Brillelli 46cc
#1427
RE: Brillelli 46cc
hello,
i 'm looking for two bearings to my 46 gt, do you know ref of them or ref of the engine ? i know it's a poulan 46 i think, that's all..
i live in france and would like buy them here.
thank you
stephane
thank you
stephane
#1428
My Feedback: (195)
RE: Brillelli 46cc
MM,
Check out "Boca Bearing" just type that in your browser and their site should come up. They have every bearing known to exist and they cater to RC. Hope you find what you are looking for.
Loopman
Loopman
#1429
My Feedback: (24)
RE: Brillelli 46cc
I don't think Boca will have that bearing, It has a rubber seal around it, You can go to www.lawnstation.com and look up the poulan pro and find the parts list for that engine, You can buy the engine still in the saw for $129.00
Milton
Milton
#1430
RE: Brillelli 46cc
Not sure about where to get parts in France but you may be able to order here in the USA>http://www.upstateoutdoorpowerequipm...d/default.aspx
#1432
RE: Brillelli 46cc
and yes milton,
it has a rubber seal , my engine juste have thirty flights with my patty and i hear a noise when i move my prop ( crankshaft moves a little) , and i have lost 200 or 300 rpm i think , according to me the problem is the rubber seal ...
stephane
stephane
#1434
MI
RE: Brillelli 46cc
I'm having a bit of trouble tuning this engine. On the ground the transition is excellent and no burble at any RPM. In the air is a different deal - WOT the thing scream with no burble however at just above idle to nearly full throttle I'm getting a burble. I've adjusted the high and low only a couple times with no help. Maybe I'm just not there with the low. Any ideas?
#1435
VA
RE: Brillelli 46cc
ORIGINAL: flymeaway
#1436
NY
RE: Brillelli 46cc
ORIGINAL: flymeaway
#1437
My Feedback: (41)
RE: Brillelli 46cc
ORIGINAL: cmoulder
Is there a static line from the carb plate routed to the inside of the fuse? If not, the kind of behavior you describe is quite common because of pressure changes inside the cowl.
ORIGINAL: flymeaway
Also worth mentioning: Another way you can get different mixtures is to have the same thing happeneing at your carb air intake. Both the vent hole and carb air intake should get undisturbed air...or be sensing from the same location so that if there is disturbed air they both sense it and the two different locations never see a difference. That's why 3W plumbs the vent to the air intake.
#1438
MI
RE: Brillelli 46cc
ORIGINAL: bmadden
What carb do you have?
ORIGINAL: flymeaway
It's a Walbro 21-245, if that means anything.
#1440
MI
RE: Brillelli 46cc
ORIGINAL: JoeAirPort
This is almost 100% certain to be the problem. I would bet that you are causing a high positive static pressure or a direct draft on your diaphragm plate vent hole when the plane gets up some air speed. This would simulate a high vacuum by your engine and cause it to run rich. Very common problem, and sometimes can cause it to run lean as well if there is a negative pressure on the vent hole. Just do as recommnded and plumb it out of the cowling...I have my Brillelli going inside my fuse just in front of my gas tank and it's the same mixture on ground as in the air. Ideally that vent hole is supposed to sense undisturbed atmospheric pressure, kind of a hard thing to achieve inside of a drafty cowling.
Would the location of my velocity stack have anything to do with this?
#1441
My Feedback: (40)
RE: Brillelli 46cc
Take off the stack and get some slightly short bolts or use some washers equal to the thickness of the stack. If you dont use up that space or get shorter bolts you will cause and air leak.
Some planes like the stacks some don't all depends how the air travels around the cowl.
#1442
My Feedback: (51)
RE: Brillelli 46cc
flymeaway, that line in the picture is the pulse line that pulses the diapphragm each time the piston moves up and down. Look at the other side of the carb for the vent hole. When I got my Brillelli it had a little nipple already installed for this purpose.
#1443
My Feedback: (41)
RE: Brillelli 46cc
ORIGINAL: flymeaway
I have the static line, but it's routed back to the motor:
Twista...err I mean Todd. It doesn't pulse the metering diaphragm, it pulses the pump. The metering diaphragm works of the vacuum of the engine. These always get confused.
#1444
My Feedback: (41)
RE: Brillelli 46cc
ORIGINAL: flymeaway
#1446
MI
RE: Brillelli 46cc
ORIGINAL: Twistawrecka
I don't see another nipple. There is a hole on the underside of the carb by the low and high needles - a fairly large hole, not threaded, can't tell where it goes. Would this be it? If so, looks like I'd have to tap it. Where should the vent line terminate in the fuse (is the idea here just to get the vent out of the turbulence of the prop wash in the cowl)?
I'll try to remove the stack first to see if that helps. I was hoping to fly today, but with a 20mph cross wind and scattered storms, I think I'll wait.
Guess I have a thing or two to learn about these engines. Thanks for helping me out.
#1447
MI
RE: Brillelli 46cc
ORIGINAL: fireman7875
How much time do you have on the engine? Mine is still breaking in and has a similar issue but smooths out the more I run it.
Brian
Brian
One more question. I switched to Amsoil running at 50:1. What are you guys using and at what ratio?
Bob
#1448
My Feedback: (41)
RE: Brillelli 46cc
ORIGINAL: flymeaway
#1449
RE: Brillelli 46cc
Take the time to look at the posts Joe AP references above. My G26 was doing the EXACT same thing and when I modified the cover and vented it to the inside of the plane it turned into a fine running engine.
#1450
NY
RE: Brillelli 46cc
ORIGINAL: flymeaway
The plane only has less than a dozen flights, however the engine has at least a couple of gallons through it between break-in, chasing RFI for three months, and actual flight time.
Bob
Bob
Saber is 100:1 and Dominator is 50:1, after break-in of course. If you've got a couple of gallons thru it, I'd say Dominator at 40:1 would be about right.
