Goldberg Tiger Club
#127
My Feedback: (15)
RE: Goldberg Tiger Club
Bikerbc
you and VincentJ are on the 1/4 scale CW piper cub build thread right? the sig kit. builders of the tiger 60 kit need help and guidance from builders like you. if only they knew how much more time some kits take compared to others.
my sig cub is still on the bench, with opening door and window mod, and fuse is almost done. I need to get back into it because i have a Saito 180 to hang on it.
#128
My Feedback: (15)
vertical grimmace
i agree about Goldberg kits, i have many of them and I like them all.
eagle 2
tiger 2
tiger 60
eaglet
piper cub
probably the sweetest flying planes of all time.
eagle 2
tiger 2
tiger 60
eaglet
piper cub
#129
ORIGINAL: jkr_1100
vertical grimmace
eagle 2
tiger 2
tiger 60
eaglet
piper cub
vertical grimmace
eagle 2
tiger 2
tiger 60
eaglet
piper cub
And some the easiest to build
#130
Yes jkr1100, I just finished my Sig 1/4 scale clipped wing cubwhich took me 7 months to complete. The Tiger build is a cake walk compared to that kit. Goldbergmodels are very well thought out relatively easy to buildand fly great! I have also built the Super Chipmunk as well. I am currently building an oldie but goodie Sig Ryan STA (check out the thread).
#132
join me up too. I do not have a Tiger at the moment but have had three in the past and miss them. if anyone knows where i can get my hands on a 120 ARf please let me know.
thank you
Terry
[email protected]
thank you
Terry
[email protected]
#133
Yes You are rite the Tigers tend to be tail heavy..They have long tails, thats part of why they handle so well... I added I think it was about 8 oz to mine, might have been more, I cant rember..I just rember it was a lot .. I never though about going to a bigger engine..I am using an OS MAX 75 AX and I am happy with it...It has enough power , it is quiet , it is quite easy on fuel and easy to tune and run...I am tempted to try the DLE 20 . What do you think of that? I could build my next one with the DLE 20 in mind..I would maby put some fiberglass reinforsement on the firwall , might need a taller landing gear..My DLE 20 has a lot of power...It handled my 120 size seagull spacewalker easily....Till I dorked it...
#134
I am more than happy to help anybody with there Tiger builds..I have built enough of them to be fairly farmiliar with them and the mods that are worth doing if a person is into it...Like going to a tail dragger and or increaseing the size of the tail feathers , building on a cowl, etc.etc. The Tigers dont need much help, they fly pretty good building folowing the plan.... I am presently building a BUSA 1/4 CUB and I am also building a huge Cessna scratch build..It is going to have a 10 ft wing span..It is on floats or wheels. Powered by a G62 , Its getting close to being done..I gotta fiberglass the fuse prior to paint then paint the works...It has flaps although I dont expect it will really need them..The wing is pretty thick...Its a heavy lifter... This is my first attempt at something this big and its turning out pretty good if I do say so myself...
#135
My Feedback: (15)
a85vette4me #40
Welcome,
I think the DLE 20 would be a slam dunk. the only think i worry about is going gas would mean lots of vibration. I put an additional 1/4 inch plywood firewall for 1/2 inch total for the 150 4 stroke.
I would think that would be a minimum for a DLE 20. this could be a great combo. think of the long flight times with that engine.
Welcome,
#137
My Feedback: (15)
Tower hobbies has it. Its sold by great planes.
http://www3.towerhobbies.com/cgi-bin...?&I=LXK312&P=7
#139
I havent had any thing too do do with it or even seen one but I would bet that it is a fun little plane...I would not be scared of giving it a try...As long as its not too expensive...Smaller ones can somtimes be a bit more of a handfull to fly . When I looked it up I see it is discontinued....Where are you finding one?
#140
ORIGINAL: bikerbc
#141
At the risk of looking stupider than I already do I have a Question to ask...What is and how do you subscribe to a thread ? I see there are 25 guys subscribed to this one and I dont know how to do it or why you would want to or need to...Could sombody tell me somthing about it and how you go about doing it ? Thanks
#142
My Feedback: (540)
ORIGINAL: RDJeff
How about the Tiger 400? I've been eyeing one for a while, and even though it's an ARF, it ahould be okay with an FP10 or a PAW 1.5 insead of electric. Anybody have any thoughts on this one?
aircraft built for electric only do not have enough strength to absorb the vibration from an IC engine.
#145
My Feedback: (15)
Bikerbc
you can subscribe to a thread and it will send you an email letting you know if someone posts to it. not good for club saito. but for less active thread it lets you know when to go look. it also provides a gauge of how popluar the thread is based on how many subscribers it has.
JKR1100
JKR1100
#146
ORIGINAL: Crazy4Flight
you may have to double up the firewall triangle stock to fuse sides too.
ORIGINAL: RDJeff
#147
BikerBC,
talking about adding weight for balance, the Tiger I got from the estate sale has a 15/16ths Mac Tools Impact Socket as its weight.. Luckily I was test running the engine to make sure it would run correctly, before taking it to the field, and the socket came loose from it's Epoxy.. although had the socket come loose during flight, the previous owner had the foresight to use a zip tie to at least keep it attached to the airframe, it was dangling, but it was still there... Going to add some proper weight tonight or tomorrow tho!
Craig.
Craig.
#148
If you can find some lead shot you can mix it with epoxy and pour it in around the firewall. It adds strength and weight at the same time but its hard to remove if you change motors..I usually use stick on tire weights..I put a screw in for added security...Never used a socket though...I have heard of guys using dead batteries like d cells and such...Well at least you got your self a free socket...
