Old 03-21-2009, 02:01 PM
  #14276
Hobbsy
Hobbsy's Avatar
http://www.bocabearings.com/main1.as...2&n=*ENK-100ST
Click on the Part #s for the size
Old 03-21-2009, 02:04 PM
  #14277
72
72's Avatar
Perfect! Thanks.
Old 03-21-2009, 02:10 PM
  #14278
Hobbsy
Hobbsy's Avatar
I decided today was a PlayDay and ran my Saito 1.00 on Davis Diesel Fuel. The 1.00 started with no glow assist at all. Engine==== Saito 1.00 GK
Fuel Davis Diesel ABC mix
Prop===MasterAirscrew Classic 18x6
RPM at full throttle=====6,650
Idle===1,000 rpm
Kinda surprising for a stone stock engine. My old high compression .80 has too much compression and sounds like a black and gold grenade at anything over 5,500 with a 14x8.
ID:	1162607   Click image for larger version
Old 03-21-2009, 03:15 PM
  #14279
w8ye
w8ye's Avatar
ORIGINAL: Carl Myers
Hey there! I am really new to this hobby, doing a ARF Pawnee build now, plan to use a Saito. I am commenting on the human interactions between R/C's with God's most beautiful creations.. eagles, hawks, falcons. I am an old fart too, and was raised in the high mountains of Colorado where eagles and hawks soar endlessly on thermals, then stoop at incredible speed to attack a prey animal, or, fight for territory in the sky. Now I live in Kansas where this is an abundance of beautiful redtail hawks. I used to fly an ultralight airplane and enjoyed being "up there" with the birds... until I had one that actually attacked the flimsly ultralight several times. I was encroaching on his domain, and clearly he let me know it... I bugged out, but it was a cool interation, if not a bit scary. Unforgetable experience. Beyond the enjoyment of flying gas/nitro rc's, I am also hoping to use an electric powered glinder to soar with these birds. ... perhaps play with them... and hope to not run afowl with regulations that prohibit "harrassing wildlife" in our country. Long term project idea is to flim these gorgeous birds up close with r/c aircraft. I wonder if anyone else has done that?
Have fun!
Carl
Seen this on you tube but the actual hawk scenes are rather momentary
Old 03-21-2009, 05:18 PM
  #14280
GaGeeBees
My Feedback: (23)
GaGeeBees's Avatar
Okay Saito experts, I need a little help. I bought a Nosen Aeronca Champ with a Saito 130 twin that appears to be barely broken in. It has two glow plugs per cylinder and, of course, two carburetors. The low end seemed really rich and I've leaned each LSN about 3/4 of a turn. The transition to wide open throttle is much more crisp but it acts like I need to go further. What's the best procedure for peaking the high speed needles? Should I start the engine on one cylinder and peak it and then shut down and repeat the process with the other cylinder? I find it very difficult to set both cylinders simultaneously. I managed to run through three tanks of fuel today but had to land deadstick at least six times. Should I install onboard glow? Any advice will be welcome and appreciated.
Paul
Old 03-21-2009, 08:24 PM
  #14281
w8ye
w8ye's Avatar
Start the engine on both cylinders by heating only the rear plugs
Warm up the engine and peak each cylinder. Go back and forth a couple times. Do it the same way for low speed except you are checking for the leanest you can get the cylinder and it still transition to high speed. If the cylinder went out on acceleration, you have that cylinder too lean
Old 03-21-2009, 08:26 PM
  #14282
w8ye
w8ye's Avatar
Hobbsy, that's amazing that the 100 will just run on diesel as is.
Old 03-21-2009, 09:03 PM
  #14283
Hobbsy
Hobbsy's Avatar
My thought was that I'd have to apply a little glow heat to start it but it just fired up instantly. I just wish someone would come up with a way to adjust the compression a little. Most folks think model Diesels have higher compression than glow engines but that is not true. My Saito .80 actually has too much compression for Diesel operation.
Old 03-21-2009, 09:21 PM
  #14284
w8ye
w8ye's Avatar
O K , ___C L U B___M E M B E R___ A N N O U C E M E N T S
VeeAte- you are member #629
IKO69 you are member #630
av8djc you are member #631
Patxipt you are member #632
Old 03-21-2009, 09:27 PM
  #14285
jmcmike
My Feedback: (45)
can anybody help with my oil blowing out my breather tube on my saito 100???????
