OFFICIAL HPI Sprint 2 Thread (Sport and Flux)
#1426
This ciming Saturday we are going to the drag races. Last time we striped the rear belt of his car. Ran a 1.5 48mph. My rs4 ran 1.4 54mph
#1428
PA
ORIGINAL: Car-Boy
#1429
Has someone fitted a gens ace 2s 5000mah hard case on the sprint 2? I just got my sprint 2 and can't fit my lipos???
#1430
Hey guys,
For some reason when i turn my car on the motor does not beep anymore. The steering works fine but then my motor does not move what soever. I hooked it back onto castle creations programer and no luck. How can i test to see if my motor is fine? my battery seems to be fine too
Let me know
Let me know
#1431
PA
ORIGINAL: aquito
#1432
PA
ORIGINAL: Car-Boy
Hey guys,
Let me know
Hey guys,
Let me know
#1433
Sorry guys, it's been a while since I was last on line.
Not much to report since I've been away other than I'm still carpet racing my Sprint Flux 2 but my car kept cutting out towards the end of the night. After some investigation the other drivers suggested it was my motor overheating so I was advised to replace the standard spur and pinion as it would take the strain off the motor. I now have an 84T spur and 30T pinion, not sure if I'll notice much difference but I'll see when I go to my next race.
After even more investigation it looks like it might not be the motor after all, it might be the battery safety setting on the ESC. After a few races I checked the voltage on my battery pack pack and it was still showing well over 7 volts but I have been told that because my battery is a 2S then the voltage is split between the 2 cells so this is more likely to be the voltage setting on the ESC. Looks like I might be buying the ESC programming kit soon!!!
Hope you guys are well.<br type="_moz" />
#1435
Hi Car-Boy,
I was told that for the standard flux 2 motor I need my gearing to be around 6.00 for carpet racing, hence the 30T pinion.
Isn't the standard pinion around 23T already?<br type="_moz"/>
#1437
Hey guys I just bought this thing brand new about a week and half ago and have already been through 2 esc. The first was dead right out of the box. The second went today for no reason. I'm running the stock gearing it came with along with stock 8.4 nimh battery. Why does it keep dying on me.
Thanks for any help in advance
#1438
Hey all, just made the move up from the Micro RS4. Bought a Sprint 2 Drift last week. Iexpect to have it here in the mail in a couple of days. been trolling this thread for the last couple days. Lots of good info. I expect this thing to be drift worthy right out of the box. I'd like to take it to the track down the street and have it perform for me. Bsushless and LiPos' are down the road, but for now, I'd love to be able to just smile when i pull the trigger.
I'd like to know more about this USB cable/link thing that can be used to "program?" the ESC? am I reading all this right? (somewhere on page 2 or 3 there was some discussion).
#1441
Hi Grass Ninja,
I have recently aquired the Castle ESC programming kit. You can install the application straight on to your PC from their website. When you open the application it'll try to search for your ESC, simply connect the ESC into the chip device that comes with the kit. Then connect the USB cable to the device and connect to your PC and hey presto it should determine your ESC and provide you with a screen with the settings you can alter. I'm at work at the moment but from what I can remember you can alter the battery safety cut off voltage, drag brake, reverse speed, acceleration curves etc. If you want the full list of options I can find them out for you, just let me know.
On another note I was reading a few forums about drifters making roll cages out of drinking straws, at first I thought it sounded ridiculous but when I saw the results I was very impressed. I'm not a drifter as I do carpet racing but I like the idea of modding shells for any outdoor racing I do. I'll upload some pics later tonight (morning to most of you guys as I'm in the UK).
#1442
ORIGINAL: twonb1
#1443
I was using the stock hpi vapor flux
ORIGINAL: t9dragon
What ESC were you using?
ORIGINAL: twonb1
#1444
ORIGINAL: twonb1
ORIGINAL: t9dragon
ORIGINAL: twonb1
Did you have the ESC set to run the NIMH?
#1445
Yes sir it was set up for nimh
ORIGINAL: t9dragon
ORIGINAL: twonb1
ORIGINAL: t9dragon
ORIGINAL: twonb1
#1446
So I've got the sprint 2 flux(the new 2010 camaro)... I'm not sure what the stock spur and pinion gears are that come on it. I stripped the spur last year and replaced it, but I think I must have went bigger with it. The car seems much slower this year than it did last... I'm just curious what people are running gear wise? I'm looking for more top end than acceleration. I just purchased a 25 pinion and an 84 spur.. Any ideas what top speed would be on that setup with a 50c 2S lipo? I dont want to gear too low and burn up my motor...
#1447
Well, this is my first post here but I wouldn't say that I am a complete novice with these. Have been playing with my Emaxx quite a lot but I am wanting an on-road car to play with. Not planning on getting into racing just just something to run on the streets or in the parking lots while I am on lunch at work. I am just curious as to which one would be better the sport or the flux? Not really wanting to do drifting but i am guessing i could with the right tires. Iam just looking for siggestions on which one would be better sport or flux.
#1448
I have both and it's much easier to deal with the flux if you're talking about the Sprint 2 flux. It as fast or faster and fun. All you do is plug and play. In other hand like the nitro, you will need to carry fuel, starter or box, remote, tools for tuning, an the car itself.
#1449
Hi guys, I'm having issues with my Sprint Flux 2 and wondered if anyone could help.
I have 2 battery packs, when I fully charge the battery and run it, the car will lose power within a few minutes. I then use my other battery which lasts a lot longer but then that too loses power. I have then checked the voltage on both batteries, the first was just over 8v and the second just above 7v.
I even have the Castle Link application and I have set the battery safety cut off to 6v so it can't be that.
I have been told that it may be the ESC getting hot but if that was the case why does one battery last a lot longer than the other?
Any pearls of wisdom would be appreciated.
p.s. the car has the Vapor ESC and standard 5700 motor<br type="_moz"/>
#1450
ORIGINAL: Quattromanta
p.s. the car has the Vapor ESC and standard 5700 motor<br type=''_moz''/>
