KMP F-7F Tigercat
#1452
RE: KMP F-7F Tigercat
Elevator
I use six flight modes, to cater for full flap / half flap / no flap and gear up / gear down conditions. Elevator throws are the same for all modes. What I did find was:
1. In landing mode (full flap / gear down) I removed all expo from elevator. With the reduced airspeed, elevator sensitivity does diminish, and removing expo does help with managing the flair. All other modes use 20% expo. With expo in landing mode, I did get that "running out of elevator" feeling, but it was really only a sensitivity issue. I think once you get in the groove on final approach, you condition yourself to make small, smooth corrections to flight path. But with expo, you need to be hauling back stick more aggressively than might seem natural. I wouldn't have thought 20% would make such a difference, but it seemed to.
2. With gear down, the flap setting has little or no impact on elevator trim. With gear up, full flap needs quite a dash of down elevator trim. It seems to be quite a linear effect, so half flap needs only half the trim.
Silly question, but you do check the CG with gear retracted, yes?
#1453
ORIGINAL: Keithfl
Elevator
Elevator
I did my CG at 117 with retracted up !! is that ok?? I needed 400grams in the noze thats ok?
thx
g
#1456
My Feedback: (10)
ORIGINAL: Keithfl
Elevator
Elevator
#1457
ORIGINAL: Keithfl
Yup, the specified CG is with the gear up.
did you guys had to put lots of weight extra in the noze?
thx
g
#1458
My Feedback: (10)
ORIGINAL: ghost.fr
thx I had a stupid dought
thx
g
ORIGINAL: Keithfl
thx
g
#1461
Hi Ghost, I have been flying mine now and it's EASY to fly. Mine weights 31 Lbs. and a few ounces. I took weight out after removing the RCV 91 engines. I now have Fuji 24. Weight doesn't seem to be a problem. I'm from the"Old School" I don't use Exponential. I don't think you need it on this type of aircraft. Dual Rate is adequate. I use Exponential on my Turbine Jet and Pattern aircraft. I believe the main concert is CG. Keep it on the Nose Heavy side during test flights. You can slowly take out weight as you get the FEEL of the aircraft. The worst situation is to takeoff with a tail heavy aircraft. Col. Chuck Winter
#1462
ORIGINAL: CHARLES WINTER
Did the first 2 flights yesterday and only got a pb with a landing gear that turned in the air
today did 2 more flight and bumped on the second landing and damaged the wood on the gear and now have to repair it
And i did found then that tha wood used to build it is not of the best quality althout not the worse
I flys very well at fast speed but At lower its hard to make smooth turn without aving lots of "inersi"
I tryed different props and i'm at 9000 rpm on 14/7 with my saito 115 and then the bird is realy fast
this week i'll post a small video
thx
g
#1463
My Feedback: (10)
ORIGINAL: ghost.fr
thx alot col.
thx
g
thx
g
Congrats!
It's a great bird, once you sort out the bugs.
Hang in there!
Wally
#1464
My Feedback: (10)
Hey Capt G,
Nice job on the color n markings.
That was a LOT of nice work to get it to look like...ours!
I'd bet it is TONS better close up and the paint won't bubble in the sun, either...
Keep us posted.
Wally
Keep us posted.
Wally
#1465
I did not need any weight in the nose of mine with 2x Zenoan 20's. Mine weighs about 26lbs. cheers Richard.
Got a new bird to play with at the minute though!!!
#1466
THE VIDEO IS HERE : [youtube]http://www.youtube.com/watch?v=BoJVRYsHZ2U[/youtube]
TRY IN HQ QUALITY ITS REALY GOOD VIDEO ACTUALY IM IMPRESSED BY YOUTUBE
ORIGINAL: F82FAN
Hey G,
Congrats!
Hang in there!
Wally
ORIGINAL: ghost.fr
thx alot col.
thx
g
thx
g
Congrats!
Hang in there!
Wally
#1469
ORIGINAL: at-6 texan
hi ghost.fr we don't see the video.......
it works for me now
let me know
g
#1470
do you speak Italian?......tay so!!!!....non possiamo vedere il video perché dice che bisogna essere tuo amico e avere la tua autorizzazione per vederlo...
#1471
VIDEO NOW OPENED SORRY
#1472
nice video I thought the plane was not more great ... seeing the video I realized how small is this... however, and always an good aircraft.
#1474
My Feedback: (10)
ORIGINAL: Pylon2
No round engines and only one propeller, to boot.
Well, this is a pretty liberal thread!