Old 03-21-2009, 09:30 PM
  #14286
w8ye
w8ye's Avatar
Oil blowing out the breather on a Saito
Often, this is the result of running the engine too rich. - The needle valves need to be leaned out some and typically it is the Kiw speed one that is at fault.
There are times that the ring gap is too great and there is too much piston blow-by on the engine causing excessive oil in the crankcase
Old 03-21-2009, 09:36 PM
  #14287
Hobbsy
Hobbsy's Avatar
It's supposed to come out of the vent, here is a lot of it from my Saito 1.15.
Old 03-21-2009, 09:39 PM
  #14288
jmcmike
My Feedback: (45)
this engine only has 1 gallon thru it and ive got it leaned out and it runs great and sips the fuel. The motor has great compresion too, just weird.THe motor is one a stick and i run a tube on the breather. Should i be able to feel air going in and out of the tube when i crank it by hand? My other saitos dont have this problem
Old 03-21-2009, 09:41 PM
  #14289
Hobbsy
Hobbsy's Avatar
You should only feel air comming out and it will be hot.
Sorry, you said while flipping, you should hear it gurgle and wheeze when flipping.
Old 03-21-2009, 09:59 PM
  #14290
jmcmike
My Feedback: (45)
Thanks hobbsy, ive never ran one with out a cowl i guess just never noticed the oil. I tune the lsn and hsn per you guys suggestions and its amazing how well and quiet these motors run.
Old 03-22-2009, 06:05 AM
  #14291
Rudolph Hart
Rudolph Hart's Avatar
Have fun!
Carl
Hi carl and yes they have,well too on some of the birdlife docco's i've seen,in a commercial sense i meant.Stayed up till midnight last nite finishing the rainbow off and getting the little saito 30 happy.It's an ep model and that battery hatch is a gift from God when converting one to glo.Fired it up early this morning and the airfield wedgie was up too.Maiden flight but once trims were sorted it was straight up there but well to one side and orbiting about 200mtrs away in the same circle,it was magic till my new and not run in engine stopped which the eagle seemed to like as he followed me down a bit,nice formation flying on his part.
Happy days guys
Old 03-22-2009, 08:17 AM
  #14292
BobbyGee
BobbyGee's Avatar
ORIGINAL: w8ye
Oh - can I get in on this, too?
2 SA72's, 2 SA80's.
BobbyG
Old 03-22-2009, 08:32 AM
  #14293
w8ye
w8ye's Avatar
BobbyGee you are member #633
Old 03-22-2009, 08:44 AM
  #14294
av8djc
ORIGINAL: Hobbsy
Hobbsy
That is very interesting. Where's the advantage, cheaper fuel? More torque? As for lowering the compression I would take a look at making a shim for under the cylinder. That should be fairly easy to do unless you get involved with having to lengthen the pushrods, PR tubes, intake tube etc. depending on the thickness of the shim needed.
Dave(r)
Old 03-22-2009, 09:48 AM
  #14295
blw
blw's Avatar
What's my number???
Old 03-22-2009, 01:51 PM
  #14296
rwj146
My Feedback: (7)
Good Afternoon , I am installing a Saito .72 in a Sig Kadet Sr. ARF, it has a 10.8 oz. fuel tank, what sort of flight time should I look for? I will be using this as my trainer so mostly low speed flights. Also would like to know if a glow driver is recomended? Thanks.. Bob J.
Old 03-22-2009, 03:18 PM
  #14297
Patxipt
Your FA-72, according to this page consumes around 28cc/1oz per minute at full throttle.
Old 03-22-2009, 03:21 PM
  #14298
jdkxtreme
Well i got my $25.00 fa80gk running this morning.. runs like a sewing machine. my problem is when i go from full throttle to idle it idles down but then waits a second then goes to normal idle..Any ideas?
Old 03-22-2009, 03:23 PM
  #14299
w8ye
w8ye's Avatar
Were's the LSN?
It sounds a little rich
Old 03-22-2009, 03:28 PM
  #14300
w8ye
w8ye's Avatar
BLW you are Saito Club member #14
