasons the SPA guys use a OS 91 Surpass rather than the Saito 91. The OS 91 Surpass II seems to have a little more power than the Saito 91. (And it weighs more too)
But what the SPA guys will tell you is that you can set the needles on the OS 91 Surpass II early in the day and when your turn to fly comes, you start the engine, take-off and fly the pattern. They claim you cannot do that with the Saito 91 without a run-up and a needle check?
ORIGINAL: jdkxtreme
My Feedback: (14)
ORIGINAL: rangerman
Put the same prop diameter and pitch on the .61 two-stroke that you are running on the Saito .91. You may have to switch glow plugs toward the cold side in the two-stroke to prevent preignition, but you should see a bit more rpm from the .61 than the .91 if both are burning 15% nitro fuel. Any more than that and you might have to shim the head of the two-stroke to prevent preignition with the large prop.
Folks have been running OS four-strokes in SPA for years with great success. But, they are burning 30% nitro heli fuel and they have to shorten the nose/lengthen the rear fuselage in order to get the models to balance. Frankly, I can't see how they would have enough control authority with the stock size control surfaces. They are also running large diameter/low pitch propellers to slow down the top speed and to enhance vertical performance. The large prop diameter also helps keep the speed down in vertical ascents.
I have talked to a few of the SPA folks and they claim that the Saito .91 doesn't hold up as well as the OS FS-91 SII with all of the heavy practice flying that they must do to remain competitive. Yeah, it surprised me too.
The best way to compare the two engines that you have mentioned is to go through a bunch of props and find out exactly which size favors each particular engine. You will find that the two-stroke needs to turn up a bit in order to generate the same or more thrust than the .91 four-stroke. What really hurts the two-strokes in SPA is the inability to legally run a long, stretched out tuned pipe, which would also help quiet the two-strokes considerably. This is one area in which I disagree with the practicality of the SPA rules, but whatcha gonna do? It's their contest.
Ed Cregger
When I was at the field and saw that all the pattern planes had OS 91 Surpass I & II four strokes, I asked Bruce Underwood, the Pres. of SPA who I happened to be helping to set up his sun shelter. He more or less told me what I posted above. At the time I couldn't believe what I was hearing but all those SPA guys couldn't be wrong.
I have three Saito 91's and a Couple of OS 91 Surpass II's and used to have a OS 91 Surpass I.
I would rather use the Saitos any day. They weigh less and don't have the screwed up speed changes and surging apparently caused by carb icing in the OS engines. The OS Surpass II will pull a bigger prop than a Saito though. The Saito 100 compares more favorably powerwise with the OS 91 Surpass II and weighs about the same also.
Thanks for the info, that is a shock. I always hear them talking about OS 4-S but none of them run as well as my Saito; however, I've set the valve clearance on some OS and they run a lot better. It seems like the Saitos are more durable but that's just my experience...weird the SPA guys don't agree.
Thanks again,
Tim
Thanks again,
Tim
Original: Ed Creggor
My Feedback: (14)
That makes perfect sense, Jim. I was thinking that they had diminished authority because of the much lower airspeed when using the low pitch/high diameter props. Maybe they get some of that back with the longer tail moment.
Ed Cregger
Ed Cregger
ORIGINAL: N2ECW
Ed Cregger
Ed Cregger
My Feedback: (27)
NV
About the ceramic bearings, in my misguided life talking to the boys that make the noise etc. 99.9 cases of ceramic bearings going bad is in the installation, they are prone to crack if they are not installed correctly, cocked or hammered on, a lot moreso than metal ones.........John
There's a difference between smooth and loose vs tight and ratchety. Cockeyed is tight and ratchety. Chipped ball is ratchety of a different nature. Smooth and free is correct. Loose is a new one that I will know next time. These were installed correctly Thanks.
ORIGINAL: w8ye
Greetings Gentlemen,
I was hoping your vast experiences could tell me if what I noticed this weekend with my 1.25 was normal.
After one of my flights, I grabbed my aluminum spinner and noticed it was very warm to the touch. I haven’t ever really done that before, so I don’t know if I should have expected that. The valve covers were too hot to touch comfortably. I didn’t notice anything strange during the flights (though this is a new engine, so I don’t have a feel for ‘normal’ yet). The engine is cowled with a 1:2 entry/exit ratio for the airflow (The opening oposite the cylinder is covered with a screen to restrict airflow).
So, am I just paranoid? Is there some other way to ensure the engine is not getting too hot?
Thanks!
Pearhead
Thanks!
Pearhead
Run without the cowl and compare
The plane will fly pretty much the same without the cowl
you must do your "feeling" immediately at shutdown or the engine will heat soak all the way through.
Yes don't run it,just kidding mate
Hey mike 109 just running in my 30 and will post a pic.Sounds and purrs like a kitten,will be a good match for the rainbow[img]
Hey OF, you'll love that lil engine, I bought a second one when it was announced that Horizon was going to quit handling them. The first one was just like yours and the second is a GK. I sent the first one to Bill Ribison in Fla. to be part of his Saito notes, he sent it back with a black cylinder. Now that he has passed on it one of my most prized posessions. I run Graupner a 10.5x5 or a 10x6 depending on the length of grass where I'm flying that day. Sweet engines.
